Question about Garden
Where is the fuses in a daewoo solar 030 mini digger
The lights are not working and i think it is fuse. but can find it look all over it .
3 Suggested Answers
SOURCE: JCB 801.4 mini digger - no control of digger arm
We have a similar problem on a Mitsubishi MM55SR.
We developed a new control set-up
Posted on Aug 07, 2009
simontricket
  • 235 Answers
SOURCE: how do i replace a track seal in my mini digger.
Slack off the track adjuster valve, spin the track off and pull out the idler assy. The seal is on the end of the chrome  piston just pull it out .
Posted on Dec 31, 2009
Where is the interior fuse for 2001 Daewoo Leganza. interior light is not working
Fuse is in fuse box under the hood to the rear of the windshield washer reservoir. It is marked EF-29 but first check to see if dome light switch is set in the center mark, ie. on/door/off. 'On' is always on, 'off' is always off, 'door' is light on when door opened. Also, bulb may be shot.
Jan 29, 2012 | 2001 Daewoo Leganza
Were is my brake fuse located on my 2001 daewoo
I'm guessing you are talking about the brake lights. That fuse is in the fuse panel under the hood of the vehicle in the engine compartment. Below is a diagram of the fuse layout and have marked the fuse with an arrow that you want to check. It should be a 20 amp fuse. Hope thsi helps....
Jan 24, 2012 | 2001 Daewoo Leganza
I have an over the range DAEWOO MT1510W Microwave i think the fuse blowed my manual doesn't show where it located at
The fuse probably is internal. It may be necessary to remove your OTR microwave to get access inside.
Jan 13, 2012 | Daewoo Microwave Ovens
I have a 2000 Daewoo Lanos hatchback. All the turn signals quit working last weekend but all other lights work. I suspect I have a bad fuse. What fuse do I need to replace and where is it located?
since the tail lamps and brake lamps work it will not be a fuse
the directional switch incorporated inside the steering column needs to be checked
Aug 20, 2011 | 2000 Daewoo Lanos
My daewoo won't go out of park unless you have another key in this safety thing by the shifts. It is also making my break lights not work.
im not sure on these, but i know on ford if your brake lights fuse or brake switch is bad it wont let you shift out of park, try checking your fuse that operates the brake lights in the fuse panel on the inside of the car on the driver side. hope this helps
Feb 11, 2011 | 2001 Daewoo Leganza
Need installation instructions for aerosharp HR-INV-XOI-030 solar inverter
My HR-INV-X01 PV Invertor LCD Display has nothing. No power, run or fault lights however the blue safty switches note ON. What could be the problem?
Jan 07, 2011 | Solar Grid-tie Budget Package: Panels,...
Where is the fuse panel on a 2000 daewoo leganza, interior dome light does not work
Check the light first. remove the plastic cover and twist the bulb in its socket. Sometimes they get corrosion. The fuse box is under the dash on the left side, little slide out door conceals the fuses. there is a diagram of fuses on the panel door your slid off.
Dec 31, 2009 | 2000 Daewoo Leganza
Daewoo Microwave KOG 867 T9-DEAD??
There could be a main fuse inside the unit. Mine has one that is ceramic, sort of like the old glass car fuses but ceramic instead of glass. Digi-Key has all kinds of fuses, www.digikey.com.
Aug 03, 2009 | Daewoo KOG-867T Microwave Oven
Need to get code for 3-1 remote # 1519001
TV Brand 3-in-1 Code Radio Shack Cat. No.
Akai 098
Anam 068, 180
Anam National 055, 161
AOC 019, 030, 052, 137
Candle 030, 046, 056, 186
Capehart 052
Citizen 030, 039, 046, 056, 060, 092,
186
Concerto 056
Contec 158, 180, 185
Craig 161, 180
Crown 039
Curtis Mathes 030, 039, 060
CXC 180
Daewoo 019, 039, 091, 092
Daytron 039
Electrohome 039
Emerson 039, 158, 177, 178, 179, 180,
181, 182, 183, 185, 236, 270,
280, 282
Envision 030
Fisher 154, 159
Fortress 093
Fujitsu 179
Funai 179, 180
Futuretech 180
GE 021, 027, 029, 047, 051, 055,
174, 178, 282
Goldstar 001,019, 039,056, 106, 178
Hallmark 178
Hitachi 038, 039, 056, 095, 097, 145,
151, 173, 227
Infinity 054
JBL 054
JVC 053, 169
Kenwood 030
Kloss 046
Kloss Novabeam 024
KMC 106
KTV 039, 180, 280
Logik 016
Luxman 056
LXI 047, 054, 148,154, 156
Magnavox 020, 024, 028, 030, 054,
096, 186, 187
Marantz 030, 054
Memorex 016
154 16-229
178 16-254
16-263
16-280
MGA 019, 030, 150, 155, 178
Mitsubishi 019, 098, 155, 178
Mitsubishi Unified 150
MTC 019, 030, 056, 060, 091
Multitech 217
NAD 156, 166
NEC 019, 056, 170
NEC Unified 030
Onwa 180
Optonica 093, 165
Panasonic 051, 054, 055, 162
Penney 018, 019, 021, 030, 039, 047,
060, 135, 149, 019, 020, 024,
028, 030, 054, 186, 187
Phillips 000, 054
Pioneer 038, 166
i think this will help you a lot.
Aug 03, 2009 | Televison & Video
2002 Daewoo Leganza all four windows stopped working
try looking under the bonnet for a big 50 or 80 amp fuse ,should be near the battery
Apr 25, 2009 | 2000 Daewoo Leganza
Garden Logo
103 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
