Question about Nilfisk GD 930 Canister Vacuum
Nilfisk GD930 vacuum-can't find replacement brush
I'm trying to get a replacement for the little round brush that came with the vacuum. I have been to numerous websites and most don't have pictures. I went to the Nilfisk site and got the part number, ordered it, and it's a round brush alright, but has two prongs that need to insert into a tube and they are bigger than the tube on the vacuum, so the part is useless. Anyone know a part number for the little round brush accessory that came with the original purchase? And where to get one?
  • 706 Answers
Hello mddamus,
Try this link to a Nilfisk supplier, speak with a rep and they should be able to identify exactly what you need and provide that part for you.. http://www.nilfiskcfm.com/ProductAcc.aspx?m=15
Regards,
Rick
Posted on Dec 06, 2008
How do I put a new wheel on nilfisk a300
by the picture of the
nilfisk a300 replacement wheels
its a pull off clip on type design
the axle should be metal
it will need some force to remove the old wheel
may even try to break the old wheel off in pieces
Sep 07, 2016 | Nilfisk Vacuums
Why is red light on my Nilfisk Orbit vacuum cleaner on ?
[PDF]Nilfisk GM80 and GM80i Vacuum Cleaner User Manual ...
www.sylvane.com/media/.../nilfisk-gm80-vacuum-cleaner-user-manual.p...
Troubleshooting. Loss of Power. 5. 6 ... CAUTION: This Nilfisk vacuum cleaner or any other vacuum cleaner is not to be used in explosion-hazardous areas, as ..
Sep 19, 2015 | Nilfisk Vacuums
My Nilfisk GU305 cuts out after a few minutes use
You are probably right. There is not enough air flow around the motor. It uses the air from the vacuum as the cooling air.
There is a secondary filter after the first filter bag. You may think the bag is not full and don't think you need to change. Sometimes the material you vacuum is so fine that it will clog the filter bag. I've done it vacuuming sheetrock sanding dust. Then just below the main filter is the secondary filter. Depending on the age and amount of use, there could be other problems. Motor brushes about to fail. A wire connection that separates as temperatures rise. Then reconnects when "cool". Plug end may be a problem. Its connection to the switch. The switch it'self could be.
Mar 21, 2015 | Nilfisk Vacuums
Nilfisk king 500 motor noisy and smelly
contact brushes are dying, try wd40 if it continues repair shop!
Nov 02, 2014 | Vacuums
Power keeps turning off on Nilfisk vacuum
What kind of vacuum is this? If it is a pushbutton switch you may need to replace the switch.
Oct 24, 2013 | Nilfisk Family Vac Bagged Canister Vacuum
Nilfisk vacume bearings
Hi There, If you could provide the model number of the machine that would help. However as a general rule if it is the motor bearings you are after then normally you replace the entire motor. If it is the roller brush you are needing bearings for you can get them from any bearing supplies store. If you are looking for any nilfisk parts in Australia then vacuumspot is the go.
May 27, 2012 | Vacuums
UNIT RUNS FOR APPROX 1 MINUTE THEN CUTS OUT AND WILL ONLY RUN ERRATICALLY
It could be a few issues. It could be a thermister switch, carbon brushes or electrical. you could take it to a repair shop with free estimates. This way they will diog. the problem and might be able to save you some $$$$$
Nov 10, 2009 | Nilfisk GM 80 Bagged Canister Vacuum
Vacuum emitting strong odors when it's on.
Hi there SmartAlec from NelsonVacuums.com.au here. I am a nilfisk vacuum agent and although i havent actually worked on one exactly the same as yours there are no Nilfisk with any kind of washable filters at all. I think you will have to replace it. If you are in Australia i can check out the cost of replacement filters for you just drop me an email with the exact model number.
Hope this helps.
Happy Vacuuming :)
Aug 31, 2009 | Nilfisk Family Vac Bagged Canister Vacuum
My filters? need cleaning
most likely the hose is blocked, drop a coin down it to confirm. You are best to replace the filters, they are not very expensive; though they are not likely to be the cause of your nilfisk over heating
Sep 26, 2008 | Nilfisk Family Vac Bagged Canister Vacuum
Nilfisk GD 930 Canister Vacuum Logo
244 people viewed this question
Top Nilfisk Vacuums Experts
Jim Parker
Jim Parker
Andrew Taylor
Andrew Taylor
Thatvacguy.com
Are you a Nilfisk Vacuum Expert? Answer questions, earn points and help others
