Question about Canon imageCLASS MF4150 All-In-One Laser Printer
CANON MF4140 'LOAD CORRECT PAPER CASSETTE : LTR'
It prints one page then stops the error light flashes red and the message 'load correct paper cassette : ltr ' appears on the LCD screen. I have tried resetting the paper size thickness etc also the manual feeder is set at a4 - help?! CANON MF4150 'LOAD CORRECT PAPER CASSETTE : LTR' problem It prints fine and then stops after 10 or so pages, with the above error. Settings are correct both on printer and on software running. Vista driver was reloaded as well, still problems printing. I tried that helpful tip, however my printer still does not print but one page and then I get the same error as above. Curtis.buck@comcast.net
  • MANAGER07 Dec 25, 2008
    CASSETTE LTR
I had the same cr@p of the problem yesterday. The problem was not inthe paper. You have to do 2 simple things, from which one will solvethe problem.
first, download the latest drivers and install them.
And the more important thing, the problem occurred due to incorrectpaper format. Solution is very simple. Open MS word or somethingsimilar, file->print.. and before you print open Properties menu.There for the Output Size will be selected "Match Page Size". you don'twant that (i don't know why it doesn't work), but the solution ismanually select A4, or whatever your page size is.
And there it is... printer starts throwing pages out like crazy :)))
Posted on Dec 27, 2008
    New Friend:
The problem was the driver of the printer. Try to uninstall driver of the printer. Download the driver at http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/imageclass_series/imageclass_mf4150#DriversAndSoftware
and reinstall the driver.
It works 100%
Posted on Jul 03, 2013
3 Suggested Answers
SOURCE: CANON MF4140 'LOAD CORRECT PAPER CASSETTE : LTR'
the problem is from Word.
Change the settings: File-Page Setup-A4 (not letter).
IT'S WORKING!!!!
Posted on Feb 08, 2008
AFter we tried everything, the paper we bought was apparently not quality controlled and mixed with different weights of paper that caused the error. We purchased another brand and have had no problems so far...
Posted on Dec 02, 2008
My printer is i-sensys MF4150. It prints one page then stops the error light flashes red and message 'load correct paper cassette : ltr ' appears on the LCD screen.I print 1 page then I...
Dear
Pl. select the paper size ( as mentioned on the paper packet) on computer on click START-PRINTER AND FAXES(new window opened)-(right click on printer icon) PRINTING PREFERENCE(new window opened)-select PAPER -paper option (here the paper size to be selected- APPLY. This may set the paper size default.
Thanks.
Feb 03, 2015 | Office Equipment & Supplies
Whenever I try to print anything or copy anything on the Cannon MF6530 it will print the first page then make a beeping noise and the red light starts flashing and it says change paper size - casette 1 LTR...
try to set the proper size for the paper in the printer.
press [Additional Functions] button (right of the LED display)
navigate to Common Settings
use [<-] and [+>] buttons to navigate to Select Paper Type and press and press OK
Confirm that Cassette 1 i selected (or Cassette 2 if you have optional installed)
and Set the paper type
next navigate to Reg. Paper Size, press OK, confirm again the cassette (1 or 2) and using the arrow buttons, set the paper size (should be LTR if you using LTR)
Sep 20, 2011 | Office Equipment & Supplies
Error Message: load the correct paper cassette: A4
check under printer driver, paper size.Usually the default paper size iz ltr. change it to A4 if you wana print on A4.
Jul 22, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Load cassette LTR only prints first page
Turn off the machine, under printer driver properties on PC set the custom paper size on A4 or paper tha you use.
Turn on, and try to print.
Jun 28, 2010 | Canon i-SENSYS MF4140 All-In-One Laser...
Paper cassette error
This meen the paper dial selector in the drawer is set for letter size paper,set it to the correct envelope size.I suggest you use the manual bypass for the evelopes.
Sep 25, 2009 | Canon imageRUNNER C3200 Copier
I had the same cr@p of the problem yesterday. The problem was not in the paper. You have to do 2 simple things, from which one will solve the problem.
And the more important thing, the problem occurred due to incorrect paper format. Solution is very simple. Open MS word or something similar, file->print.. and before you print open Properties menu. There for the Output Size will be selected "Match Page Size". you don't want that (i don't know why it doesn't work), but the solution is manually select A4, or whatever your page size is.
Dec 01, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
Canon MF3240 printer error message.........
I think I solved my printer problem: Chang the paper size to LTR in the printer panel. then go to compter printer setup and choose printing preferences and choose page setup and chang the paper size to Letter (LTR) also. hope this is helpful.
Nov 13, 2007 | Office Equipment & Supplies
I had same thing happen after a fresh Windows install. It was hard to figure out since it had been working fine until then, but luckily it is simple to fix. Open the Start Menu > Settings > Printers and Faxes folder. Then right-click on the Canon MF4100 Series printer and choose Printing Preferences. In there, change the Paper Size to Letter (instead of A4). You may also have to do this in the Print setup for whatever program you're using to print.
Sep 11, 2007 | Canon i-SENSYS MF4140 All-In-One Laser...
Canon imageCLASS  MF4150 All-In-One Laser Printer Logo
3,295 people viewed this question
old marine
old marine
