Question about Symbol PPT 2800 Portable Terminal
I have apocket pc symbol scanner not work i dont know why
Scanner lazer does not come on
The way the scanner reacts to the buttons depends on the software that is installed.
But the fault you are describing tends to be the scan head flexible cable is broken. i can fix it. please send it to Pen Mobile via Google search and quote my name David Germain.
David Germain
Mar 13, 2013 | Symbol PDT 3100
Is there a driver for barcode scanner i am holding Model No - LS1902T-1000 company - symbol tech inc. hotsville n.y.
The barcode scanners are usually using ans Standard PS/2 or USB interface in the same way as keyboard, therefore you dont need an driver.
You would probably need to setup the barcode scanner according to the used connection/interface.
Here is the manual for yur scanner
Jul 08, 2010 | Symbol LS2208 Handheld
Need a users manual
Hello, You will get the reference guide for your Symbol PPT 8800 scanner in the following link. Hope it helps, Good luck! ~regards, Jegan
Jun 03, 2009 | Symbol PPT 8800 Wireless Barcode Scanner
it can work with ether of them mainly then driver is needed. so i hope that is the answer you wanted and please rate the help i have been to you.
Apr 21, 2009 | Symbol LS 2208 Barcode Scanner
When the unit comes on, it asks for a pass word
Default password for Symbol is: Symbol
I am a Barcode Tech let me know if this works otherwise I will look into this matter more for you
many thanks
Nov 20, 2008 | Symbol MC7094-PKCDJQHA6GR Barcode Scanner
How can I download the data from de Symbol PDT 3100 to a PC?
We hava a Symbol PDT 3100 barr reader. It worls properly picking up bar codes fron our inventoy, however we don´t know hoy to dowload them to a PC. ¿Is there a software or configuration to download the data to a PC? Thanks for your help Jos? jalal
Aug 04, 2008 | Symbol PDT 3100
Symbol Spark LS 1004 Problem
What barcode scanner do you have? USB, SERIAL or ps2.
by the way. the old computer is it like NCR, SIEMENS or IBM because then you need to re-program your scanner.
i found a manual where you can set your pc type with barcode scanner. be careful not to scan reset defaults. because you will loose your settings.
look at chapter 4-9 and 4-10
If you don't know ask me. we don't want to lose al the settings.
good luck
Nov 29, 2007 | Symbol Spark LS 1004
Scanning problem
With this problem there are 2 things that I think you need to do. 1. USB devices usually require drivers, it is unlikely that these came with windows, you need to check that your device is correctly installed and any software required to run it is installed. 2. check the configuration of the scanner, (as it will appear to work even if it is configured incorrectly. you should have a code book which you can program all of the options, as the scanner may not even know that it is connected via usb. (all the scanner knows is that it has power)
Sep 06, 2007 | Symbol P 304PRO Handheld
Symbol scanner LS3200
Check out the cable of your scanner, it must be placed with new one if it's broken
Aug 17, 2007 | Symbol LS 3200
Scanner Symbol Ls2208 keyboard not work
The scanner does not detect the keyboard host on power up and is locking up your keyboard. The IBM PC/AT host type barcode must be scanned the first time it is setup. The barcode is on Adobe page 56 of 342 of the LS2208 Product Reference Guide. The scanner should start working immediately after the host type barcode is scanned.
Jan 30, 2007 | Symbol LS2208-7AZK0100S Handheld
Symbol PPT 2800 Portable Terminal Logo
71 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
