Question about Dell OptiPlex GX110 PC Desktop
Got CPU from friend and it wont work
When I start the cpu it goes to the dell page then to a black screen that say strike f1 to retry boot, f2 for setup utility. I think the settings are right... whats going on and how do I fix it?
    President:
  • 2,961 Answers
When prompted again hit F2 as the bios clock may be incorrect, which means your cmos battery needs changing, reset the time and save, exit for a re boot. Take the side off the pc and look at the motherboard for a flat disc shaped watch type battery and replace if required.
Posted on Feb 16, 2007
3 Suggested Answers
SOURCE:
SOURCE: 1 beep and won't boot...Strike F1 to retry or F2 for setup utility
hi! i have a prob with my pc its an DELL GX OPTIPLEX 270. It doesn't work in the boot, it lunch me a message at the first screen (strike f1 to retry boot, f2 for utilities). I have try many solution but it doesn't work. So, plz if any one can help me to solve my pc.
i'm waiting for and thx.
Posted on Jul 26, 2008
Konzen
  • 128 Answers
SOURCE: no boot device available- strike F1 to retry boot ...
you can try this steps to resolve your issue:
1. clean your disc drive with white cloth and alcohol
2. try to re-install the OS
3. if this won't work try to download another boot disk like EBCD
or ask a friend to create you a boot disc and try to boot your computer with it.
- This can rule out or confirm a Bad Windows OS disc, thus let's you install you Windows OS in the process.
4. try to re-install again the OS
Posted on Sep 07, 2010
No boot device
Your CPU isn't recognising your hard drive. If it is a lap top, check to make sure u didn't accidentally loosen it, there is an unlock button on bottom of some laptops that unlocks your hard drive. If that isn't the issue, then some how either the plug came loose or your drive is corrupted. There are many ways to fix it, but recovering data will be difficult. If there is data that you must have, you will have to replace the drive(or use a friends CPU) and get data recovery software. You can also just bring the drive somewhere like best buy geek squad or other reputable CPU repair man to have it recovered. If you do that, they will sell you new drive and recover all data possible and restore CPU to factory settings.
Jun 02, 2014 | Computers & Internet
CPU Fan Failure
ask the Dell support of directions, they will guide you.
Mar 27, 2012 | Dell Inspiron 620 ST Desktop Computer...
My Laptop is Dell Latitude D600 (A16) Everytime I tried to power up, Splash screen appears with blue bar and when going into next screen this message appears " No bootable devices--strike F1 to retry...
Check your BIOS, by pressing F2 and see if the hard drive is recognized. It should indicate the MFR next to the hard drive listing. If it's not there, then you might have a bad hard drive. If it is there, try re-installing the operating system with the set-up disk. You can also go to the Dell website, enter you service tag number, and get technical support for your particular laptop. It might have a recovery partition in the hard drive to recover to factory settings.
Oct 26, 2010 | Dell Latitude D600 Notebook
No boot device available- strike F1 to retry boot F2 for setup utility
May 21, 2010 | Dell Dimension 8400 PC Desktop
I have a latitude CSx it has been refurbished they didn't install an os,I bought a hp dvd 1040e external 20X Multiformat DVD writer & ram.When I try to load an os I get,No boot sector on hard...
there is not OS and boot files on ur HD, u need to install it from a Win CD...u need to format add install Windows OS then only it will boot from the disk
Dec 26, 2009 | Dell Latitude CSX H Pentium III 500MZH CPU...
Primary disk drive not found
Check the connection of your hard drive and make sure it's plugged properly On The Motherboard.
Is this a SATA drive? Has it ever operated properly? If worse comes to worse, you'll have to reload windows from scratch.
Nov 11, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Can't System Restrore Dell Inspiron 531.
This can usally be sorted by inserting your Dell windows OS restore disc & choosing the repair option.
Jun 23, 2009 | Dell Inspiron 531s Desktop Computer
Dell latitude C610
From the Bios, load all the default settings and then check the bios SATA port settings. If it is set to AHCI, change it to IDE to boot from Hard Drive. This should solve the problem
Oct 01, 2008 | Dell Latitude D600 Notebook
Jun 13, 2007 | Dell OptiPlex GX110 PC Desktop
Dell OptiPlex GX110 PC Desktop Logo
99 people viewed this question
Clive
Clive
Alun Cox
