Question about Westinghouse LCM-22w2 Television
My Westinghouse LCM 22w2 (1 year old) has developed a green line running top to bottom of the screen. I cannot get rid of it. I've tried turning the monitor off, changing inputs, reseting - but it's still there. Any suggestions? Thanks, Bob
  • imbc Dec 06, 2008
    I spoke to Westinghouse and they confirmed your assessment. No love from them on a 2 year old monitor with this problem. Into the round file it goes :-(. Pretty poor performance for a LCD monitor - less than 2 years of modest use service.
    Thanks for your help.
  • jsura Jan 15, 2009
    tx42f430 bestbuy 12/22/07..on the 10th it developed a 1" green vertical line on the right. can u access a service menu to fix like a pro serviceman would? Others in av forums have this 1 year green garbage and no help. ok with pc though. just tv prob
    President:
  • 2,992 Answers
Unfortunately that is a failure in the display electronics and is repairable only by replacing the display panel. I don't know what the warranty period is for this model, but check your purchase date and the warranty information. If the thing is just recently out of warranty maybe the manufacturer will work with you on a solution. Or you can contact them anyway and ask. Sometimes if you complain loud enough it works wonders.
Posted on Dec 06, 2008
Verticle lines on monitor
Hi there.
I have written a very helpful tip about this problem recently.
Check it out here: http://www.fixya.com/support/r9352105-fix_colored_vertical_lines_lcd_display
Jan 17, 2012 | Westinghouse LCM-19v1 Monitor
I have a Westinghouse monitor Model # LCM-19v SL the monitor keep turning off. Unplugging then replugging gets it working then it shorts out again. Can I replace the power Supply cord - Potrans ITE Power...
i also have a 19" westinghouse monitor the screen on mine goes black i just turn the monitor of then back on the problem is it's overheating and from what i understand it's caused by faulty or worn capacitors the ones that are bad are vented on top so it's easy to tell the bad ones. you can see what they look like on line!
Nov 18, 2010 | Westinghouse LCM-19v1 Monitor
Westinghouse LCM-19w4 has power, but blank screen
refer to an earlier post about similar problems. Does it power up and then shut itself off. this is possibly due to two defective capacitors. 27 cents on line $1.50 at radio shack. They will be puffy on top. I am a complete novice to soldering a capacitor onto a board. but since I was junking the monitor otherwise I gave it a try. It's still working after sitting idle a year. Handy advice on soldering online. use copper wire to **** up the old solder and try not to fry the capacitors or the board. If I did it anyone can.
Mar 22, 2009 | Westinghouse Computers & Internet
Westinghouse lcm 19w4 has to be used in brightest mode or
I had this same problem and going through the on-screen menus I found a reset option. I reset the monitor settings and the scrolling bars went away. I plan to leave it powered up for a while to see if they come back.
Jan 13, 2009 | Westinghouse LCM-19v1 Monitor
Screen goes black.
It's a hardware defect. you can't repair that. if your monitor in under warranty you can go for repair.
or repair it through any good local vendor.
Nov 23, 2008 | Westinghouse LCM-19v1 Monitor
Thin vertical red line
This maybe the symptom of a bad Panel. One Vertically This line is 99% bad panel. Call your warranty provider or SONY tech support if purchased under 2 years.
Best regards
CircuitCity
Nov 25, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Lines on the page
Hi,i will do this: Remove toner,then remove developer unit.Try to clean magnet roller on developer unit with dry cloth, if see lines on roller.Pull out paper transport unit(green handle ) and clean transfer roler and vacuum it.Then ,when is paper transport and developer unit out, remove drum unit(open door on the left side on the printer and pull out drum). Remove Corona from drum unit.Remove and clean grid,corona inside and corona vire.
Check fuser and drum for scratches.
Nov 23, 2007 | Kyocera Mita FS-1920 Laser Printer
Concave Images with pink and green colors
you can get it your tv fix the problem is in the IF amp and video circuit.a convergence will also be neeeded.the tv is old but can give you some more life call a tech they will be your tv doc.
Apr 03, 2007 | Sony KP-57HW40 57" Rear Projection...
No Picture
I have the same problem was working fine and less than 2 months bam red screen green lines top to bottom no image on any input just volume works....Now i will be a victim of there horrible warranty service
Jan 09, 2007 | Westinghouse LTV-37WI 37 in. LCD...
Westinghouse LCM-22w2 Television Logo
304 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
