Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
When i plug the flash drive into my computer, it does not show up under my computer, but the safely remove hardware icon shows up on my taskbar.
  • 1 more comment
  • marlenemagee Dec 07, 2008
    My cruzer 4GB is not being read by any computer.
    marlenemagee@yahoo.com
  • Larry Dec 08, 2008
    I have a 4G Cruzer Micro and it cannot be installed or recognized as anything. It shows up in my device mgr as Other Hardware with an ! by it. I have tried everything. I am running Windows XP SP3.
  • dark_mouse Apr 13, 2009
    I have Windows XP. I placed the cruzer in the USB socket and it loaded
    the driver. The U3 stuff works fine (didn't want that). Wghen I removed
    the U3 software the drive disappeared. I cannot use it for disk storage
    as it is not in 'My Computer'. It is in disk management as drive E and
    everything says the device is 'working properly'. The light is on and
    staring, if not mocking, me now. I have tried other USB ports and it
    works on my laptop (XP).
    I have checked everything that's on the
    Scandisk website FAQ. It seems that there is an issue with my computer
    but I don't know what it is. The computer is running 2 hard drives and
    2 cd roms and one floppy disk. It's about 4 years old but the USB ports
    are the right ones (2.0) and it's running Service Pack 2.
  • 827 Answers
Try downloading the U3 driver, if you haven't already.
First plugin the sandisk to your usb port, and then check from Windows Explorer, does your sandisk cruzer detected? you'll get a new drive letter besides your local drive or named "removable disk".
If you do see it then just do format (you'll lose the U3), copy, store, overwrite it again and again as you like.
If you still need the U3 application, pls read this:
http://www.u3.com/support/default.aspx#CQ1
You possibly haven't installed the driver properly.
If a wizard that comes up as soon as you plug the device in, Just let it detect the device and then go to Control Panel, and System, and Device Manager, and double click on the device driver, or if it isn't there, double click on the unknown device with the yellow exclamation mark and hit the Driver tab, Install Driver, and choose the 'Let me choose the driver' option, and navigate to where you unzipped that driver you downloaded to, and click on the driver, wait for it to finish installing and reboot.
Let me know how you get on..
Good Luck!
Chris (ziraffa)
Posted on Dec 26, 2008
16gb pendrive
Which operating system ?
It's always a good practice to safely remove your USB flash drive before unplugging it from your computer.
This prevents data loss and extends the life of your external storage device.
Removing a flash drive from your computer is very easy and doesn't take a long time to do.
Close all files you accessed from the flash drive.
This is necessary for the device to be removed properly.
Don't forget to save your files before closing the files.
Right-click the "USB" icon marked with a checkmark.
It is located on the bottom right of your taskbar.
From the pop-up menu, click "Safely Remove Hardware."
A small window will be displayed.
Select the USB flash drive you want to unplug then click the "Stop" button.
A confirmation window will appear. Click the appropriate hardware device, then click "OK."
The "Safe to Remove Hardware" window will inform you that it's now safe to unplug the USB flash drive from your computer.
Click "OK," then click "Close."
or
Click start all programs accessories windows explorer navigate to your usb drive right click on it select remove or exit.
Jul 27, 2013 | SanDisk Computers & Internet
How do I disconnect (uninstall) a WD External Hard Drive from my computer? I am using a WD 3200AAK WD External Hard Drive and want to install a 1 TB WD External Hard Drive. I would like to use the old one...
External hard drives don't need any program installed on your computer to run. Your operating system Windows, Linux should handle it as soon as you plug the usb in your computer. The programs included in your WD external hard drive are tools to backup your data.
If you try to hook up your hard drive to a Windows prior to XP, maybe your computer will not handle it.
It is always safer to safely remove your drive using the green arrow icon in the lower right corner of your screen. This way, the drive is shut down properly and you minimize chances of fails when you plug it again on another computer.
Hope this helps!
Feb 08, 2011 | Western Digital My Book Essential Edition...
Please can you send me detailed instructions on how to use a kingston usb memory stick
The memory stick becomes another drive, when plugged into the USB port. Some sticks have a write protect, which is a teeny tiny switch. If the switch is in the protect position, you can read but not write any data to the drive. Often the drive will be listed after all of your camera card ports.
To view the drive press and hold the Windows key and press the letter E. and then release both. The available drives should show up there.
Nov 17, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
When hd is plugged in, it installs device and drivers automatically. it never shows up under my computer but in the taskbar it shows safely remove hardware. power light shows orange but harddrive light...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Let me know if you need further assistance. Thanks for using FixYa
Nov 14, 2010 | Seagate (9W2063500) 120 GB Hard Drive
Using the jump drive device
no it shouldn't crash. you can just pull it out but i guess the "proper" way is to go to MyPC right click it and click eject
Feb 25, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I have a kingston data traveler 2gb DTI. i was copying movie files to my data traveler and it removed the volume label and i am not able to change it back. now I am not able to access any files. it does...
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
Feb 23, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Pen drive is not working
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove Hardware icon and then click on USB flash drive you want to remove)
Dec 14, 2009 | Kingston Technologies 512MB DataTraveler I...
A-data usb flash drive(no disk)
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
Jun 29, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Pleomax problem
Try clicking on the icon in the taskbar and if it's like SanDisk flash drives there is a program you need to install from the Pleomax itself, that enables it and several tools as well. When you see that window, there will more than likely be an eject button as well.
Mar 16, 2008 | Samsung Pleomax Zirex UHD-8G USB Hard...
External hard drive
Try these steps: - Right-click on "My Computer" - Click "Manage" - Click on the "Disk Management" icon in the left column (Under the "Storage" category" - If your disk appears on the right-hand side, then try to right-click on it and create a partition. The issue may just be that, since the disk is not partitioned/formatted, a drive letter has not been assigned, which would cause it to not show up in the "My Computer" list Good luck!
Oct 06, 2007 | Western Digital My Book Essential Edition...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
235 people viewed this question
Top SanDisk Computers & Internet Experts
Brian Sullivan
Brian Sullivan
laikexpert
laikexpert
CiNi
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
