Question about Dryers
The main circuit breaker triggers when i have my electric clother dryer on for while
  • eddie martinez
    eddie martinez Dec 06, 2008
    yes it the main house breaker but the breaker to the dryer doesnt trigger
  • 706 Answers
Hello latino,
If your problem has just started to happen ( meaning that it worked ok until recently) .. your circuit breaker itself may be starting to fail. They do have a finite life expectancy and over time, you may experience nuiscance trips. Another consideration is that the wiring coming from the circuit breaker up to the receptacle that feeds power to the dryer may have loosened up at the connection points and when that happens, those connections points become resistive and cause the dryer to require more current to maintain the same power..By requiring more current, you may be exceeding the rating of the breaker.. so those are a few things to check..
If I were there, the first thing I would do is shut off that breaker and open the circuit breaker panel ..make sure the screws that hold the wires to the circuit breaker are snug.. then close that up.. and do the same thing at the dryers receptacle on the wall and the termination points inside the dryer where the power cord connects. After that, I would reapply power and see if the problem persists.. If it does, I would remove and replace the circuit breaker.
One last thing to check might be the drag on the dryer drum.. make sure it isn't binding and requiring the drive motor to work harder ( which means more power demand) to rotate the clothes..
Those are a few areas to investigate.. Hope that helps
Regards,
Rick
Posted on Dec 06, 2008
  • Rick Gelin
    Rick Gelin Dec 06, 2008
    Hi latino,
    I had anotehr thought.. Are you referring to your house main breaker? If so and you aren't referring to the dryer breaker then I'd like to offer a some other ideas.. If your main breaker is tripping and that is happening when you are running your electric dryer and it did not happen previously, did you add any electrical appliances or anything that wasn't powered prior to this problem? The main breaker feeds all of the branch circuits in your house and it is possible that you added some other appliance or electrical load on one outlet and when you put your dryer on.. it exceeds that breakers trip point. If you are sure you haven't added anything else that requires power.. the same scenario could be happening.. The wires on all breakers should be torqued down at the breakers.. The main breaker itself may be going bad.. or you have added more equipment ( loads) in your house that is causing that breaker to trip when you add in the dryers power requirements. I suggest that if you aren't an electrician, you contact one to identify the problem and address it.. You may need a component of service upgrade..
    Regards,
    Rick
  • Rick Gelin
    Then my follow up comments are more appropriate .. You may want to shut off a few electrical appliances.. and cycle the dryer to see if the total sum of all electrical appliances ( loads) is not exceeding the rating on your main breaker. If you can shut off a few things and run the dryer for a while and it doesn't trip the main, you may have loose terminations on the main breaker, a main breaker that is starting to fail and needs replacement.. or house service needs to be upgraded to provide power for your existing power requirements.. An electrician may be required if you aren't trained in this area.. Good Luck..
    Regards,
    Rick
At end of washing machine fast spin the machine trips my electricity circuit and TV switches off along with other appliances. Can you tell me what's wrong with machine?
This tells me that you do not have an overload situation. There is a short, and/or one or more faulty breakers possibly including the main breaker.
Even an experienced DIY'er with electrical knowledge would probably contact an electrician at this point. If there is a potential problem with the main breaker then it is best to get professional help.
Why is my electric circuit breaker tripping
Common Causes for Tripped Circuit Breakers
Why Does My Circuit Breaker Keep Tripping
Jul 02, 2015 | Washing Machines
Outside main 100 amp breaker is tripping but none of the inside breakers, supposedly when dryer and tv on together but not all the time
Am I to assume your dryer is electrical? If so, I'll guarentee it will draw MORE than 14 Amps if heating. Sorry, can't analyze your problem from here.
May 01, 2014 | Cutler Hammer 100 Amp Main Breaker...
MY OLD GE ELECTRIC DRYER TURNS ON BUT WILL NOT HEAT
Make sure you check these to fix the problem.
  • Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
  • Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
  • A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Thank you
Aug 02, 2010 | GE Profile Harmony DPGT750EC Electric...
My Maytag Bravo Steam Dryer runs for about 5 minutes and gets hot and then kicks the breaker in the breaker box. HELP!!
Hello there:
It blows fuses or trips the circuit breaker Electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring. To decide where the problem lies, unplug the dryer, then:It could be also wired backwardes so make sure to have this checked'
If the circuit breakers or fuses remain on and/or intact when the dryer is unplugged, it's likely the problem is with the dryer. Contact a qualified appliance repair technician. If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box.
May 21, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Have a dedicater 220v 20a circut break to a clothes dryer. The only work done but the electrician was a new main grounding wire and removed conduit and wiring in the basement. Now the breaker opens after 1...
Typically, a standard electric dryer is 30A 240V unless it is natural gas. If the wire is #10awg then you can put a 30A circuit breaker on it. If the wire is #12awg then you DO NOT want to put a larger circuit breaker on it or it over heat the wiring in the wall. If it was a short in the wiring the circuit breaker would trip immediately even with out the dryer plugged in. If it was a grounding problem the circuit breaker would not trip at all, it would just electrify the dryer chasis. It sounds like it is an over current problem, drawing more than 20 amps through the circuit breaker, or like the dryer has an internal problem that is causing the circuit breaker to trip.
Nov 21, 2009 | Gb Electrical 100 Amp GE Load Center
The WHIRLPOOL TEDS840PQ0 dryer wont turn on. The
Check the house electrical panel dryer circuit breaker pair--push off, then on. Try the dryer again. If still nothing, measure the voltage across the two slanted slots in the dryer power socket. It should measure: ~230 volts AC. If at or near zero, either one of the breaker pair is defective, or a wire is open from the breaker to the socket. If you read ~230 volts, then the problem is within the dryer--motor runs, but drum doesn't turn (broken belt), or motor doesn't run (bad controller, motor, door switch, start switch. Does the unit get hot? Need more help on your end.
Oct 18, 2009 | Estate TEDS840JQ Electric Dryer
Dryer takes too long to dry clothers and yes I cleaned all the vents and there is no clog or stoppage in vents
Hope this info helps, ps don't forget to give me a rating thanks!!
For an electric dryer that runs but doesn’t heat, follow this repair roadmap:
Flip the circuit breaker off and then back on. Electric dryers run on a two-pole, 240v breaker. A common problem is for one of the legs to break which cuts the 240v that the elements need to heat up but it still supplies the 120v for the motor. The result is that the dryer runs but doesn’t heat.
If the breaker checks out, then it’s time to do some surgery. Unplug the dryer and open it up.
. Use your ohm meter to test the thermostats. All should show continuity.
Measure the resistance of the heating element with your ohm meter. Normal readings are in the neighborhood of 30 ohms.
In rare cases, the centrifugal switch in the motor can fail which breaks the power circuit for the heating elements. If this is the case, then the entire motor must be replaced since the centrifugal switch is built into the motor.
May 06, 2009 | Estate TEDS740JQ Electric Dryer
Whirlpool electric dryer keeps tripping main circuit breaker
First off, be sure the pigtail is wired correctly to the back of the unit. Black and red to the outside terminals, white to the middle, green to the frame or cabinet (should be a green screw close-by). If that is ok, you probably have an issue with possibly a bad pigtail, bad outlet, wiring issue, or possibly a bad circuit breaker or breaker box. Probably going to be more of a electrical problem than a appliance problem. Good Luck!!!!
Feb 02, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
981 people viewed this question
Top Dryers Experts
