Question about SanDisk Sansa e250 MP3 Player
Frozen i deleted all of the files on my mp3 using musicmatch jukebox and now my computer can detect it but it says that it is not working properly and when i go into my computer it will show that two usb ports are taken up instead of one and both of the folders are empty and i cant do anything with them, create new folders, transfer other folders/files.it is near new and my other mp3 is just too small for my uses. also when i unplug it the screen on it still says it is connected and is frozen until either it runs out of batteries or i remove it manually. i tried downloading raphsody due to another related solution who said to use raphsody to rewrite the program or something but since my computer cant detect the mp3 anyways it didnt work. i tried too, not just assuming it wouldnt work. maybe if you have a solution or detailed instructions on what to do with the raphsody program it would be much appreciated! thank you very much!
Use MSC USB mode!!!
Posted on Feb 17, 2007
SOURCE:
I have Musicmatch Jukebox 10 but have just changed over to Windows 7.I have a Packard Bell Hard Drive.How do I update from xp please ?
Musicmatch Jukebox 10 is not compatible with windows 7 >>
http://www.microsoft.com/windows/compatibility/windows-7/
MusicMatch Jukebox 10 was designed to be used on older 32-bit operating systems like Windows XP.Note that MusicMatch Jukebox 10 is also no longer being developed, so it is unlikely that these problems will be resolved in future.
Before proceeding with installation of Musicmatch Jukebox 10, you need to look on your Windows 7 PC for any previous versions of Musicmatch Jukebox. If you've already tried installing version 8, for example, then you need to run a complete uninstall, not to mention a good clean up of the registry.Use Revo uninstaller to uninstall and clean any registry trash ,revo uninstaller can be downloaded on the link below:
http://www.revouninstaller.com/revo_uninstaller_free_download.html
Once you have done this, or if you had no earlier versions of Musicmatch Jukebox installed, you will need to download and install the only suitable version.Download and Install Musicmatch Jukebox 10 on Windows 7 >>http://musicmatch-jukebox.com/
Once downloaded, right-click the installer file and select Run as Administrator. Next, you will need to OK the first of many warnings that the file is incompatible with this version of Windows.Proceed through the installer, clicking Next at each option.When you come to the registration page, click the option to not register and also claim to be under 13. Click Next to complete more steps of the installation, changing the location required for your Music folder if necessary. Musicmatch Jukebox 10 will add files and playlists to this location.As the installer finishes, you will be prompted to install the Yahoo! toolbar. You will need to deselect this.A successful installation should result in more incompatibility warnings. Ignore these, but agree to reboot your PC. Next right click Musicmatch Jukebox icon and select properties > compatibility >check run this program in compatibility mode for: (Windows XP) click apply ->ok.
Nov 13, 2011 | Audio Players & Recorders
I cant use Music Match jukebox on my new PC. Why?
  1. Verify that your music is in the MusicMatch Jukebox Plus folder on your hard drive. Double-click the "My Computer" icon on your desktop, or select "My Computer" from the Start menu. Open the C:\\ drive. Double-click "MusicMatch Jukebox." Review the folder to check that all of your MP3 files are inside the folder. If not, search your computer for the files and drag them to the MusicMatch folder.
  2. Turn on folder sharing to ensure the software can access your music files. Open "My Network Places" in the "My Computer" folder. Click "Properties." In the resulting window, click "File and Print Sharing." Check the box next to, "I want to be able to give others access to my files." Click "OK" and close all open windows before restarting your PC.
  3. Check that you have permission to play the specific MP3 files if you are having playback issues. Occasionally, songs purchased through the Yahoo! Music online store using MusicMatch Jukebox Plus have faulty digital rights management (DRM) protection. Burn the file to a CD and then rip the song from the CD as an MP3, which removes the DRM protection and allows the software to play it without restrictions. This is your only recourse, as the MusicMatch store no longer exists. Previously, you could have contacted MusicMatch's customer service to have the song reissued.
  4. Reinstall the MusicMatch Jukebox Plus software. Click the "Start" menu button in the lower left-hand corner of the screen and select "Settings." Open your "Control Panel" and double-click the icon named "Add/Remove Programs." Locate "MUSICMATCH" in the list of available programs and click "Uninstall."
  5. Insert the MusicMatch Jukebox Plus installation disk into your computer's disk drive and follow the on-screen instructions to install the software again. This may resolve problems involving faulty computer files and corrupt Windows Registry data.
