Question about Mission 700 Main / Stereo Speaker
No sound from Front Speaker
Hi Folks, Interesting problem cropped up this week with my two front speakers. At first the Right front speaker did not work in Surround Sound mode(I use a NAD T760 Amp). Fiddled around with the wiring, cleaned the connection, and suddenly it worked...for a while. While the Right front worked I tested it in Stereo mode, and suddenly the Left front speaker, which worked in Suround Mode, did not work, while the one on the Right did...huh?? After more fiddling I am back to square one where the Left works in both modes and the Right in none. Not sure what it can be...I live close to the sea - do you think it can have anything to do with damp air on the connections? Cheers Juan
  • 72 Answers
Take amp to a workbench, have a test speaker in hand, touch the speaker wires to each channel to see if all channels work. take each speaker to the amp and temporarily hook one at a time to see if any speaker is bad. if you eliminate the hardware, you know it's the wires in between.
Posted on Mar 03, 2007
04 toyoya camry radio wireing harness pin
Hi there:
According with the diagram on 2004 Toyota Camry Car Radio Wiring Diagram...
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Pink/Blue
Car Stereo Amplifier Location: Located to the right of the glovebox behind the passenger side of the dash.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Left Front Tweeter: Powered by the same wires as the left front speaker.
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Right Front Tweeter: Powered by the same wires as the right front speaker.
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Tehy could be harnesses 15 or 20 pins, try to look your right replacement in this links:
- 2004 Toyota Camry Stereo Wiring Harness
- 1990-2013 Toyota Camry Auxiliary Car Audio Input Adapter Kit
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 06, 2012 | Toyota Camry Solara Cars & Trucks
No Sound in Right Front Speaker- Denon AVR-1508
hi there,
have you check the system settings for each of the speaker..? should be set and balance all output of the speaker
`jack
May 24, 2008 | Audio Players & Recorders
Hi....I need a wiring diagram for the stock amp in my grand am gt...its a 2003
Monsoon System Pinouts
Pin Wire Color Function
E1 LT GRN Right Front Speaker Output (+)
E2 TAN Left Front Speaker Output (+)
E3 GRY Left Front Speaker Output (-)
E4 LT BLU Right Rear Speaker Output (-)
E5 DK BLU Right Rear Speaker Output (+)
E6 BRN Left Rear Speaker Output (+)
E7 YEL Left Rear Speaker Output (-)
E8 BLK Ground
E9 BLK Ground
E10 DK GRN Antenna Relay Coil Supply Voltage
E11 ORN Battery Positive Voltage
E13 BLK Left Front Tweeter Speaker Output (+)
E14 YEL Left Front Tweeter Speaker Output (-)
E15 DK BLU Left Front Midrange Speaker Output (+)
E16 LT BLU Left Front Midrange Speaker Output (-)
F1 DK GRN Right Front Speaker Output (-)
F2 LT GRN Right Front Speaker Tweeter Output (+)
F3 PPL Right Front Speaker Tweeter Output (-)
F4 PPL Left Rear Tweeter Speaker Output (-)
F5 RED Left Rear Tweeter Speaker Output (+)
F6 DK GRN Right Front Midrange Speaker Output (-)
F7 ORN Right Front Midrange Speaker Output (+)
F8 PPL Gain Control Signal
F9 -- Not Used
F10 YEL Right Rear Tweeter Speaker Output (-)
F11 WHT Right Rear Tweeter Speaker Output (+)
F12 -- Not Used
F13 LT BLU/BLK Right Subwoofer Speaker Output (-)
F14 DK GRN Right Subwoofer Speaker Output (+)
F15 DK BLU/WHT Left Subwoofer Speaker Outlet (+)
F16 LT GRN/BLK Left Subwoofer Speaker Outlet (-)
or it is here 3rd one down
http://www.grandamgt.com/forum/forumdisplay.php?f=76
May 08, 2011 | Audio Players & Recorders
1997 dodge dakota truck radio stereo audio wiring diagram
1997 Dodge Dakota Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red/Blue
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Black/Yellow
Car Stereo Dimmer Wire: Orange
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Brown/Yellow
Right Front Speaker Negative Wire (-): Brown/Light Blue
Left Rear Speaker Positive Wire (+): White
Left Rear Speaker Negative Wire (-): Dark Blue/Red
Right Rear Speaker Positive Wire (+): Brown/White
Right Rear Speaker Negative Wire (-): Brown/Orange
Also, this coudl be interesting: Dodge Dakota Trucks at 1996
Hope helps (remember to rate and comment this answer).
