Question about Hitachi 53FDX20B 53" Rear Projection Television
How do I tell my 53FDX20B to recognize digital instead of analog?
I was lead to believe the 53FDX20B is "digital" ready.
How do I / can I, enable it to receive the digital antenna signals?
Thanks
    Genius:
  • 1,199 Answers
You may have been lied too! there should be a test in your area and if you tv does not pass your local test your tv is not digatal ready!you may have to buy a converter
Posted on Dec 06, 2008
Unable to enable digital audio.
Digital audio will only be enabled through the optical in jack. And the sourse has to be a digital broadcast.
Mar 20, 2013 | Vizio GV42L 42 in. LCD Television
Tip
A fax machine is just a big ol' telephone answering machine
There is no mystery, seriously. You send a fax exactly the same way as you make a phone call; instead of talking to a person, your fax machine talks to another fax machine. Clicks, squeals, buzz sounds.
If it says it's busy, well, it's busy
If it doesn't answer, it's not set to AUTO RECEIVE
If it says OFF HOOK another device is using YOUR phone line.
If you don't hear a dial tone when you press the HOOK or MONITOR key, the phone line is dead. Check the line with a regular phone.
If a dial tone sounds weird, it is a DIGITAL phone line. You need an ANALOG or regular phone line.
ALL FAX MACHINES ARE ANALOG DEVICES AND WILL NOT WORK RELIABLY ON A DIGITAL SYSTEM OR A COMPUTER....Magic Jack, Vonage, etc. are DIGITAL PHONE SYSTEMS. Don't believe what the Vendor tells you. They are for designed for VOICE GRADE PHONE CALLS ONLY.
The settings in your fax machine were designed by people who are a lot smarter and make more money than us. DON"T MESS WITH THE PARAMETERS.
It's all that SIMPLE !!
on Mar 09, 2010 | Office Equipment & Supplies
My receiver will not change to digital play ? the text on the receiver is ''analog only''
Hi
A little more information about the make and model of your amplifier would make it much easier to tell you exactly what button where to press on your amplifier.
But I am sure I can point you in the right direction.
Analog only means that although you have connected your DVD player or Settop box to your amplifier on the digital coaxial input you have not yet setup all that needs to be setup.
Start by checking that you have enabled the digital coaxial output on you DVD player. You can set the following if it is available:
1: Select your Digital output to ON
2: Dolby Digital setting must be Dolby digital
3: MPEG switched to MPEG, not PCM
4: Select 96Khz/24bit or higher data transfer on coaxial cable.
Note - all these setting might not be available depending on the manufacturer.
Now you will already know the input switching on the amplifier - so select DVD.
Now to activate the coaxial port you must look for a button named "input mode" either on the amplifier itself or on the remote.
Press this until the amplifier says Digital.
Now get ready for great sound.
Hope this helps!
Jan 01, 2010 | Audio Players & Recorders
Have Problems with getting Channels?
You've not given us the manufacturer, make and model number, but I see 3 analog inputs on the left and the usb on the right. This tells me the analog audio and video signals must come from a dvd or vcr or tv-tuner. You say getting channels, so I'm assuming you've not hooked up to a digital ready tv hooked to cable or dish or digital converter. THERE ARE NO MORE ANALOG SIGNAL CHANNELS ANYMORE. Everything went digital in June 2009. So there you have it. If you don't have usable information going in, you can't get it out. try it with sterio audio and video from a digital tv that is receiving channels, and I think you'd then see sterio and video out of your pc. Regards --- GooseBay_Camper
Sep 28, 2009 | RCA Analog (RCA) to Digital (USB)...
A Samsung Tv model #HLN5065W
Model # HLN5065W Digital Main Assembly Board should be part # BP94-00385A. Here's a link to a major Samsung distributor:
Samsung HLN5065W Replacement Part Digital Main Assembly Board
***There's also a manufaturer's notice: If you replace the digital main board (BP94-00385A) you must replace the main analog board (BP94-00434A) per mfg bulletin# ASC20040728004.***
Samsung HLN5065W Replacement Part Main Analog Board
Dec 30, 2008 | Samsung HLN5065W 50" Rear Projection...
Is the sony kv-32v35 digital ready?
if the tv is less than two yrs old than yes.
Dec 20, 2008 | Sony KV-32V35 TV
Digital ready?
Sanyo's customer service responded that this TV is not digital. If it's connected to an antenna, you will need to purchase a Digital to Analog converter box.
May 11, 2008 | Sanyo DS19310 19" TV
Digital Conversion 2/2009
No it is not HD ready, your set has a NTSC tuner the new digital sets have an ATSC tuner, BMW Rider
Jan 02, 2008 | Hitachi 50UX57B 50" Rear Projection...
No picture, no sound
First thing to check, would be that there is no oily liquid or residue around or on the printed circuit boards underneath where the picture tubes are. If there is, one or more of the tubes are leaking out the coolant and the seals will need to be repaired as well as the board, if it is not beyond repair. If that does not work, check out the power supply voltage . Check to see if the horizontal output transistor is shorted, or that the convergence Ic's are not causing the set not to start up. Good Luck
Jul 15, 2007 | Hitachi 53FDX20B 53" Rear Projection...
Hitachi 53FDX20B 53" Rear Projection Television Logo
47 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
