Question about RCA P60920BL 60" Rear Projection Television
Colors off Had to pull the guts out of my 20 year old RCA 60" projection TV to get the power supply replaced and then again to move it. Slid the guts back in the cabinet and now the colors don't line up and the picture is not perfectly centered anymore. The blue is off to the left. Is there an adjustment for this?? I can only find focus adjustments for each of the colors and it looks like the blue just needs to be tilted slightly.
  • 1 more comment
  • psolar Dec 06, 2008
    Can you help me with the convergence controls?? Where are they? The only adjustments I see focus each of the colors.
  • psolar Dec 07, 2008
    Thanks!
    I found the maze of adjusters, set them to center positions and went through the convergence steps 3 times but I can't get the blue right. I still have dual "blue" images mainly on the top with the blue stretched and bending in an ark. Is there a trick to this?
    I keep playing with it and it is getting better but I still have the halo effects mainly in the corners. I take it that there is no real "system" for this. The controls are numbered so I'm adjusting them in sequence. Can I assume the object is to get all the colored lines to merge or am I thinking about this the wrong way?
  • 979 Answers
You say you have "dual" blue images: If this the case, you'll have to repair the blue convergence first before being able to properly setup the rest of the alignment...accordianman
Posted on Dec 07, 2008
  • 979 Answers
Set all convergence controls to center and then manually set all tubes to as close as possible to coincide with each other. Then, use those electronic potentiometers to fine tune the picture.
Posted on Dec 06, 2008
  • Michael Borelli Dec 06, 2008
    This set may have controls that are actuated from the remote. I don 't have the manual in front of me right now. The front panel convergence controls are generally "hidden" behind a panel on the front of the set as a rule...accordianman
  • Michael Borelli Dec 07, 2008
    Typically, you'll set the green as the master; Making it as symetrtrical as possible and then set the other two colors to it.....accordianman
60 INC RCA PROJECTION CURVED PIC. TOP BOTTOM
This problem is caused by a faulty Convergence amp. This amp keeps all three colors aligned together and square on the screen. It could also be the power supply section that supplies power to this amp.
A local TV shop should be able to repair this for you for about $350
Jan 06, 2010 | RCA Televison & Video
Convergence issue-60 inch RCA projetion TV
it is under set up options in the menu
Oct 16, 2009 | Televison & Video
RCA HD52W59 Projection Big Screen TV
you have cold solder conections if you know how to solder you can fix it with a good light
Oct 14, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
This problem is commonly refered to as a CONVERGENCE problem. Question 1 do you have convergence seting in setup menu...if you do NOT it could be a special small fuse. 2 if you go into setup then convergence. then can you move crosshairs in setup. Since you have a arcing picture this indicates convergence power supply problems....in which has to be replaced or repaired,
May 09, 2008 | RCA HD52W59 HDTV Projection Television
60" RCA PROJECTION TV
my tv is 12 yrs old it started with the color starting to fade and then it started cracklin real bad and now theres no pic but there is sound
Dec 29, 2007 | RCA P60921 60" Rear Projection Television
Convergence
Color tubes are OK. Do not adjust. The issue at hand is called
convergence alignment.The repair involves-------
1)Pull chassis
2)Replace convergence IC's
3)Recheck alignment
work should be done by a skilled technician........T.
Oct 24, 2007 | Philips 60PP9202 60" Rear Projection...
Rca home theatre big screen tv
If it is truly a 52 inch standard projection set (you have it listed under 32V420T which is not a projection TV) and your 3 colors (red, green and blue) are no longer lining up and are all curved on the sides, then it means that your convergence power supply has stopped working. Post the actual model and chassis number and a better description of the picture here and I will be able to assist you further.
Aug 07, 2007 | RCA 32V420T 32" TV
Hourglassing
This problem is the "pincussion" setup on the convergence board. It, however can be caused by a failing power supply. If the set takes more than 60 seconds to produce the picture and up to 10 minutes to fully produce a good picture, even with the problem, power supply. Most likely if it does not do the mentioned it is the pin amp on the convergence board.
Apr 27, 2007 | RCA P52930BL 52" Rear Projection...
Televison & Video Logo
119 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
