Question about Acer Aspire 5500 5570-2609 Laptop
Computer can't find USB drive
Same problem as earlier today with the DVD drive.
Why won't Xbox update?
To resolve this problem, try the following solutions.
Solution 1: Check your Xbox Live connection
If you're having problems connecting or staying connected to Xbox Live, see I get an error message when I test my Xbox Live connection.
If you still experience the problem, try the next solution.
Solution 2: Clear the system cache
Removing the temporary files on your console might solve the problem. Follow the instructions at How to clear your Xbox 360 system cache. Then, try downloading the update again.
Solution 3: Copy the update to a USB flash drive, CD or DVD
Copy the console update from your computer to a USB flash drive, CD or DVD, and then install the update on your console. Here's how:
Copy to a USB flash drive
Note The USB flash drive must use the FAT32 file system.
  1. Plug your USB flash drive into a USB port on your computer.
  2. Download the update file.
  3. Click Save to save the console update .zip file to your computer.
  4. Unzip the file:
  • If you are using Windows XP, Windows Vista or Windows 7, double-click the .zip file to unzip it.
  • If you are using an earlier version of Windows, you need to use a special software program to unzip the file (for example, WinZip).
  1. Copy the contents of the .zip file to the root directory of your USB flash drive.
  2. Unplug the USB flash drive from your computer.
  3. Plug the USB flash drive into a USB port on your Xbox 360 console.
  4. Restart the console.
  5. When the console restarts, the installation program starts automatically. Select Yes when you are prompted to update the new console software.
Burn to CD or DVD
You can also download the update to your computer, burn the update to a CD or DVD, and then install the update on your console. Here's how:
  1. On your computer, download the update file.
  2. Click Save to save the console update .zip file to your computer.
  3. Unzip the file:
  1. Insert a blank, writeable CD or DVD into your computer.
  2. Copy the contents of the .zip file to the root directory on your CD or DVD, and choose to write (burn) the files to the disc.
  3. Once the files have been burned to disc, remove that disc from your computer and insert it into the disc drive on your Xbox 360 console.
Dec 15, 2013 | Microsoft Xbox 360 Console
I have Lenovo Ideapad S10-3s. I have changed the OS to WinXP SP3 from the earlier Win7 Starter. The whole thing is working fine. My External DVD burner i.e., Lenovo GP20N (suitable for Ideapad S10-3s) also...
Hi wsmurty,
I see that you are having issues regarding your External DVD drive, you also mentioned that the Operating system was down graded to WinXP SP3 from Win7 Starter.
  • If this only happen just a day ago or possibly just hours ago you can try doing a system restore on the machine, restore to an earlier date at least a day or two from the day that the DVD drive was not dected on the machine. if this does not work then try the steps below.
  • Check Device manager to see if there are any drivers that you may have missed out for the Lenovo System.
  • Possible Drivers that can cause your USB's not to detect the External DVD drive will be the chipset drivers.
  • Second Driver is the driver for your External DVD drive see if it is up to date or possible that it may needs updating on the case.
  • Is the External DVD detected in My Computer? If it is then Uninstalling and reinstalling the driver for your External DVD drive can be done just to check then update the driver for it if possible from the manufacturers website.
I hope that this helps.
Have a nice day,
mvincentc
Apr 27, 2011 | Lenovo Portable DVD Burner GP20N WHTWGB...
My Verbatim Model #47512 1TB is showing as "Unknown" when connecting to the Computer. It was working earlier today but I removed it and then connected it again and now it's not working.. It's...
An external hard drive is a normal hard drive with a converter to change it to USB.
If you have important information on it, you could open it up, and connect internally to your computer, however, opening it will (almost always) void the warranty.
I'd recommend contacting whoever sold it to you, and asking them: 1) If you can open it up, to connect it internally, to get your data off, and 2) For a replacement.
Good luck with it.
Dec 22, 2010 | Verbatim 500GB USB Desktop 500 GB Hard...
My girl took pics of wedding Saturday and viewed pics earlier today. When she went to look at them again, a message " Disc in Drive E is not formatted. Do you want to format disc now?" Of...
do not format -- you will lose the pictures
instead go to another computer that supports SD memory and CDRW. insert into that computer and then take all the PICS, save into that computer. now take a blank CD and take the saved PICs and burn into CD.
Also, to ensure you dont lose these pictures (PICs) you may want to buy a 4G or 8G USB thumb drive (about $10-$15 or less) -- drag and drop all the PICs (saved on that computer) into the USB thumb drive. Now you have on CD and USB drive.
hope this helps
Nov 14, 2010 | SanDisk 2GB microSD Memory Card
DVD ROM DOES NOT RECOGNIZE BURNABLE DISK IN DRIVE
I decided earlier today not even to bother with bad mannered people who use caps.
Jul 29, 2009 | TDK Indi DVD 420N (AID+420N) DVD+RW Burner
Power calibration error
change the cables of dvd drive, also check power
Sep 28, 2008 | Imation 16575 2.4x DVD+RW Storage Media
I got a new computer and downloaded the new windows vista updates and it made is so i cant see my cd/dvd rom drive in my computer settings and it doesnt read discs.
try to do system restore, go to start search,type system restore,choose "restore computer to earlier time" choose a date before today.
Aug 03, 2008 | Computers & Internet
Seagate external Harddrive
I would suggest to take it to a computer repair shop to get it open.
You can also try to open it using a flat head screwdriver and locate where the locking tabs are on the hard drive enclosure.
Let me know if you need further assistance.
Apr 11, 2008 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Acer Aspire 5500 5570-2609 Laptop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
