Deep Fryers
Problem for Deep Fryers
Generic problem for all Deep Fryers
Stopped working
By iaincarpente on Dec 06, 2008
half way through a fry and the lights when out and the oil started to cool. changed the fuse but its not that.any ideas
Comments:
Dec 06, 2008
- BUSH FC043 Deep fat fryer
Same Problem
Jan 29, 2009
-   fryer doesn't light up and stopped working. should I buy new one or get it repaired? help!!-   megan2009
Solution #1
posted on Dec 06, 2008
Somewhat Helpful)
drumbanger
Rank: Wiz
Rating: 85%, 151 votes
sounds like it could be a bad capaciter...will be cheaper to buy a new one then fix look on overstock.com I recomend the delonge
Was this helpful?
Yes
No
Solution #2
posted on Jul 25, 2009
Not Rated)
Capt Rick
Rank: Guru
Rating: 92%, 21 votes
Try the hi limit. Really small red plunger button. Push it in until it clicks. This is a safety device made to trip if the oil temp reaches a predetermined max temp, when it trips, it opens the circuit & will not allow the unit to heat. It will only have two wires going to it.
Comments:
Jul 25, 2009
- Try the hi limit. Really small red plunger button. Push it in until it clicks. This is a safety device made to trip if the oil temp reaches a predetermined max temp, when it trips, it opens the circuit & will not allow the unit to heat. It will only have two wires going to it.
Was this helpful?
Yes
No
Popular Solutions for Deep Fryers
Questions and Unsolved Problems for Deep Fryers
Answer
euro pro 1052 2 litter dose the oil go on top of the element Brand Euro Pro 1052
Answer
The control module will not turn on the socket works and the cord is secure, and the module is... (More)
Answer
I assume the red button that sits directly behind the star deep fat fryer is the high limit switch,... (More)
Answer
no instructions on assembly on 815-4000s
Answer
While unloading our new Masterbuilt Fryer a very small spring fell out. Wondering where it goes and... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Deep Fryers:
Top Deep Fryer Experts
Rank: Guru Guru
Solutions: 901
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Deep Fryer Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
