Question about Amana RanARG7302 Gas Kitchen Range
It Wont Turn On Automatically The Second Time.
I Have And "Amana" And It Wont Turn Back On. When You First Turn It On To About 400 Degrees, It Turns On. Then It's Supposed To Turn Off Automatically, Then When It's To About 300 Degrees It's Supposed Turn Back On Automatically, But It Dosent Turn Back On To Heat It Back Up. What Is The Problem With It?
    Habit-Forming:
  • 171 Answers
Change the oven ignitor.
Posted on Dec 07, 2008
Induction fan comes on ignitor wont ignite
If the igniter turns orange and the gas fires for only a second or two then your heat sensor needs to be cleaned with sand cloth, if it does not turn orange then your igniter needs to be replaced.
Jan 17, 2015 | Amana Gas Furnace 90% Afue 45000 Btu...
Our gas oven will heat to 265 degrees and then turn off. This happens on the bake setting. Even after trying to heat to 400 degrees, it turns off at 265 every time.
The first thing you need to do is check the temperature sensor, which should be 1100 ohms at room temperature (plus or minus 5%). If it is accurate, you probably need to fix the control board. You can send in your board to appliancetimers.com for repair.
Mar 16, 2011 | Whirlpool SF367 Gas Kitchen Range
Ps3 goes to standby mode as soon as turn on
Same here. Just re-flowed it for the second time. Now when I hit the switch in the back it automatically turns on, ejected the game inside, beeped twice, then goes back to solid red. If I try to turn it on it just stays solid red.
Sep 04, 2010 | Sony Playstation 3 (PS3) Console
Amana, ACS3350, gas slid - in range, the oven will not turn
I just had the same problem. I had it repaired and it was the oven ignitor. Labor and Parts $185. I now have an additional problem and I have to call the repair person back. The oven starts up and preheats to temp I set of 350 degrees. Then after awhile it will shut off and after another few minutes the clock will come back on and blink. I will repress oven bake and it will go for a short time and then shut off. I don't know what the problem is yet. I am totaly dis gusted with this stove. The stove is only 8 years old!
Jun 08, 2010 | Amana ACS3350 Gas Kitchen Range
Every time my heat pump turns on, the blue auxilliary light comes on, and it only blows icy air. I do not want to use that much power, so I turn it back down a few degrees. Now, it is 50 degrees in the...
A heat pump starts losing efficiency below 30F or so. The aux. heat helps the heat pump keep up with heat demand. The Aux heat can be electric heat strips or another type of heat. Check to make sure you have power to whatever type of aux heat you have (breaker not tripped, no overloads tripped). If it is electric heat check the heat strips to make sure they haven't burnt in to. Hope this helps.
Jan 10, 2010 | Amana PTH123B25AJ Heat Pump Air...
Amana refrig refrig wont get lower than 42 degrees
that is defrost timer every 8 hrs it turns on heater to defrost evap coils, unless there is major ice behind freezer panel after 1 day which i doubt, that would not be problem ...im trying to go through steps i would take as tech at your house
Jan 03, 2010 | Amana Easy Reach 18.1 cu. ft. Bottom...
Oven temp
after youve cooked at desired temp(400) for allotted time. turn off oven, and restart at 350. it wont start up right away( its already at 400, but it wool drop in temp and cook at 350. good cookin to ya!!!
Mar 23, 2008 | Amana ARGS7650SS Gas Kitchen Range
Oven will not heat past 220 degrees
Check your bake element, I had the exact same problem and found the bake element had burned in half. The broil element comes on during preheat and kicks off at around 220 degrees.
May 06, 2007 | Amana AER5515QA Electric Kitchen Range
Amana RanARG7302 Gas Kitchen Range Logo
96 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
