Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
I have blurry picture.
The problem is that I have like a blue double picture. The problem comes and goes.
    Genius:
  • 2,920 Answers
It could be in the focus control...it may be trying to go out
Posted on Dec 06, 2008
5 Suggested Answers
  • 4234 Answers
SOURCE: Toshiba Tn55x81 frequent convergence problems
If this only occurs occassionally, it suggests that there are bad connections at the convergence ICs rather than defective ICs. If you can solder, try resoldering the pins on the ICs. That may resolve the problem. These ICs are large, black and attached to a heatsink. They will be marked STKxxx.
Keep us posted.
Dan
Posted on Aug 19, 2008
  • 668 Answers
SOURCE: Looks like 3D Picture
You probly have a convergence cicuit failure. Replacing the convergencr IC's will probly fix it.
I recommend a professional repairman to
do it though. Particularly if it needs further adjustments after the IC's are replaced.
Posted on Jun 16, 2009
  • 668 Answers
SOURCE: blurry screen double vision picture
The convergence circuit has failed. It is not a easy fix due to the tear down needed to get to the circuit area. I would call Mitsubishi at 18003322119 to get a Authorized Service Facility to check it out and give you a estimate of repair cost.
Posted on Jun 22, 2009
Slinteriors
  • 8617 Answers
SOURCE: Double Blue Halo Effect and Blurry Blue Picture
thats a problem with the Blue CRTs coolant needing replacement. If you look directly into the blue and green CRTs while its playing you should notice a bunch of crud inside the lens indicating that the coolant needs replacement. You can get the coolant replacement kit for a phillips at the following link which includes the coolant and instructions
http://servicemanuals.vstore.ca/
Posted on Aug 08, 2009
Westinghouse Flat Screen Goes Blurry/has Scrambled Picture
tried first with re seating the lvds cable in the t-con board, the t-con board is mounted covered with metal shield. if can get with fixing the cable, then your t-con board has defective component parts.
Aug 13, 2012 | Westinghouse Televison & Video
Aug 05, 2009 | Philips 60P8341 60" Rear Projection...
Pictures are coming out blurry
On digital cameras it is always best to press the button half way down before taking the picture. This helps the camera focus, thus preventing blurry images. Always, always press the button half way down. Secondly, if you are still getting blurry pictures, there is a possiblity that the sensor in your camera is bad. I don't know how old your camera is or how long you've had it, but you would need to send it for repair, exchange it, or if it's under warranty maybe they'll send you a new one.
Jul 05, 2009 | Sony Cybershot DSCW80 7.2MP Digital Camera...
Blurry screen double vision picture
Jun 22, 2009 | Mitsubishi WT-42311 42" Rear Projection...
Jun 16, 2009 | JVC AV-48WP30 48" Rear Projection...
Double Images
Just click below for convergence repair kit;
Double images and colors are blurry .Blue,red and yellow wave coming up from the bottom of the screen on the lower left symptom is for busted convergence IC,you must replaced this IC in order that will works better again.STK 392-xxx ICs and it's associated resistor,this resistor automatically change value,can caused truoble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is intallation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
Hope this may help;
Regards,
VOTIT
Oct 02, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
Trying to set up a Lexmark 1185 with Vista. I've downloaded the driver and have followed the instructions on the guide pages, but my printing still comes out with blurry picture and words that are...
U get blurry picture and words that are printing double.this is not problem with u r Installation .it is due to print cartridge please check printer with ok cartridges ,it should be working ....
if this information is useful for u please Rate me.............
Jun 15, 2008 | Office Equipment & Supplies
Fuzzy pictures
The blurry pictures are due to movement. Sometimes adjusting the flash helps.
Mar 19, 2008 | Samsung Digimax S630 Digital Camera
Mitsubishi VS-50703 blurry after move
A halo effect usually means the coolant in the CRTs need replacing in the effected color usually blue goes first followed by green. red seems to be less prone for some reason.
Jan 14, 2008 | Mitsubishi VS-50703 50" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