Apr 29, 2011 | Car Audio & Video
Plugged in a Kenwood stereo in a 2000 tahoe. Have all power but no sound. Radio is not defective. When plugging the same stereo into a 99 express van, it works just fine. My question... What is the wiring...
Hi, your factory wire colors are below. Please let me know if you have more questions.
2000 Chevrolet Tahoe Car Radio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Audio Front Speakers Size: 6 1/2? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6 1/2? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Rear Speakers Location: Rear Doors
Left Rear Speaker Positive Wire (+): Brown
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Feb 10, 2011 | 2000 Chevrolet Tahoe
I just bought the car last week, and only the right front speaker is working. I thought the stereo was bad and replaced it with a new one only to find the same issue. Is it possible that they may have a...
Every stereo has it's intricacies, once you learn the controls then you can adjust the sound. if you have adjusted the balance to equal, then you may have a broken by door swing ground or positive, sometimes the ohms are split by a common positive connection (front and rear) contained with in the circuit of left or right. This crappy circuit could kill 3 of your 4 speakers, but then with the addition of an after market sub, who knows what kind of monkey business has been committed. Start from scratch in stead of chasing down electrical gremlins. Run new wires to all the speakers, dump the sub. Rebuild what should be there in the first place. Verify manufacturers connections and your interpretation of said, in the harness. Verify that the radio or amp can handle a sub without some goofy mono marriage of rear channels to obtain required ohms for crappy walmart sub Bazooka.
On second thought go to best buy, apply for credit card, and tell them that you want to bump down the road.
Jul 31, 2010 | Car Audio & Video
Weird surround sound speaker behavior with Denon 2105 7.1
Sounds interesting.
It may sound silly, but can you check all your speaker cables again and confirm whether they are connected to the right connections. please check all cables as also the severed one and please repair it also.
Now please go to the system-set-up and do an auto setup and set up your speakers. Listen to the test tones and confirm that they are coming out of the correct speaker.
Once these are set, then if still there is mismatch of sounds, then we could further trouble shoot.
Mar 08, 2009 | Denon AVR-2105 Receiver
No sound out of Front Left/Right Speakers on 5:1 setup
i have the same problem with my sony receiver. seems like the fronts and sub have no output after sitting idle for about one and a half years. center and rears are ok. any help folks?
Feb 08, 2009 | Pioneer VSX-05
No sound/test tone front front right channel
1-make a reset to your system.2-repeat your speaker setup.3-confirm that you assign your sysem for 5 chanell surround system.-4-change the cables between left and right front speakers if the trouble go to left channel you will have a problem in receiver itself-if the problem exict you will have a problem in speaker itself(cable or speaker)
Sep 30, 2008 | Audio Players & Recorders
DVD plays partial sound
Check your speaker connections it sounds like you have a 5.1 or higher sound system. 5.1 means left front speaker, right front speaker, center speaker, right rear speaker, left rear speaker and subwoofer.
Voices in movies all get channeled to the center speaker (you can usually hear it a bit from the right and left front speakers as well). If your center speaker is disconnected or not working, you will only hear the background sounds.
Sep 20, 2008 | Compaq Presario 5000 PC Desktop
Mission 700 Main / Stereo Speaker Logo
197 people viewed this question
Top Mission Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mission Audio Player and Recorder Expert? Answer questions, earn points and help others
