Question about Euro-Pro Shark SC-505 Handheld Steam Vacuum
I can't unscrew the plug on the water reservoir??
I have "pushed" down while turning both left and right it won't budge!
Same thing happened to me. The plastic cap gets "stripped" inside and won't catch to turn. I removed the plastic cap with a big wrench and a lot of muscle. Then used an adjustable to remove the metal screw-in plug. I still use it this way and put the metal cap on and off with a wrench. Just have to be very careful as it gets extremely hot.
Posted on Oct 18, 2012
SOURCE:
Customerservice
yes it does unscrew it will be tight and you will need alot of presure to unscrew try tapping it with a screwdriver handle turnig it the link below is the manual page 10 is filter change.
http://hoover.com/file/979/http://hoover.com/file/979/
Jul 26, 2013 | Hoover Vacuums
Zip brush won't spin and I can't figure out how to fix
did you check to make sure theres no clog in the hose since its powered by air?
Aug 09, 2011 | Kirby G4 Bagged Upright Vacuum
I have the Platinum keurig and the water is going back into the reservoir and not into the cup??? is it beyond repair?
Are you getting a message saying to "de-scale" it may need a good cleaning. That's usually the issue & the quickest fix. If the Keurig (or any other coffee maker) gets lime/calcium build up on the internal components it will ignore whatever has been programmed into it & just keep cutting off, keep making partial cups & just not working properly. Run some white vinegar thru it - fill the reservoir with a strong vinegar/water mix, remove any kcups/my kcup filters, also remove the reservoir carbon filter ( fyi - that's not going to eliminate any lime/calcium in your water - it's just to eliminate any bad tastes/odors) and "make" how ever many cups it takes to empty the reservoir.Depending on the build up - you may need to do this 2 or 3 times. Also run about 2 more reservoirs of just clear water to help rinse out the vinegar mix (otherwise your next cup of coffee will not be what you expected).
This may eliminate your problem & should be done every 2-3 mths. If that doesn't solve it - your Keurig may already be too far gone. Good Luck.
Jul 09, 2011 | Vacuums
Shows that it is ready to brew, but says "de scale"
What model do you have? I'm guessing we are talking coffee maker, is it a Keurig? If you're getting a message saying to "de-scale" it need a good cleaning. That's usually the issue & the quickest fix. If the Keurig (or any other coffee maker) gets lime/calcium build up on the internal components it will ignore whatever has been programmed into it & just keep cutting off or keep making partial cups. Run some white vinegar thru it - fill the reservoir with a strong vinegar/water mix, remove any kcups/my kcup or filters, also remove the reservoir carbon filter ( fyi - that's not going to eliminate any lime/calcium in your water - it's just to eliminate any bad tastes/odors) and "make" how ever many cups it takes to empty the reservoir. Depending on the build up - you may need to do this 2 or 3 times. Also run about 2 more reservoirs of just clear water to help rinse out the vinegar mix (otherwise your next cup of coffee will not be what you expected).
This should eliminate your problem & should be done every 2-3 mths, regardless of whatever the model of coffee maker you have. Good Luck.
Jul 08, 2011 | Vacuums
Clean water and solution will not dispense
This is an unusual problem. The most likely reason is that the supports inside the upper handle grip have broken, and when you squeeze the trigger, the rod that opens the reservoir assembly is not pushing open the valve. If you remove the upper tank, and look behind it, you should be able to see the end of the actuating rod sitting on top of a rubber valve assembly. Squeeze the trigger and watch the rod to see if it pushes down on the valve. If it doesn't, the upper handle grip will likely need replacement. If it does push down on the rubber seal, the reservoir assembly has probably failed and may need replacement.
Jun 07, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Steam buggy water reservoir cap has apparently been cross threaded, and cannot be removed by twisting or other "encouragement." If I cut it off, where can I get a replacement? Can the machine be used as...
You need to completely annihilate the plastic cap by cutting it off and destroying the remaining plastic to expose the stainless steel insert/plug. You can use either a pipe wrench or 11mm wrench to turn the insert counter-clockwise to unscrew. You will need to use some force to get the plug out since it's basically glued shut by lime deposits in your tap water.
Do not move the slotted cap or else this will need to be adjusted so that all your water doesn't squirt out before turning to steam.
Next time only use distilled water. Store with the cap off. Grease the inner and outer threads after every use and wipe it off completely before use so it doesn't mix with the steam and turn to vapor.
Sep 23, 2010 | Tristar SB Steam Buggy Vacuum
Can't get the top unscrewed
I had the same problem. Mine had been stored for a year. We had to completely destroy the plastic cap. Once down to the metal underneath we did the boiling water thing. It didn't work at first so we tried it again. And then immediately after applying the boiling water we used ice water to make the metal contract. With pliers on the neck and pliers on the lid we were able to open it. But, I know my husband had to put some strength into it. Hope this helps you all!!!
sorcha1580
Nov 16, 2008 | Euro-Pro Shark SC-505 Handheld Steam...
Safety cap on the Euro-Pro dexuxe steam cleaner style SC507H
if it is anything like mine...you push the cap down, give it a full turn & release. keep doing this (maybe 5 or more times, and eventually it will start unscrewing easily without needing to push down
Oct 24, 2008 | Euro-Pro Shark SC-505 Handheld Steam...
Euro-Pro Shark SC-505 Handheld Steam Vacuum Logo
116 people viewed this question
Top Euro-Pro Vacuums Experts
 Tony C
Tony C
Level 1 Expert
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
