Foxconn 661M03-G-6EL Motherboard
No sound
posted by lockey on Mar 02, 2007
Can't get the on-board sound to work. I have enabled it in BIOS, and downloaded/installed the latest drivers but no success. Any idea's?
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Mar 02, 2007
Helpful (85)
tomj23
Rank:Guru Guru
Rating: 86%, 1618 votes
Without knowing what else you?ve tried besides checking the BIOS configuration I?ll just list everything including the basics:
-Check the hardware device manager and ensure your sound card shows up and is running without errors.
-Make really, really sure you plugged the speakers into the right socket.
-Try plugging a known working pair of headphones or other simple speaker system into your sound socket to verify your speakers work.
-Open the ?sounds and audio devices? in the control panel, in the volume tab make sure the volume is mid way and not muted.
-Click on the advanced button and make sure the wave, SW Synth CD Player volumes are mid way or better and not muted (the volume is the same as the previous volume slider).
-Make sure your driver came from the motherboard manufacturer and you have the right one for your operating system.
If you get here and it still doesn?t work then you?ll need to start considering the possibility that your motherboard may have a problem. As an alternative you can disable it in the BIOS and plug in a cheap PCI sound card.
Let us know how it goes and please don?t forget to rate this post.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on No sound:
I don't want to Accept this solution
Can you Help with these Motherboards problems?
Motherboards
I can't find a motherboard manual so I know the pin layout...
Motherboards
Got motherboard from a friend with two matched CPU''S but...
Motherboards
i dont cant intalation of driver unknow for sony vio model...
Motherboards
HP d550 cmt (dc577av) Intel Pentium 4 2.53 XP Pro I...
Motherboards
this board has like 2 places for usb and about 16 pins i...
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Repair Service
Find Motherboard Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
