Question about Roper RAS8445KQ Top Load Washer
Water Won't Drain from Washing Machine
My GE washing machine will not drain water. If you put it on spin the tub spins but will shut off. It was working fine untilmy son washed a pillow that burst in the machine. I noticed today that there is some pillow stuffing that is in the water after the tub gets filled with water. Do you thing that something is clogged. I have a GE Heavy Duty Super Capacity machine with 9 cycles and 2 wash-spin speed combination. I found these two numbeers on the back of the machine, Ser DL154807G aand WHDSR209DAWW. Any ideas?
  • Anonymous Dec 08, 2008
    I have a similar problem with my washer aswell, I put the clothes in and it begin to wash for a little bit, but then it cut off and wouldn't drain.
    I took out the wet clothes and most of the water, but I'm not sure how to get my washer working again.
  • 706 Answers
Hello phylislw61,
If you had an incident where a pillow broke and feathers where dispersed throughout the washer..then there is a good chance that teh drain fiilter screen, pump or hose feeding the pump is clogged. I would verify that the filter is free from anything that would limit water flow from getting to the pump.. then if the problem is still there.. examine the pump itself to make sure it isn't clogged...
If you or someone in your family is reasonably handy, here is a link to your washing machines exploded view and parts and this should provide sufficient information for how to access the pump and associated hoses etc that feed into and out of it for cleaning..
If you are having problems after you verify the lines are free of restriction, feel free to contact me and I will try to assist you in solving your problem.. Here is the link..
http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
Posted on Dec 06, 2008
Asko 620 washer won't drain well with heavy load
Washing machine won't drain
When your washing machine won't drain, it could be as simple as a kinked hose or as complicated as a faulty impeller on the pump. Overloading your washing machine can cause items to be swept into the space between the inner and outer tub, leading to clogs in the drain hose or pump. These clogs may be the reason for why your washing machine won't drain. Here are some steps to help you determine the problem and solution:
1. Pinched hose: Is the drain hose at the back of the washer been flattened or twisted in any area? A pinched hose could prevent the water from draining thoroughly. Gently straighten the hose, and make sure there is sufficient room between the back of the washing machine and the wall to prevent a repeat of the problem.
2. Clogged drain hose or pump:
Does the drum spin normally, but the washing machine won't drain the water? Sometimes a piece of clothing, money, fabric or other debris gets into the water between the inner and outer tub. It may then make its way into a drain hose or even into the pump itself. The farther into the machinery a clog goes, the trickier it can be to remove. Call a repair professional for help.
3. Faulty timer: Does your machine fill with water and begin agitating, but the cycle never advances far enough to allow the water to drain? The timer that controls the cycles may be broken. Arrange for washing machine repair service.
4. Worn or loose belts: Are clothes still soaked at the end of a wash, even though the washing machine appears to go through the spin and drain cycles? The timer that controls the cycles may be broken. This is a job for the pros.
5. Faulty or jammed internal impeller on pump: When the spin cycle starts, do you hear a humming noise? The internal impeller that moves the water through the drain pump may be faulty or jammed. A grinding or grating sound is almost always an indication of a coin, button or other object colliding with the impeller. Have a washing machine repair expert determine if the impeller is jammed and can be cleared, or if the pump needs to be replaced.
6. Pump failure: Is your washing machine more than 7 years old? Your pump may simply have worn out. Even if it sounds as though it is running, the pump may not be working well enough to draw the water out of the machine. Replacement parts for pumps are generally unavailable. A new pump may be necessary.
For more troubleshooting steps, see Washing machine won't drain. I hope this helps!
Oct 08, 2012 | Asko W6021 Front Load Washer
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
HI: My washer will not drain all the water out at the end of the wash can you help me out
Hello there and thank you for choosing fixya
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Aug 04, 2011 | Frigidaire Washing Machines
It won't drain away water.
take drain hose put in pail at ground level if it drains trouble with pump
if no drain try
put a hose in drain pipe hose force water back into machine then see if it drains the plumbing of machine has to cleaned spin tub shall have to be remove to clean
Jun 12, 2011 | Washing Machines
Water won"t drain out. i have taken the front panel off what do i look for.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 24, 2010 | GE Washing Machines
GE washer wont drain or spin, lid switch has been replaced and so has the timer. At the start of cycle it fills and aggitates properly.
If the machine tries to spin for a few seconds and shuts down because the tub is full of water, then - The first thing I would do is check the pump. You may have something blocking the pump or the pump could have failed. Newer models built within the last 10 - 15 years must drain their water down first before they are able to spin.
Jul 28, 2010 | GE Washing Machines
Water runs but doesn't fill tub and wont spin if put on spin cycl
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Jan 09, 2010 | GE WBSE2090A Top Load Washer
G.E. washing machine will not drain completely
It won't drain
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
good luck.....
Mar 28, 2009 | GE WJSR2080V
GE Top Load Washer WLSR2000G3WW~smells like burning and wont drain
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Nov 06, 2008 | GE WBSR3140DW Top Load Washer
Washing machine will not drain
I have a maytag washer that when it fills with water it wont drain out..the spin cycle just makes a noise and it wont do anything..any ideas what i can do to fix it thanks
May 07, 2006 | Indesit W 123 Front Load Washer
Roper RAS8445KQ Top Load Washer Logo
1,060 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
