Question about ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
1gb DDR 400 not recognized
I'm trying to upgrade my ASUS A7V8X-X motherboard from 768MB of ram 50 over 1 gig. It currently has 3 sticks of 2356mb PC2700. I bought a signle stick of 1gb PC3200. It will not recognixe. I'm running XP. Any ideas?
  • 837 Answers
That board needs to have minimally memory in pairs .. get another 1Gb stick
Posted on Dec 06, 2008
Problem with upgrading ram on Asrock 775i65G Motherboard
Hello download the manual here:
http://www.asrock.com/mb/Intel/775i65G/?cat=Manual
It explains the problem.
You will need adobe reader, to read content.
Good luck
Feb 01, 2013 | Asrock 775i65G Motherboard
A7v8x-mx 2GB (2x 1GB) don't recognize
Sounds like you have run into a compatibility problem between your RAM and motherboard. These kinds of problems have been very common and that is why most motherboards have a supported memory list. Usually if the RAM does not work properly you can try reversing the slots that they are plugged into and make sure that your motherboard is set for the proper voltage and speed for the RAM. If it still does not work then you would most likely need either different RAM or a different motherboard.
Feb 17, 2012 | ASUS A7V8X-MX Motherboard
Cpu speed for ddr 400 ram
cpu speed has nothing to do with ram. they are completely independant. ram speed is important to the FSB (front serial bus) this is the speed at which your motherboard communicates with the devives attached to it. cpu speed refers to how fast a cpu can process info. or how fast it "thinks". most motherboards have the capability of upgrading cpu's. your mobo (motherboard will support the following cpu's:
any pentium 4 up to 3.0 ghz
it supports the following ram
ddr (nott ddr 2 or 3) up to 2 gigs (1 gig each slot) of 533mhz speed (or less)
it also supports up to 2 gigs of sdram either pc133 or pc100
you are using 400 speed ram as you stated i would upgrade to a 533 speed ram as it will be faster, but this is not necessary. as for the cpu just get any P4 (pentium 4) that is 3.0 ghz or less and it will work.
Jun 27, 2010 | ASUS P4S533-MX Motherboard
I have an asus k8v-mx motherboard running only 512 mb of ram what type of ram would suit this mother board and could i fit a 1 x 2mb ram instead of 2 x 1mb?
Dear Sir,
*********** board is Asus old p4 Mother board.It supports maximum 1GB RAM of DDR 400(DDR1). According to your post your computer having only one 512 MB working RAM. If you want good purformance you can upgrade your computer by purchasing another 512MB DDR400 RAM and install it on another RAM slot.If your computer have only one working RAM slot,you can purchase 1GB DDR400 RAM & install it on older RAM place. I think it solves your problem.if you have any problem come back with more information. I will try to assist you more accurately.
good luck
Aug 05, 2009 | ASUS K8V-MX Motherboard
Asus p5 vdc-x motherboard not recognizing ddr2
HI it sounds like a speed issue,check your
motherboard info for support or if you
have no manual download it from asus site
check for ddr2 support via the manual
regards john sykes
Jun 30, 2009 | ASUS Computers & Internet
Use of DDR2 RAM in ASUS MOTHER BOARD
This motherboard only support DDR type of RAM up to 4GIG , 400 MHz • 333 MHz this are the support speed of DDR RAM, so you can go ahead upgrade up to 4 GIG of RAM and that will make your computer very fast...
Nov 04, 2008 | ASUS GeForce® 4 V9180SE MX 440, AGP...
Its about the memory card
The board supports upto 4 GB RAM. PC3200 RAM is supported.
1. Reset CMOS settings by CMOS jumper.
2. Try updating BIOS of your motherboard from :
http://support.asus.com/download/download_item.aspx?product=1&model=P5GL-MX
Best of Luck,
rajesh_im
Feb 13, 2008 | ASUS P5GL-MX Motherboard
High density memory
need low densisty on ebay 35 buck eash 1 gb ok works on picky mobos way better
Feb 07, 2008 | Dell (E210882) Motherboard
Type of memory for e210882 motherboard
the memory you're about to purchase will not work. the maximum gig that the computer can handle per stick is only 1 gig. this system is not designed for 4 gig barrier.
hope this helps.
thanks.
Feb 05, 2008 | Dell (E210882) Motherboard
Asus A7V8X 1 gb sim
Have you tried the 1gb in the motherboard on its own but in different slots. i.e try slot 1 then slot 2 then slot 3 and see if you still get beeps.
Aug 23, 2007 | Abit BL7-RAID Motherboard
ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard Logo
135 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
