Question about Singer 5160 Mechanical Sewing Machine
Motor turning but needle not moving
Hello I need some help in determining what is exactly wrong with my machine and what i can do to fix it. I have singer 5160 and it is brand new just got it today, it will sew fine for a few then it slows down and then the needle stops moving but the motor is trying to move it, so it makes a growling noise. Please help me, im sew confused?!?!?! Thanks for all help
SOURCE:
SOURCE: singer merritt 8834 sewing machine slows then stops
If you still need the Manual E-mail me @ goldengoose001@yahoo.com be sure to put in comment part of e-mail something Like "Looking for a singer 8834 manual" as I delete all e-mail without reading them unless I know the person or what e-mail is about and know its safe , and even then I scan all and report any found to have viruses , etc
Posted on Aug 15, 2008
  • 69 Answers
SOURCE: Singer Touch & Sew won't loop bobbin thread
I believe you have a broken gear. These are difficult to repair on your own.
Posted on Feb 12, 2009
  • 10865 Answers
SOURCE: I replaced the needle of my machine and now it wont sew
http://www.singerco.com/accessories/manuals.html
go to this site to get the manual. please mark this answer as a fixya
Posted on Feb 27, 2009
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
SOURCE: singer quantum cxl sewing machine needle hitting metal
Your needle is probably to long or you need to open it more
Posted on Apr 08, 2009
On my singer serger-i think i cranked the hand wheel the wrong way, now it won't move needle, when i turn machine on and press foot pedal motor runs but needle doesn't move, how can i fix it?
Force it in it's correct direction of travel using the hand wheel. My dry cleaner with 4 machines had me force one of hers. She said you can't break them.
If there is a lock in the centre of the hand wheel, make sure that is tight and you aren't in bobbin winding mode.
Jun 12, 2018 | Singer Sewing Machines
Janome mc5200 sewing machine E3 code need to fix it myself. Cannot find it in my instruction book
Hello Dear Jeff Moore!
greeting
FYI......
Needle bar is out of position. Press OK to move the needle bar to switching position. (Needle bar change over phase.) 3. Remove the stationary cover then turn the hand wheel to 270°. Using a 2.5mm hex driver, turn the silver gear on the needle-change step motor to move the head from needle bar #1 to #4 then back to #1 to check for any binds. If there is a bind, adjust 'head play' as shown in the service manual. 4. Check and adjust 'moving head stop position' and 'needle stop position' as shown in the service manual.
May 23, 2018 | Janome Sewing Machines
Have an old basic model Kenmore machine. Motor sounds find, but needle moves very slowly. Cleaned and oiled, no help. What could be wrong, and how do I fix
Did you thoroughly oil? Sounds like it has seized because old oil is preventing the parts from moving. Refrain from trying to run the motor until the problem is addressed or you could damage it.
Wheel on right side that controls the needle up and down is very tight...
Apr 26, 2018 | Kenmore Sewing Machines
I don't need help with a washing machine, it's a sewing machine!
Looks like an older mechanical machine--looks very similar to a Bernina I have. Hopefully nothing is broken or out of alignment that would cause this. Refrain from forcing the motor to run while the machine's parts will not move freely or it could damage the motor.
These are great machines, however, they do need maintenance to keep them operating smoothly. They are very prone to seizing when the old oil dries and turns to varnish, thus preventing the parts from moving efficiently. Here's the method I've use to fix several older machines that suffered from this problem. The problem can affect any moving part of your machine, ie the needle bar, the selector knobs/dials/levers, the feed dogs, the handwheel, etc.
Jul 13, 2017 | PfaFF Sewing Machines
Kenmore 158.1703 sewing machine - needle not going up and down
Sounds like your worm drive gear is striped and needs to de replaced. If you twist the handel on the end of machine does the needle move up and down.
Jan 03, 2010 | Kenmore Sewing Machines
Sewing Machine Motors Runs But Needle Does Not Move
Probably the belt tension needs adjusting, it is slipping like a car fanbelt and needs the same relative "give" when correctly tightened.
Remove the side cover where the handwheel is and loosen the motor fixing to adjust and increase the tension on the belt ....needs some slack, if you can move the belt 10mm with light pressure then it will be fine NOT TOO TIGHT or you will overload the motor. NOTE: If the side panel is not easily removed, ie 2 piece casing split in the middle, take it to a service centre or risk breaking the casing trying to get in....if it is more than a few years since last service, let someone do it all and get a sweet machine back, with no risk for not a whole lot of time or money
Aug 22, 2009 | Sewing Machines
When I turn on my PFAFF 1222 it wont sew
It may be in bobbin filling mode. Can you turn the inner circular on the hand crank. If you can click it into position, this should engage the needle mechanism.
Jun 14, 2009 | PfaFF Sewing Machines
The needle wont move at all?
Hello we had the same problem with our sewing machine. After playing with it we found there is a bobbin winding assembly lever that moves back and forth. By moving it the needle moved. This helped us. Hope it helps you. embreyR97@yahoo.com if you have questions.
Jan 05, 2009 | Brother XL-5130 Mechanical Sewing Machine
Very old Necchi sewing machine - sews in place
sounds like the feed dogs may be down or not working. Watch to see if the little teeth are moving under the pressure foot when you stitch( try to run unthreaded and with foot up no fabricto check) May be a button to turn up the feed dogs.
Oct 27, 2008 | Necchi 3101 Mechanical Sewing Machine
Needle broken in the needle-slot
Can you please tell me what brand name and model the machine? I need to determine how the needle is normally held in place and how you usually release the needle. I have a couple of ideas but having a little bit better picture of the needle holder will help me provide you the best solution. Thanks
Jan 04, 2008 | White Sewing 2037 Mechanical Sewing...
Singer 5160 Mechanical Sewing Machine Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