  6. Clean any CDs you are trying to rip or record to using the MusicMatch software. Disks with unclean surfaces involving dust or fingerprints are some of the most common reasons for faulty MP3 ripping or poor audio when recording CDs. Use a specialty disk cleaning cloth or a cloth intended for cleaning similarly sensitive accessories such as prescription eyeglasses. Wipe the disk from the middle toward the edge.please rate and comment on this product just by saying how helpful it is.raise the thumb up
Dec 21, 2010 | Computers & Internet
My Musicmatch Jukebox, can't detect an internet connection
This is from musicmatch:
To prevent MUSICMATCH Jukebox from requesting a connection to the Internet, do the following:
- Open MUSICMATCH Jukebox.
- Click the "View" menu.
- Click "My Library".
- Click the "Options" menu.
- Click "Settings".
- Deselect the options under "Permission to communicate with MUSICMATCH server".
- Click the "CD Lookup/Connectivity" tab.
- Disable the CD lookup service.
So maybe the disbable the cd lookup service is on. Just a thought.
OR
Has any MMJB subscriber found another music program that permits line-in recordings, similar to MMJ
Nov 06, 2009 | Computers & Internet
How to record music from the computer with a SA2325 MP3 Player. Send me the steps to follow. Thanks
Overview of online support for SA2325/02 ( GB ):
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA2325/02&slg=en&scy=GB
Link to the user manual:
http://www.p4c.philips.com/files/s/sa2325_02/sa2325_02_dfu_eng.pdf
Music files MP3 or WMA
Music transfer can be made seeing the player as a USB mass storage device in Windows Explorer, exploring the drives on "my computer": the player should show up as a drive letter with about 2 GB of memory.
The files must have the format and extension as shown on page 17 of the manual:
• Compression format: MP3 / mp3 (8-320 kbps
and VBR; Sample rate: 8, 11.025, 16,
22.050, 24, 32, 44.1, 48kHz),
WMA / wma (64-320kbps)
• ID3-tag support: Song title and artist name
Transferring songs from the computer to the player
After exploring the appropriate music files on the computer, the songs can be dragged and dropped to the memory of the player: read the blue
tips on page 11 of the manual.
Always disconnect the player safely after transfers, see point 3.4.1 of the manual on page 11.
Audio CD converting to mp3 / wma format: RIPPING
When wanting to convert audio CD's to files that can be played on the player, you could use Windows Media Player 11 or MusicMatch Jukebox using the RIP utility.
  • For WMP 11: update your Windows operating system.
  • When using XP MusicMatch Jukebox 10 can be downloaded from next site:
http://www.soft32.com/Download/Free/MusicMatch_Jukebox/4-277-1.html
Right click on the download file under Soft32 Mirrors and select "Save target as..." Rember the download location for executing the file later, having the MusicMatch Jukebox installed.
Need more help ? Just post a comment.
Oct 17, 2009 | Philips SA2325 (2 GB) MP3 Player
I installed IE8 and now jukebox does not come up
I would upgrade to the latest version of Musicmatch.
Jun 28, 2009 | Musicmatch Jukebox 7.0 (1575956454) for PC
Dell jukebox on my computer
By "Jukebox", do you mean MusicMatch Jukebox?
If so, you can download it here http://www.download.com/Musicmatch-Jukebox/3000-2167_4-10020670.html
Apr 21, 2008 | Dell Dimension 4600 PC Desktop
Have rca lyra mp3 , but on cd with it
If you have Windows XP you need to download Musicmatch Jukebox in order to transfer music. Google it. You will probably have to pay for it. However Musicmatch Jukebox does not work with Windows Vista. If you have Vista, you can use Windows Media Player to transfer music to your Lyra. The Media Player automatically comes with Windows Vista OS. Of course, you need to connect your Lyra to your computer using the proper USB cable, so your computer must have a USB port.
-Potter4
Dec 10, 2007 | RCA RD1076 MP3 Player
How the heck do i download my cd's to this darn MP3 player ???????????????
I hope you have Windows XP. Download Musicmatch Jukebox (google it). Open up Musicmatch Jukebox and on the left hand side is a link to download songs to the MP3 player. Click on the link and follow the directions. Musicmatch Jukebox does not work on Windows Vista (yet).
Nov 05, 2007 | RCA RD1076 MP3 Player
PSA250/17 doesn't show the songs that I have put on it!
I was having the same problem with my PSA250/05 but found out how to resolve it.
As the PSA250 converts the files into it's own naming algorithms simple dragging and dropping mp3's work work as the device doesn't recognise them.
Inside musicmatch Jukebox you will find a portable device options section. In here under one of the options you'll see the mp3 device which is in a drop down box. If you click this box you'll see that you have another option for Nike + Phillips, select this option and now add your tracks.... All should be fine.
MOPSTER
Oct 15, 2007 | Philips PSA250 MP3 Player
Seeing files in musicmatch jukebox
Musicmatch is now cancelled - Oct 2007
Jan 23, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
