Question about Cameras
I drop my camera while the lens was out and when it droppped the lens bent in and now it cant close. i cant do anything to with it.
    Genius:
  • 1,199 Answers
Try needle nose plyers to bend it back.it will not be covered under the warrenty and will cost more then the price you paid to fix! or better use your hand be firm but gentle once lined up it should be fine
Posted on Dec 06, 2008
The lens want close due to being bent
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
Jan 09, 2010 | Sanyo VPC-E760 Digital Camera
Drooped camer now lens stuck
These cameras are easily broken by dropping them. Try to free it by hitting it easy at first, not too hard, you don't want more damage to it? Option number two is to take it to a camera shop for repair estimate. They will try what I'm telling you and chage you a lot if it works.
May 27, 2009 | Canon PowerShot A470 Digital Camera
The lens wont close and it keeps saying on screen "lens error restat camera" but when i turn it back on it doesnt do anything
Your lens frame - that which moves out when the camera opens is probable bent. Looking down at it from the top and sides, does it look bent? By grasping is firmly but not hard try softly to bend the lens frame in the opposite direction, carefully.
Feb 19, 2009 | Canon PowerShot A430 Digital Camera
Lens wont close.
did you try and take the battery out and outting them back in
might be worth a try
Feb 08, 2009 | Canon PowerShot SD850 IS Digital Camera
Camera dropped, lens won't retract or expand
You can buy a new A590 for under $110 these days, so the professional repair option may be out. Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 24, 2009 | Canon PowerShot A590 IS Digital Camera
CAMERA TURNS ON FOR A SPLIT SECOND THEN SHUTS OFF
My Z1275 was off with the lens open. When I turned it on, the lens moved a little, the screen came on
for an instant, and then the camera off.
Here is what I did to "fix" it.
I turned it on and helped the lens (gently) close while it was moving. It closed and the camera came on.
It must have been dropped and slightly bent in such a way where the lens could not close.
Good Luck!
Dec 29, 2008 | Kodak EasyShare Z1275 Digital Camera
Lens problem
Dear Customer,
When you say the lens barrel is bent, do you mean that the camera won't turn on ?, or the lens barrel is just bent and it looks outlandish. However if it's not turning on follow these steps:
1) Try to gently re-position the barrel, and make it more stortionate.
2) try to recharge ( or get new batteries ), and see if the lens will withdraw.
Unfornately, when you drop a camera, many warranties are voided, and you have to pay to have it fixed, but i doubt it would be that much money to fix.
Please rate this solution.. Thank You..
Jul 11, 2008 | Casio Exilim EX-S500 Digital Camera
I dropped my camera
idk i have tht same problem and i just got my camera
i droppped it on the bathroom floor
Nov 13, 2007 | Nikon COOLPIX L3 Digital Camera
Bent lens.
The complete service manual costs US$21.00 and we can upload. The Lens block may be expensive at US$120.00-3 weeks and needs confirmation. Regards, Siva
Sep 21, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
