SOURCE: 2002 sequioa sudden stall
Often when the battery is disconnected or replaced the computer will lose it's learned idle settings. You could try letting the engine idle in park until the engine temperature comes up to normal and leave it like that for a few minutes, then put the Air con on and let it idle again for a few minutes, then switch the air con off and put it into drive. If it does not stall, let it idle in drive for 2 minutes or so, and then do the same with the Air con on. This should relearn the base idle settings and stop it from stalling on you. Before you carry out this procedure you should make sure that when you replaced the battery you didn't remove any other plugs or knocked anything that may be causing the fault. If you try this procedure and it still stall when you select drive, you will need to get a Mechanic to check the vehicle over.
Hope this helps,
Mark.
SOURCE: Chevy dealer said that 3.4L
Hi there... Both the fwd and awd have the same towing capacities of 3500Lbs. Hope this helps you out
SOURCE: Front turn indicators don't work, on 04 Cadillac SRX
you may want to check the fuse for the signals and asfor the locked windows, it sounds like your window lock has either seized or the button is off track. In any case, replacement would be the best option.
