Question about Sony MSDW-904 Comopsite Video Input Board MSDW904 Camcorder
I have an old 1985 Sony Video -8 AF camcorder...I shot some film and it is VERY grainy on the tape....
Im pretty sure after reading some of the other postings on here that I need to get a head cleaner cassette. Do you know where I could get this? Also, is there any way to salvage the material from the tape? Do you think cleaning the head will allow me to see what was recorded...or is the recording itself bad.
SOURCE: very grainy playback
Same problem with my Sony CCD-TR416 recently. Know what finally worked? With camera playing a tape, I picked up the camera and tapped it sharply on a solid desktop. Had to do it 3 times. I held the camera with two hands, one on each side of the camera, raised it about 3 to 5 inches off the desktop and then quickly tapped it on the desk holding the camera parallel to the desktop so that it solidly hit with all of the lower surface of the camera body.
I know it sounds crazy. I swear it worked. I had tried cleaning the heads over and over. I examined them with a 20x loupe and they looked fine. I doubt that the problem was oxide and debris build-up on the heads.
I planned to order a new head/drum just to see if I could manage the replacement procedure by myself (I'm a chronic do-it-yourselfer/experimenter). I guess I don't need to do that now.
Why did the slam technique work? My guess: Inside the rotating head, there must be some sort of electronic track like the brushes of a motor or something similar.. Some sort of debris must have been involved in a corruption of the transfer of impulses from the heads. A few taps and it broke free.
If banging it on the desk didn't work, I was next planning to remove the drum to check for bad connections. I'm sorry I didn't have to do that.
Nevertheless, don't listen to everyone when they say that the "heads must be dirty." Nope. With the loupe, I could see mine were sparkling clean. But, I still had those multiple horizontal rows of short white streaks obliterating the video image. Tap. Tap. Tap. Now they're gone.
Try it. Couldn't hurt. Though chances are, you won't see this. I'm posting 6 months after your original post. I just happened upon your post as I researched the problem through Google. Neverthelss, someone might see my response someday and maybe they, too, will get luck with the tap, tap, tap procedure.
Posted on Jan 15, 2008
welcomejee
  • 10594 Answers
SOURCE: Mode for playback of older 8mm tapes using Sony DCR-TRV730 ?
In 1990s Sony camcorder records movie in analog format so playing in digital camcorder like DCR-TRV730 doesn't mean it will be converted in digital format and you can not import file in PC for editing purpose. You will get analog signal while playing back old cassettes.
Regarding SP, LP speed, its decided at time of recording. Camera sens SP or LP automatically in playback and set itself accordingly.
If you want to convert old cassettes into digital format, connect our camcorder to DVD recorder and burn DVD which is digital format, copy DVD files in to PC and do desired editing.
Posted on Nov 24, 2008
  • 383 Answers
SOURCE: camcorder won't play recorded tape
Clean the head and try again
Posted on Dec 07, 2008
renx
  • 71 Answers
SOURCE: Cannot find a head cleaner for Sony Digital 8 (DCR-TRV460)
Yes you can clean the heads. It's a delicate procedure, but, requires no disassembly. But, I'm curious about your mention of "blurry spots." Typically, on a digital camera, the video when the heads are dirty, will either just appear as a white screen, or, will come out blocky and glitchy (like poor satellite reception). "Blurry" would result from a dirty lense or filter. However, to clean your heads, I would run to Radio Shack and buy cleaning fluid refils. Take a Qtip and dampen it with the cleaning fluid. Open the camera, remove the tape and look for the video drum. Lightly rub the Qtip along the drum horizontal to the spin direction (not across the grain). Turn the drum and clean until you have swept the entire circumference.
Posted on May 02, 2009
aneesh ch
  • 73 Answers
SOURCE: Sony Handycam CCD-TRV21 won't play tapes.
no that u must remove ur camera and try to clean all strip that connect with board and mechanisum and all connectors legs solder then it will work .any doubt call u.a.e no 00971503853766
Posted on Jul 09, 2009
We have an Sony Video 8 AF. Camcorder is not working. Can and What can we use to transfer the movies we have taped to a more modern format?? Is there a cable or can you recommend a professional who can...
