Question about Cobra Radio Communications
Weather Radio won't work on 29 Nightwatch
Cb is on a 2007 Freightliner which has commercial radio running off the CB antennaes. Commercial radio has weather band and it works. Have put on other antnnaes and ran them straight to CB and weather channel works, but won't work if ran through the truck radio system, has something to do with the trucks pre wired antennae's.
Need to know what I have to do to get the CB's weather channel to work,
    Genius:
  • 1,139 Answers
Hello papapyr07,
It looks like you are trying to run the CB and the commercial radio off of the same antenna at the same time? This I gather is failing. This may be due to the pre-wired antenna having a filter on it to prevent exactly what you are trying to do. If this is the case you may have no choice but to run a separate antenna for your CB (this is the most logical choice), now you can try to find the filter if it is an external filter and remove it and use an antenna matching network to connect the CB to the existing antenna system (next logical, but may void the antenna system warranty). In any event you will either have to run another antenna for the CB or find and remove the present antenna filter.
I hope this helps
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Dec 08, 2008
The weather channels quit working on my cobra 29 nightwatch.
its an internal problem , take it to a tech and let them fix it. the board for the wx probably has jumped freq. and thats why you can't receive wx.
Apr 10, 2015 | Cobra 29 WX NW ST 40-Channels Base CB...
Cobra CB 29wxnwst no weather?
I think you have a capacitor on the wx board thats been cut and / or removed.If it has been cut and its still in the radio all you have to do should be replace it. I think it # C608 ???
Jun 26, 2013 | Cobra 29 WX NW ST 40-Channels Base CB...
Every time i turn on my cobra 29 wx nw st sound tracker it goes back off
Hi Davis, please post on CB radio forum, this is Radio scanner forum.
Cheers,
Peter
Feb 20, 2013 | Cobra 29 Wx Nw St 40-channel Nightwatch Cb...
With my cobra 29 wx nw st I can not pick up any weather channels. I have the k30 antenna. Do I need a dual band antenna?
Do you hear static when you turn on weather? If so there are just none in range of you. There are not weather radio stations everywhere. You would not use a dual band antenna on any CB. Only an antenna designed for the 11 meter band. Which is the 27mhz CB radio band.
You can go here and see if you have NOAA All hazards weather radio coverage in your area.
If the CB radio is working otherwise it is most likely that there is just not a NOAA transmitter near you.
Aug 09, 2011 | Cobra 29 WX NW ST 40-Channels Base CB...
I have had a Cobra 29 BT installed and my reception is nothing but loud static only when moving. It is a 2010 Freightliner and SWR is consistently high at about 3.0. Is this a coax or antenna problem?
Hi,my name is John. Welcome to FixYa. It could be both. Try running your unit direct from or to the battery, bi-passing all ignition noise. Make sure your antenna is getting a good ground, have your SWR checked at a near-by CB shack, or Radio Shack all for free. Thanks for choosing FixYa....John
Nov 16, 2010 | Cobra 29 LTD CB Radio
Radio comes on but cant hear others talking
Is the antenna plugged in?
Is the antenna propperly checked with an SWR meter?
Have you tried turning the squelch back? (squelch on)
Have you check the microphone connections? (is the microphone dodgy?)
Jun 19, 2010 | Cobra 29 LTD CB Radio
Bought a new cobra 29, need antenna advice
Firestik Dual CB Antenna Kit This is a most popular dual antenna kit and one we HIGHLY recommend! It contains everything you need and features premium USA-made components from Firestik. The included FS CB antennas are our best-selling antennas and ensure you'll receive maximum transmit and receive performance. Designed for the elements, the stainless steel springs and mounts are rust- and weather-resistant. The included three-way mounts -- the most popular style we carry-- offer numerous mounting possibilities.
Dec 22, 2009 | Cobra 29 LTD CB Radio
Radio Communications Logo
112 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
