I need to add more cooling fans to my computer and wanted to find a manual on the motherboard, layout of motherboard and electrical diagram so I can wire the fans in the proper way and places. Plus I could use these manuals for later problems that come up. I have been looking for a service manual for this machine for some time now.
The manufacturer is the best source for a diagram for your machine. However, most cooling fans are three prong plugs, some are two or four, and most motherboards label these connections right on the motherboard. So, if you look at the motherboard and find a three prong connection that says something like CPU_FAN, CHA_FAN1 (Chassis Fan 1), CHA_FAN2, etc you are good to go.
SOURCE: Connection
=1024) && (screen.height>=768))
document.write( 'Search
manual, information?
Part number
Manual
Warranty information
Refund information
Rebate information
Serial numbers / manufacturer numbers
Billing information
Missing or lost CD, disk, or install file
Upgrade information
Part Number
There are literally millions if not billions of different part numbers used by companies today. Because of the vast quantity of part numbers and the frequency of those numbers getting changed or referenced to other numbers, Computer Hope is unable to offer its customers with third-party part numbers.
If you are looking for a part number we recommend that you contact the computer company or the company responsible for supporting your product. You can find a listing of companies and their contact information on our company listing.
If the company responsible for your product is no longer in business we recommend the below.
Also see: Part Number (PN) Computer Hope dictionary definition.
Manual
suggest you visit the manufacturer of your product web page.
Also see: Manual Computer Hope dictionary definition
Serial Numbers
Unfortunately, with the billions of different serial numbers and manufacturer numbers, contact the manufacturer of the product or look for information about the product on Computer Hope by searching by the manufacturer or type of device name. For example, instead of searching for "Serial Number 12345" it may be easier to search for "Maxtor hard drive".
If you are looking for a serial number for a particular software program you will need to contact the software developer or producer of the software program; Computer Hope will not provide any type of serial numbers or other registration numbers to any users. See our underground section for additional information to why Computer Hope does not provide this information.
Finally, a serial number for a hardware device such as a computer or printer can almost always be found on the bottom or back of the device. If you're trying to find the serial number for one of these devices try physically examining the device. If you're still having issues locating it the contact the manufacturer .
If you've lost one or more of your installation CD's or diskettes you must contact the developer of that program to obtain a new copy. Computer Hope cannot send anyone copies of the disks or downloadable files over the Internet of the program regardless if you have purchased the program.
SOURCE: emachines t2865 power led diagram
The header connections that you are looking for are on the edge of the motherboard near the battery. Look for a group of gold contacts sticking straight up at you. The silkscreen tells you which header are for what light or switch. You will see one that says "PWR LED". Another says "PWR SW" Another says "HDD LED". They are printed very small. You will see others in that vicinity that say "SAST1" and "SPKR". Ignore them.Look along the edge where the battery is mounted some are located around the nearby corner but still along the edge. All should be on the edge nearst the front of your machine. Others may be along the edge facing the bottom of your machine.
SOURCE: need wiring diagram for emachines t2200 motherboard
i need wiring diagram for my emachine t2042! I can't figure out where the red/white, green/white and black/white wires go!
I already know where the power supply wires go, everybody does- they're all the same!
SOURCE: Need wiring diagram for eMachine 20030812 motherboard!!!
You should be able to see the words/letters that go with the jumpers on the motherboard itself. look around the jumper settings area for power, pwr etc. and match them up with your jumpers which should have what the go to on them.
SOURCE: need manual or wiring diagram for this motherboard, thanks
Hello sir, I search for you and found a manual. Hope it is useful.You can see the wiring and everything. http://www.fixya.com/support/p362922-asus_p4sdx_motherboard/manual-11143
