Question about Sony Handycam DCR-HC30E Mini DV Digital Camcorder
Trouble recording to DV Tape
I am having trouble recording to, and playing from the DV Tape. I have successfully recorded to the MemoryStick more than once. I can also hear the mechanical mechanisms working while recording/playing, including the sound of FW/REV, so it seems that the those are not culprits. I saw a message regarding cleaing the head just once, but it never came on again. Any help on this would be appreciated.
  • Islam Tawfik Apr 23, 2007
    Apri,
    I'd actually already done that, and it worked... but thanx for the input, after all you are the only one who showed interest in this issue!
    Also the tape itself was damaged, that helped fix the problem.
    Sergeant:
    Champion:
  • 326 Answers
Hello, cleaning the head and the tape path with cleaning tape is a good idea. Try it! If the cleaning does not help the video head is damaged. If you need more info please advice.
Posted on Apr 11, 2007
After recording and replaying, the picture is "sliced up". I've tried cleaning head with dry tape, seemed to help but still there. Trouble is it seems to vary each time I play the same tape.
Do not use a head cleaner - they can damage the heads. Insert a brand new high quality tape and perform a record. Let it record through the entire tape. Then, play back an original prerecorded tape and check playback.
Nov 15, 2010 | Canon GL1 Mini DV Digital Camcorder
Sony dv premium ME DVM60 Mini DV tape. How many times(hr) to use
Recommend contacting your local service provider directly or online here:
Contact Us
Jul 29, 2017 | Canon Sony DVM-60 Min. miniDV tape - 6Pack...
Recording onto a mini dv tape from Mac computer Via firewire
I have successfully recorded to a mini Dv tape from my computer however I connected my PC to the VX2100 using the RCA inputs. I have an adapter that I purchased from best buy that provides the RCA input/output. If your able to connect that make sure to...
1. Turn you VX2100 to Play/Edit mode (not camera mode)
2. Insure the program on your mac has an external output otherwise you won't be able to record.
3. See if your video editing software (if your using one) has an option for record to tape or to camera. I use Vegas Studio and it has an option for that.
Hope this helps. Good Luck!
Jun 23, 2009 | Sony Handycam DCR-VX2100 Mini DV Digital...
DVD to mini DV tranfer
Only way is Play burned DVD in dvd player and provide Audio- Video out (yellow-red-white) to mini DV camera that has AV Line Input recording facility. Or find any Mini DV recorder and record tape.
In that way you can record video again on Mini DV tape.
Apr 24, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Trouble recording to DVD - connections are not done right - Sharp DVD-RW340
I had to run from the RCA outs of my DVR into the inputs that are on the front right of the RW340...behind the little door.  Now I can easily record from live cable or from my Comcast DVR recorder.  Couldn't get it to work from the backside inputs.
Mine is just the DV RW340 (no U).  And yes, the manual is brutal.  We had to call tech support to find what disc will actually work in the darned thing.
Now my big problem is finding more 4x DV-R disks. Shoulda bought more when Comp USA was clearing them out a few years ago!
I have had great success with Dynex Model: DX-DVD-R25 discs.  And they play equally nicely on my Toshiba DVD player in the livingroom.   I have also given several away to people after I had transfered home videos to DVD and those people all had good results playing the discs that I made on my lowly Sharp Dv-RW340.
Sep 13, 2008 | Sharp DV-RW340U DVD Recorder/VCR
Sharp dv-rw260h vcr/dvd combi
The tape drive and head cylinder motors are having trouble synchronizing close enough to allow the manual tracking to work. Does it work on prerecorded tapes?
Could be:
Too much drag from the tensioning gizmo. (fixable)
Dirty tape path (fixable)
Damaged tape (does it have a crease along one edge?
dragging motor (not usually fixable)
Hope Ya Fix It!
Jan 17, 2008 | Televison & Video
Get Final Cut Pro 5.04 to communicate with my XH A1
Many HDV cameras and decks are able to play and record DV as well as the higher-resolution HDV format. Additionally, many of these HDV devices will attempt to automatically change their settings to match the format of the tape that it's playing. Here are some tips for using these types of devices with Final Cut Pro / Final Cut Express.
