Question about Asko 24 in. D3120 Dishwasher
Dishwasher fault We have an Asko D3100 dishwasher (2 drawer) which is coming up a F1 fault. Any idea what this means? The symptoms are the motor running in short cycles and the F1 sign flashing. Regards Maureen
  • Anonymous Mar 28, 2014
    Short cycle
  • 52 Answers
F1 Water heating fault, selected temperature not reached within 60 minutes · Incoming water temperature too cool
· Heating element burned out
· Thermostat defective
Posted on Jan 29, 2008
I got this with another dishwasher. On that one it meant the water wasn't feeding into it (tap switched off, kink in inlet tube, etc.)
Posted on Jun 08, 2007
Fisher & paykel fault "F1" is displayed on the top
hello
F1 means the flood sensor senses water at base of machine at PC board.
You need to take out bottom drawer and check for water puddle under where the drawer was.If there is water you can get the machine going again by comletely drying it out(F1WILL CLEAR),but it still means you have a leak.With bottom drawer out you can really see whats going on.Once F1 is clear you can actually run upper drawer and see if it leaks.Most likely culprit are the lid actuators.Replace all 4 . It'll run like new.Don't overload drawer .That can cause lid leak too.Also the PC board may be damaged and may start to go crazy giving fake F1 codes.$80 easy fix.
good luck
Jul 27, 2011 | Fisher and Paykel 23 in. DD603H SS...
Have an f1 error that comes up , says it is a flood switch doesn t seem to be any water in the area around the dishwasher. Any ideas?
The flood switch is at the base of the dishwasher housing under the bottom drawer.
Do you have the F1 fault displayed in both drawers? If so, or if you have single drawer, then turn power off and take the bottom drawer out. Dry the base with towels and use hair dryer on the small circuit board at the base.
Put everything back and turn power back on. The source of leak could be lid seal, kink in hose or ruptured hose.
If you have 2 drawer unit and the F1 error is in top drawer only then the bottom drawer has lost power. Could be due to thermal fuse blown on heater plate.
Hope this helps find the problem.
Dec 22, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Has and F1 fault
HI- The F1 fault means that the Mains Filter board on the bottom pan has detected water, a leak. The only way to stop the fault from constantly running the drain pumps is to unplug the dishwasher or turn off the breaker. You will need to keep the dishwasher off until you get it worked on unfortunately. There are, unfortunately, a few possibilities that can be the cause of this. Most likely it is bad lid motors (the motors that lift and pull down the lid to seal the drawers) or a broken Link Support. This is the plastic assembly that holds all the hoses and wiring out of the way when you open and shut the drawers. A portion of this Link breaks free and gets lodged in between the drawer and the lid causing water to pour out into the lower pan when the unit is running. In this case you will have to have the Link Support and the Lid replaced. The other cause can be someone put really tall plates or a pan in the drawer and the lid couldn't close completely when the cycle started and the water leaked out of the gap between the lid and the drawer.
You'll need to have a Tech out to take a look at it and determine the exact cause. Make sure you use a Authorized F/P tech as these machines are unique. Good luck.
Sep 24, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 fault
Hi . F1 means your machine has triggered the flood alarm. either you have a leak on one of your drawers or water or soap suds has escaped throe the overflow. now the 1st thing to do is turn your machine off at the wall. then leave it for a couple of days to let it dry out. then turn it on and try the lower drawer throe a cycle,if it doesn't go to F1 then try the top drawer. if it doesn't go to F1 then it might be fixed.if it does go to F1 on any drawer then please reply and tell me which drawer it is and i can help you further.
Jun 03, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 in F&P 2 drawer dishwasher
You will need to be a bit more specific when you say "no flood".
Are you having this F1 fault in one or both drawers?
What did the engineer do when he was there last time?
Does the F1 code flash with beeps?
What happens when you turn the mains power off and on after a short delay?
Please provide the actual model number of your fisher and paykel 2 drawer dishwasher.
May 19, 2010 | Fisher and Paykel Dishwashers
I have a single draw Fisher and Paykel dishwasher. I stupidly put washing up liquid in the dishwasher which resulted in a F1 problem. Water started leaking under the draw and onto my floor. I turned the...
ok , F1 means your flood switch has activated, which is underneath the drawer. now they show the F1 fault because of 2 reasons.1st there is still water underneath drawer causing switch to activate. 2nd your activator board which has the flood switch attached is faulty reading your posting it has been about 15 days since the fault happened. the water should have dryed around switch by now. if there is power to the unit and it is still coming up with F1 fault then possibly you have damaged the activator board. please reply and tell me if you have power on or off at the present time. to fix the problem it is alittle bit involved but i can guide you thru it when you reply .good luck
Apr 23, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
I have a Fisher & Paykel Model #DD603 double dishwasher it is coming on with a code F1 with a little wrench Whats going on ?
An F1 fault means that the Mains Filter board on the bottom pan has detected water, a leak. There are, unfortunately, a few possibilities of the cause of this. Most likely it is bad lid motors (the motors that lift and pull down the lid to seal the drawers) or a broken Link Support. This is the plastic piece that hold all the hoses and wiring out of the way when you open and shut the drawers. A portion of this Link breaks free and gets lodged in between the drawer and the lid causing water to pour out into the lower pan when the unit is running. You'll need to have a Tech out to take a look at it, if you can find one. Good luck.
Apr 22, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
My Fisher Paykel dishwasher is flashing F1 - top drawer only. The bottom drawer is working just fine.
F1 error means the flood switch in the drawer is activated. If there is water inside when you open the drawer then you will have to manually empty it with a small container.
Most likely the solenoid that controls inlet water is faulty or the water level sensor is faulty.
Try turning the mains power and water off and on again and run dishwasher. If fault persists then you may have replace the parts.
Nov 11, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
We have the Q 2 drawer dishwasher stopped working.
the f1 is the flood sensor....a leak has accured....either a dish to larger or lid motor has failed. will need to remove bottom drawer and soak up water and then let air dry for a day or two....turn off the breaker this will keep it from beeping and running the pumps....after drying unit will run, but need to watch the dishes you put in drawers.
Jun 30, 2009 | Fisher and Paykel DD605HSS 23 in. Built-in...
Fisher & Paykel dishwasher:
Turn off dishwasher's circt braker at distribution panel (usaly located in garage or in basement)
1. Open lower drawer
2. Push in two plastic buttons at front lower corners.
3. Remove drawer from railing
4. Remove water from bottom of dishwasher
5. Use hair drier to dry off bottom copartment, specialy in left corner at floding switch location.
6. Install drawer on the rail in position when plastic buttons pup up
Mar 27, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Asko 24 in. D3120 Dishwasher Logo
711 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Jose Pino
Marvin
Marvin
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
