Back to:
Tags:
Eizo FlexScan L 985EX  21.3 in. Flat Panel LCD Monitor
Monitor goes black and then on again (by 2 users)
posted by ronpiterman on Mar 01, 2007
My Eizo l985ex is turning suddenly black and then turns immediately on again - just like a black "flashlight".
This has apparently nothing with the graphic card or mainboard of the computer since I just changed a system, and the problem was also on the other system.
The problem accures repeatedly every 10-20 minutes, sometime more, sometime less often.
Cheers,
Ron
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by mihaievoiu, posted on Dec 02, 2007
I have the same problem but only when i use th digital input. The analog does not have this problem
Can you Help with these Monitors problems?
Monitors
Sir what is a backlight inverter? because you said I need...
Monitors
Screen flickers and flashes. Then settles down for a few...
Monitors
hi dear, my computer works fine but...
Monitors
I have cracked my 19" HP monitor (works fine still)...
Loading problems.
Repair Service
Find Monitor Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
