Question about Sony MSDW-904 Comopsite Video Input Board MSDW904 Camcorder
If I recorded a tape with dirty heads, Is the recording going to be fuzzy? When I play the tape...its very distorted ..but im wondering if I clean the heads will the video I shot be salvagable.
I recorded a tape and then later realized I had dirty heads, Is the recording going to be fuzzy? When I play the tape...its very distorted ..but im wondering if I clean the heads will the video I shot be salvagable.
All of a sudden no picture appears on the screen when recording or playing back. It will play old tapes that have been recorded, but won't record any new pictures, just sound. Did I press something? It worked a month ago and hasn't been used since.
Posted on May 02, 2008
  • 370 Answers
SOURCE: camcorder won't play recorded tape
Clean the head and try again
Posted on Dec 07, 2008
SOURCE: No playback pics. Blue screen.Can't record.Used x2 since service.
I just made contact with a service tech who seems very competent and who won me over. Have problem with video and audio dropout similiar to dirty heads on a 10 year old DCR-VX2000 but which is a larger problem attributed to worn parts which will need replacement. Do not know how old your unit is, but will share name of person/company if you wish. Only thing that worries me is if you by chance had had yours repaired by them!!! They are a Southern California company.
Posted on Mar 13, 2009
  • 71 Answers
SOURCE: Cannot find a head cleaner for Sony Digital 8 (DCR-TRV460)
Yes you can clean the heads. It's a delicate procedure, but, requires no disassembly. But, I'm curious about your mention of "blurry spots." Typically, on a digital camera, the video when the heads are dirty, will either just appear as a white screen, or, will come out blocky and glitchy (like poor satellite reception). "Blurry" would result from a dirty lense or filter. However, to clean your heads, I would run to Radio Shack and buy cleaning fluid refils. Take a Qtip and dampen it with the cleaning fluid. Open the camera, remove the tape and look for the video drum. Lightly rub the Qtip along the drum horizontal to the spin direction (not across the grain). Turn the drum and clean until you have swept the entire circumference.
Posted on May 02, 2009
  • 431 Answers
SOURCE: picture playback on hi8 tapes distorted and fuzzy
Hi I am Vortash get a tape head cleaner for Hi 8 cameras and try that , most people never actually clean the camera it's something we all forget to do if its not tha you may have contamination in the lens or a taget imager fault regards Vortash
Posted on May 31, 2009
SOURCE: No picture when trying to record
Check the following link. Call them and explain the symptoms and they should send shipping label to you so you can send the camcorder in for repair. I had my TRV38 repaired in about 2 weeks. Good luck.
this is a known issue with Sony
Posted on Jun 09, 2009
0 characters
1 Points
Picture during playback is badly distorted
There could be several reasons for badly distorted pictures. considering the age of the unit as DV camcoder which I am guessing would be quite a bit. Most likely the heads have worn out and need replacement. I am assuming you have this problem with newly recorded tapes being played on a TV directly from the camcorder. For this you may also need to check if you are using new tapes and whether the recording mode is PAL or NTSC as per the TV format.
Alternate test would be to play back a previously recorded tape back from the camcorder. That way at least you can establish if the problem is the read head or the write head or the tape itself.
Aug 16, 2014 | Canon Elura 100 Mini DV Digital Camcorder
When playback of tape, fuzzy, not clear picture, or blue screen with sounds
try rewinding the tape and play it from the beginning.if still the same,video heads may be dirty and needs to be clean.i recommend you use a dry head cleaning tape.after which reinsert tape and play it again.if issue persists use a diff tape with previous recordings.if still no go,use new tape and try recording on it,play it back and check.if still the same your unit will require service.thanks:) hope this help.
Mar 12, 2010 | Sony Handycam CCD-TRV308 Camcorder
I have a samsung scd103 digital cam and when i record something it looks good on the screen while im recording it but when i play it back there are grey lines and distorted sound
Have you tried cleaning the recording heads? Use a dry type cassette cleaner only. It's just like a vcr head cleaner tape, only in the small mini-dv tape size.
Sep 30, 2009 | Samsung SC-D103 Mini DV Digital Camcorder
Camera won't record/ play footage.
Video head was dirty / clogged due to old tapes usage so it did not recorded any signal on tape and now it requires cleaning with good quality head cleaning tape to record and playback properly.
May 31, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Colored, pixilated bars appear during playback
It is very common when the magnetic heads got dirty. Buy a Mini DV cleaning tape, follow the instruction clean the heads by playing the cleaning tape for a while. Record NEW video and playback to test.
Please know if you play the old video recorded buy the dirty heads, you may not get clear picture, because here is not correct data recorded on the tape.
Apr 09, 2009 | Canon ZR90 Mini DV Digital Camcorder
Dirty heads
I work for canon and when I get one this dirty I use a tape that has been recorded with used or almost used up. I let the tape rewind and fast forward all the way through. I then use a soft head cleaning tape for 25 secs. If that doesn't work then it might need an adjustment.
Dec 18, 2008 | Canon HV20 HDV Digital Camcorder
D8-->Hi8 switch.
Hello DutchyFL,
Sony recomends to use Video Head Cleaning Cassette in Playback mode. Video Head is still dirty in your camera thats why you can't see D8 picture.
Apr 29, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Problems with playback of HI8 tapes...
What's happening is that the tape in the cassette is being chewed on one side by the camera's tape transporting mechanism during playback, hence the distorted image and sound. The mechanism might be damaged (misalignment) or just dirty. Try not to play other tapes on this unit because they will become permanently damaged. The best way is to find another camcorder (if cleaning does not help). Note that some old cassettes of long recording time will exhibit this behavior more often because of thinner tape used.
Dec 06, 2007 | Video Cameras
Will not record or play back.
the head may be dirty, try cleaning the head with a cleaner tape and try recording again.
Oct 23, 2007 | Sony Handycam DCR-TRV340 Digital Camcorder
Bad playback quality
Some possible cause of lines, noise or pixelation during playback are: 1. Dirty heads on the recording machine. If the heads were dirty at the time of recording, the dirty heads didn't record a strong enough signal on the tape. The damage is done for this tape and recovery is unlikely. Best advice here is to use only premium grade new tapes and keep your camcorder clean by occasionally running a cleaning tape. 2. Physical tape damage. Any distortion of the tape will result in mistracking and subsequent loss of data. 3. Built up oxide deposits or other debris in the guidepost corners can also result in tape edge damage. Keep your machine clean! 4. Improper tape storage - Even short term exposure to high temperatures over 130 deg f. can permanently damage the tape. The black cassette housing readily absorbs the sun's infrared rays and internal cassette temperatures can soar even if left in direct sunlight on just a warm day. It doesn't take much heat to slightly distort the plastic shell or ruin the tape contained within. * Try other tapes to ensure the problem lies within the tape and not the camcorder. * If the problem becomes apparent on all tapes, try a head cleaner. After cleaning the heads, the tapes may not play cleaner if the recording was done while the heads were dirty.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Video Cameras Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