You can take your tapes to a video transfer service and get them to transfer to DVDs. Any large metro area will have these services but if not, you can mail off the tapes to a known service. Look online (google) for a reliable service with BBB rating and customer testimonials. Look locally first.
You may find a working Sony 8mm camcorder on your local Craigslist.com or at a Goodwill store or other second hand outlet or in the newspaper ads or online but that is unlikely since they are so dated. Remember that a Sony Hi8 camcorder can also read 8mm tapes so if you can find one of those for $50 to $80, they would read the tapes.
Lastly you could repair the camcorder but it may not be worth the cost. Local electronics repair shops may be able to fix the camera.
Apr 07, 2011 | Sony MSDW-904 Comopsite Video Input Board...
How can I convert my 8mm tapes to a digital format and save to my hard drive?
If you have DVD Recorder then hook your Video-8 camera in analog AV input and burn a DVD, this will convert analog video/ audio signal of camcorder in digital format and transfer the data on DVD as well. Put that dvd in computer and save it in computer.
Nov 23, 2009 | Sony Handycam DCR-TRV350 Digital Camcorder
Got old 8 mil video recorder wont to put film on pc how do i do it
you need a card for your computer. available form electronics store it's easy
Nov 16, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
560X Camcorder Handycam won't record or play
This behaviour is relaterd to tape reading / tape detection. You may have a dirty or worn-out head on the video heads drum.
You may try to use a cleaning tape in order to retrieve normal perfoming of your camcorder, BUT you should take care, as cleaning tapes are also abrasive tapes, and the amount of cleaning cycles a video head can support is limited.
Then it should be possible that after cleaning the result is nul or worse (I had this lately on an old Sony Camcorder, it was recording with much losses in the film, after using the cleaning tape it doesn't record any more).
All that means you may repair your camcorder with the cleaning tape, but you may finish it too, if the video heads are too old.
In any case take time to read the cleaning tape user manual, cleaning time is very short (10 seconds generally) and must'nt be overtaken.
Hope you would have the good result !
Jun 17, 2009 | Sony Handycam DCR-TRV130 Digital Camcorder
Sony Hi-8 plays new recorded video buy not playback
Are they PAL or NTSC tapes ? They may not be compatible with your new equipment.
Jun 13, 2017 | Sony Handycam CCD-TRV40 Camcorder
Viewing SONY 8mm Tapes -- Please help
The older tapes were shot on a 8mm camcorder and the camcorder you have wil not play them becasue it doesn't have backwards compatability with the older format. The tapes you recorded are on a digital 8 camcorderr and it is different encoding than the one you recorded the other 60 tapes with. You will need to find either a dcr-trv 350 trv 530 trv 730 ect as these have the ability to play all the tapes.
Or find an older 8mm camcorder to play your tapes with.
Hope this helps
Cheers
Al
Nov 01, 2008 | Sony Handycam DCR-TRV280 Digital Camcorder
Dcr-trv320e
Hi 8 tapes will only play on a Hi 8 machine. I would recommend you search for a place that will do the video transfer for you. There are several in my town and likely you could find one on the internet.
Oct 18, 2008 | Video Cameras
Video 8mm player
only sony really supported 8mm look for any trv model cam on ebay etc and make sure you tapes were hi 8mm-not digital 8-digital 8 won't play on reg 8mm cam-need to get model that supports both formats then-trv480-look at tapes and if they say digital and/or hi 8 they may have been in digital and get the 480 it will work with both types
Aug 24, 2008 | Video Cameras
Not reading Hi8 tapes
Fidus, I am not sure where you are located but the camcorder you're trying to use now is a PAL version of Sony's 8mm camcorder. If the tapes you recorded earlier were recorded in D8 (digital 8) or 8mm/Hi8 format NTSC, they will not play correctly in this unit. The NTSC and PAL formats are different and not compatible. Hope this helps you. Joe Weibel customelectronics.org
Feb 28, 2007 | Sony CCD-TRV228E Camcorder
Video Cameras Logo
665 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Jose Ma DM.
Jose Ma DM.
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
