Question about Onkyo TX-NR801 Receiver
Rear left channel not working on Onkyo NR801
There is no sound coming from my rear left channel. First, the sound was intermittent. Now, there is no sound coming from that speaker at all. I've ruled out wires and speaker because when the same wire and speaker are attached to a different channel, they work fine. What could be causing this and can this be fixed myself or outside cheaply? Unfortunately, the receiver is out of warranty. Please help. Thanks in advance.
  • 979 Answers
Sounds as if it's time for a shop visit, unless you want to try this yourself. The panel connection on the rear of the receiver, or the protection relay have apparently come loose from the circuit board. It happens sometimes when stress causes the cabling to pull on the back of the unit..accordianman
Posted on Oct 31, 2007
No surround sound on rear speakers and cant access speaker set up functions. left front channel not working when rears set up without surround
from the problem description, it sounds like a wiring/setup problem with the speakers. check to make sure you are only using the main 'a' front r & l speaker connectors. if you select speaker set a + b on the front, you will not have the rear channels. please see the speaker connection guidelines in the manual on page 13-15. make sure the audessey mike and/or headphones are not plugged in when trying to use the speaker set up function.
manual: http://www.uk.onkyo.com/downloads/1/1/9/7/8/21637363_df4adc7f5e.pdf
Jan 21, 2015 | Onkyo TX-SR307 A/V Receiver
Onkyo TX-NR801
is the mute indicater displated on the screen.
Jul 12, 2008 | Onkyo TX-NR801 Receiver
Onkyo HT S3300 center, left front and rear speaker not working.
check your speaker wiring, make sure both terminals are connected properly. or could just be left speaker is disconnected. and is set in stereo mode which will only play left and right front and Sub, if you have one. try chaning the surround mode to play in multi channel speaker which will send sound to all speakers. i trust your using a Digital audio cable from your source ( cable box, DVD player) if your using analog audio cable you will only get stereo sound, and nothing will ever come out of the rear speaker unless you change the surround mode to multi- channel speaker. also in the setup menu you should be able to perform a speaker setup, make sure all your speakers are able to produce sound. follow speaker setup mode in menu, make sure you have checked the boxes or Yes to speaker you have in your system. then perform calibration and a test tone will come out of each speaker as you select them.
Apr 28, 2011 | Audio Players & Recorders
What Blu Ray to buy for ONKYO TX-NR801 for Dolby TrueHD, etc???
Hi, as the Onkyo receiver you have does not have HDMI switching, the only thing it will do for you with a Blu-Ray player is process the audio signals.  The video from the BR player will have to go directly to an HDMI input of your hi def TV.  In this case, either Sony or Panasonic BR player will be equal.  Assuming you keep the Onkyo unit you have, you would want to use the optical digital output from the BR player as the audio source into one of the optical, digital audio inputs on the Onkyo.  In an ideal world, your receiver would some that does do HDMI switching.  This way, all the audio and video signals from any audio or video source would be automatically switched and channeled through 1 simple HDMI cable into your hi def TV.  This will make you life simpler as ther would be no need to select an appropriate input on the TV, as well as one on the receiver.  That said, buying a new receiver in addition to a BR player is more costly.  Good luck.  Let us know how it goes.
Jan 02, 2009 | Onkyo TX-NR801 Receiver
Audyssey won't initialize the left rear channel speaker input during set-up
had the same problem found that the rear speakers were connected to the wrong inputs on the receiver, try changing them i think you will find that this will work
Aug 28, 2008 | Onkyo TX-SR605 Receiver
Onkyo 605 Reciever no sound from zone 2 RCAs
did the AS amp ever work properly from the RCA's?
Dec 05, 2007 | Onkyo TX-NR801 Receiver
Onkyo tx-nr801 net tune setup help
Below is the sequence that I made it work
1. download the latest firmware for tx-nr801 and net-tune central software at Onkyo website as shown below:
http://www.intl.onkyo.com/products/net-tune/download/index.html
Click on "User Identification" at the bottom
(You'll need the serial number shown at the back of TX-NR801
to download it)
2. disable firewall in your PC or notebook and start
updating the firmware for tx-nr801
If firewall can't be disable, you probably can't go through this.
This step takes about 30 min.
(There is a document showing how to do this with the download)
3. keep disabling firewall in your PC (notebook) and install net-tune central (there is similar document describing the procedure too)
4. By pressing Net-Audio on remote controller (it can switch between mServer and iRadio fucntions if you keep pressing this button)
Nov 15, 2007 | Onkyo TX-NR801 Receiver
Left rear surround channel sometimes doesn't work
If your receiver has speaker protection relays and they are intermittent due to bad contacts you might be able to repair them if they are not sealed. Most are but take a shot. They make small files for this purpose. Replacing them can be daunting because yo may not have good access. Tap the relay with the receiver playing and see if it helps.
Aug 26, 2007 | Onkyo TX-DS696 Receiver
NO surround sound coming from our harmon/kardon speakers when set up to our onkyo tx-sr601 receiver. wires connected in correct areas, front left, right and center speakers work, subwoofer works. setup for...
So your saying that you have no rear channel. Some recivers use a single stereo output ic for both sides on the rear speakers. you could have a defect with this IC . Anther thing Im sure you check3ed the obvious ie : the switch is on suround sound? If there is a front to rear fader is it in the middle? Good Luck
Jun 04, 2006 | Onkyo TX-SR601 Receiver
Onkyo TX-NR801 Receiver Logo
263 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