Tip: Make explicit settings on your HDV device. Instead of using an "Auto" setting, make your own settings on your HDV device to keep the communication going between it and Final Cut Pro / Final Cut Express. This also helps Final Cut Pro / Final Cut Express keep things running smoothly with HDV devices that handle both DV-NTSC and DV-PAL.
For example, say you're using an HDV deck to capture footage from a tape that was recorded as DV-NTSC. Before capturing in Final Cut Pro / Final Cut Express, make sure that you set the deck to DV mode specifically—don't rely on Auto mode. With some devices, you may need to disconnect it from FireWire to change the mode.
For a common capture workflow, this sequence of steps can provide the best results:
  1. Quit Final Cut Pro / Final Cut Express if it's open.
  2. Insert your tape into your HDV deck or camcorder.
  3. Use the device's menus to set it to match the format that's recorded on the tape.
  4. Connect your HDV device to your computer with a FireWire cable.
  5. Open Final Cut Pro / Final Cut Express.
  6. Choose an Easy Setup for DV or HDV (whichever matches the format recorded on your tape).
  7. Proceed to Log and Capture.
Tip: Quit Final Cut Pro / Final Cut Express before changing modes. It's generally a good idea to quit Final Cut Pro / Final Cut Express before you change the mode on your device from DV to HDV, or from HDV to DV, and then re-open the application again.
Tip: Use an Easy Setup to play back non-default HDV format footage on your HDV device. You can use Final Cut Pro / Final Cut Express to make your HDV device play back footage in its non-default HDV format. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as 1080i50. Or perhaps you have a 1808i50 HDV device and you want to play back footage that was recorded as 1080i60. To do this, follow these steps:
  1. Connect your camera to your computer.
  2. In Final Cut Pro / Final Cut Express, choose an HDV preset Easy Setup that matches the format of the tape's footage (you don't need to restart Final Cut Pro / Final Cut Express).
  3. Your device's LCD display should automatically display a switch to 60 or 50, indicating the type of media that's being played.
Playing back non-default DV format footage on your HDV device You can also use your HDV device to play back footage in its non-default DV format too. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as DV-PAL. Or maybe you have a 1080i50 HDV device and want to play back footage that was recorded as DV-NTSC. If so, follow these steps:
  1. Make sure that your device is in DV/DVCAM mode.
  2. Put your device into Play/Pause mode, then open the Log and Capture window in Final Cut Pro / Final Cut Express.
  3. Make sure that your device's LCD (or other readout screen) displays the same format as your tape or Final Cut Pro / Final Cut Express will misinterpret what type of device you have.
Tip: Avoid recording both HDV and DV formats on the same tape. Use separate tapes whenever you want to record in a different format. If you need to record over existing footage in a different format (for example, you have a tape with DV-PAL on it, but you want to record over it with HDV 1080i50), it's a good idea to black and code the tape, or completely record over the old footage with contiguous recording in the new format. If the tape contains even a second of, say, DV in the middle of an HDV tape (or vice versa), it could cause unexpected results later when you try to capture video from that tape.
For more information, see HD and Broadcast Formats and the Final Cut Pro / Final Cut Express User Manual, available under the Final Cut Pro / Final Cut Express Help menu
Dec 04, 2007 | Canon XH A1 Mini DV Digital Camcorder
JVC GR-DVL120 Playback
hi
you should have the heads cleaning,
try to put a cleaning tape and run it for playback then try recording again
thx.
Nov 20, 2007 | JVC GR-DVL120 Mini DV Camcorder
GR-D72 Mini DV Digital Camcorder makes clicking sound when tape running
the clicking is from the capstain turning the tape -- and perhaps the metal cage holding the tape.. if it is bent then the movement of the capstain may be pushing it in an eccentric fashion.
send it in for repair.
Oct 15, 2007 | JVC Cybercam GR-D72 Mini DV Digital...
Open Questions:
See all Sony Handycam DCR-HC30E Mini DV Digital Camcorder Questions
Sony Handycam DCR-HC30E Mini DV Digital Camcorder Logo
81 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Jose Ma DM.
Jose Ma DM.
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
