Question about Vivitar ViviCam 5355 Digital Camera
Camera will not recognize sd memory card
Installed and formatted 1gb sd memory card in vivicam 5355 and camera
still only shows int memory
  • gypsymishka Dec 26, 2008
    II have also installed and formatted an SD card (2gb) but Vivicam 5355 will it recognise it
    Genius:
  • 1,234 Answers
Hello There
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Posted on Aug 27, 2010
    SD Card Problems with Vivitar Vivicam 5118!
    What size is the memory card. If it's larger than 4GB then it won't work in the 5118.
    Try using another card. Don't format it in your computer but do format it in the camera before trying to take pictures.
    May 05, 2012 | Vivitar ViviCam Cameras
    How do I clear the internal memory?
    This should do it - this comes from the manual Formatting will do what you want.
    Formatting an SD Memory Card or Internal Memory This utility formats the internal memory (or memory card) and erases all stored images and data. 1. Press the button to turn on your ViviCam 3785. 2. Press the MODE button twice to enter [ ] Playback mode. Then press the button to enter the Playback menu. 3. Select [Delete] by using the / buttons, and press the button. 4. Select [Format ] by using the / buttons, and press the button. 5. If you want to format your SD memory card or the internal memory choose [OK] by pressing / buttons, then press the button to confirm.  To cancel the action, select [Cancel] instead.  [No Image] pops up after the SD memory card or internal memory has been formatted. Note:  Be sure the SD memory card is properly inserted into the camera before formatting it.  To format the internal memory, be sure to remove your SD memory card first.  Formatting will erase all information (even unrelated , non-camera data) from the memory/card.  For complete compatibility, be sure NOT to select FAT 32 as the file system when you format the SD card in your computer. Memory cards formatted in FAT 32 file system will not be recognized by this ViviCam 3785.
    Jun 16, 2011 | Vivitar ViviCam 3785 Digital Camera
    My computer is not recognizing my PNY SD 1GB memory card. I can still take pictures and my camera saves them to the memory card, but when I try to transfer the pictures to my computer, it does not...
    In this instance, you might want to consider either borrowing, or, purchasing and card sd reader. Some computers just don't read these cards from their built-in slots, so, using an sd card reader often fixes the problem.
    Hope this helps. :)
    Oct 06, 2010 | PNY 1GB microSD Memory Card
    The camera is saying that memory full and then when I try to playback it says file error.
    your memory card is not letting camera to read files.. its better to copy files to your pc and then format your card.. this will surely fix your problem
    Feb 12, 2010 | Vivitar ViviCam 5355 Digital Camera
    How do I format an SD card for a Vivicam 3785?
    You can format the SD card in your ViviCam 3785.
    This utility formats the internal memory (or memory card) and erases all stored images and data. Make sure your SD card is in the unlocked position.
    2. Press the MODE button twice to enter Playback mode. Then press
    3. Select [Delete] by using the up/down arrow buttons, and press the OK button.
    4. Select [Format ] by using the up/down arrow buttons, and press the OK button.
    [OK] by pressing up/down arrow buttons, then press the OK button to confirm.
    has been formatted.
    If you need a manual for your camera you can download a free PDF at
    http://www.retrevo.com/support/Vivitar-3785-Digital-Cameras-manual/id/200ag818/t/2/
    Please rate this solution. Thanks.
    Jan 15, 2010 | Vivitar ViviCam 3785 Digital Camera
    I have a 2GB SD Memory card thats won't format and says its full
    per manual... camera supports UP TO 256MB... your camera can't recognize a 2gb card.
    Mar 08, 2009 | Vivitar ViviCam 3705 Digital Camera
    Lost cd for vivicam 5355
    If the camera has a removable storage card find a friend with a computer that will accept the card and upload it into a variety of programs
    Jan 16, 2009 | Vivitar ViviCam 5355 Digital Camera
    Cant format memory card for vivitar vivicam 5188
    I cannot format the sd card. The camera stays in the busy mode.
    Dec 09, 2008 | Vivitar VIVICAM 5188 PINK BNIB Digital...
    Vivitar ViviCam 5355 Digital Camera Logo
    188 people viewed this question
    Top Vivitar Cameras Experts
    Tony
    Are you a Vivitar Camera Expert? Answer questions, earn points and help others
