Question about HP PSC 2410 All-In-One InkJet Printer
Printer won't print following brief power outage
Following a brief power outage, the printer will not print. the hour glass is constaintly on and the machine is making a zip zip zip noise at about 1 cycle per second. there are not paper jams. on opening the front cover, i find the printer cartiages are partially down and in such a position that they can not travel along the slide bar to the left.
usually after moving the cartigages along this bar, turing everything off and wating all nite, all works fine again next morning once all is powered up..
one propose solution was to greeze the slide bar.........this doesn't sound like a good idea to me. I have the same problem. How do I slide the bar to the left? Do I need the special bit to unscrew the top?
  • 837 Answers
You may have unfortunately gotten a spike that has affected this printer.
But make sure all print jobs are removed from the print queue.
Shut down computer and printer
Wait 5 mins
Turn printer on
Power up computer.
Check print queue again .. try to print
Let me know
Posted on Dec 06, 2008
  • Jay Glendenning
    Jay Glendenning Dec 06, 2008
    You may be stuck buying a new printer though .. Another thought .. USB connection? Possibly the PC suffered damage
Unsupported ink cartridge after power outage
(1) Open the printer and wait for the carriage to slide over. If for some reason it does not follow these instructions:
(a) Unplug the printer
(b) Manually slide the carriage over until you can get the ink cartridges out.
(2) Remove the ink cartridges from the print head.
(3) Use cotton swabs dipped in hot water or a mix of hot water and isopropyl alcohol to thoroughly clean the print head.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now
If that does not work then you have one of two possibilities:
(1) One of the ink cartridges is defective and causing the error
(2) If it's definitely not that, then the print head will need to be replaced.
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For Canon Printer Support
Mar 18, 2014 | Canon PIXMA Office Equipment & Supplies
My konica bizhub c550 does not go past the hour glass when powered on, how can I fix this please?
Something maybe mechanically stuck. The printer is expecting something to happen which is failing to happen. Maybe the carrage has to go to one end then back again when you turn on.
Nov 15, 2013 | Konica Minolta Bizhub C550
Dell Dimension 4550 and HP printer 2410. Everytime computer is turned on, it detects new hardware and reinstalls the printer, and repeats the process again. After that, the printer seems to work OK.
disconnect the printer, go into device manager and delete all the printers listed there. go onto the printer manufacturer website and download the drivers manually then install them. Hook the printer back up.
Aug 25, 2012 | Dell Computers & Internet
After a brief power surge our Vingcard 2800 stopped encoding, what do I need to do to fix?
WE HAVE POWER OUTAGE FOR 1/2 HOUR AND THEN AFTER WE TRY TO RESET OUR VINGCARD 2800 AND FOUND BLACKOUT ON SCREEN. WE CAN SEE, IF U TRY FROM ONE SIDE UNDER THE KNEE.
Aug 14, 2012 | Office Equipment & Supplies
After a brief power outage during a thunderstorm my canon i9900 will not turn on. I left it un pluged for several hours and then repluged it and still nothing. Everything else in the office works fine.
The power supply of your printer are damage due to the brief power output during the thunderstorm. Just check the fuse inside of the power supply of the printer if they have some burned or else use the Multi Tester to identify that the fuse are damage or needed for replacement.
Jun 03, 2010 | Canon i9900 InkJet Photo Printer
We had a brief power outage--now prinker knunks
In all probability that Power Outage caused a massive Spike or Surge on your power line. This has affected this unit. It doesn't take much to cause this type of thing and is quite common. It may be repairable, however these days buying a new one is often a better option. If you do go the repair route, go to a reputable place, & please ensure you get a firm "Quote" not an "Estimate" for repair.
Jan 20, 2010 | HP Photosmart 2410 All-In-One InkJet...
After a brief power outage, our Wii will not turn on.
It probly short circuted or somthing..Unplug it w8 a couple hours then plug it back in and try again..it might not work ever again if it was turned on durring the power outage
Nov 07, 2009 | Nintendo Wii Console
Trouble following brief power outage
apply any greese material like vaseline on the steel rod on which the cartridge carriage moves.if that rod is become rusty the carriage sometimes cannot move freely on it and this happens,
Nov 14, 2008 | HP PSC 2410 All-In-One InkJet Printer
HP Photosmart 2410
por favor me pueden ayudar con los drivers de esta impresora les quedare eternamente agradecidos mi correo es dismanort@hotmail.com
Jun 02, 2008 | HP Photosmart 2410 All-In-One InkJet...
FO 2850 - Power Outage Aftermath
Unplug the machine for 4 hours & then plug back in. If you get the same symptoms, it will be cheaper to replace with a new one. Power supply is probably blown.
Jul 01, 2007 | Sharp FO 2950 Plain Paper Laser Fax
HP PSC 2410 All-In-One InkJet Printer Logo
26 people viewed this question
Ben Johnson
