Question about Refrigerators
Defrost water not reaching the collection tray
I have a Hoover contour fridge which has worked perfectly for a number of years. It started leaking recently and when I remove the drip tray underneath it is always bone dry, however far back I position it. I figure the pipe leading from the defroster, is missing it or broken. Can I get to it without tipping the fridge on its side?
  • iaintrish Dec 22, 2008
    Excellent! Excellent! thank you very much for the prompt advice. It did the trick perfectly. Well worth the price.
    Scholar:
  • 111 Answers
The defrost drain tube from the freezer is plugged up. You first need to clear any ice away from the top of the tube then blast it out with about 4 cups of hot (not boiling) water with a turkey baster. That should take care of it. Shouldn't be a reason to lay it on its side.
Posted on Dec 20, 2008
I have a Hoover Contour HE430TF fridge leaking water to the bottom of the crisper. There is no internal drain hole. Hoover has no record of a 20 yr old model & is no help. How can I fix the problem?
it's not leaking water.. it's condensation running down the back of the fridge.. normally this is channelled into a hole that has a tube on it, that allows the water to go to a drip tray on top of the (warm) compressor, which then evaporates it.. Please re-check for a "V" shape moulding on the back if the fridge.. there SHOULD be a hole smack bang in the middle, which may have clogged up in the pipe with gunk, causing water to refreeze and block the hole completely.. best to do a full empty and clean, and use a chopstick, or better still a cheap pipe-brush from the £ shop, to clear that tube (about 1/2 inch diameter, or maybe less.)
Apr 24, 2017 | Hoover Refrigerators
Fridge working perfectly... water leaks onto floor over night seems to be from underneath..
I would check that the water catch tray is on the compressor, this item collects the water from a defrost, it may be missing.
Dec 04, 2011 | Fisher and Paykel RF201ADUX Bottom Freezer...
Water is leaking into my fridge from defrost.
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section ( not on all models, but this is the most common way ), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system.
If in case the water is leaking on the floor then:--
There are several things to check for. The condensing defrost tray under the fridge can crack or develop a hole and leak onto the floor. A door gasket not closing properly may cause sweating and leak onto the floor. If your fridge has developed a frost free failure problem, often the frost will travel down the suction line at the back of the fridge and drip water on the floor. The heat exchanger tubing can separate and also sweat and drip on the floor. Ice maker and chilled water fill lines can crack and leak as well, this is fairly common with the plastic lines as they can dry out and crack.
Unplug the unit from main power outlet and empty whole unit and keep both the doors open and then connect the power after 24 hours and recheck.This procedure is called manual defrost reset.If this helps then its OK,but if this procedure not helping then its the faulty defrost unit and it needs to be replaced.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 30, 2010 | GE Refrigerators
Water is leaking from the bottom of the fridge.
Your fridge has likely gone through a defrost cycle. What frost was present has been melted and drained into the tray. During this cycle, the walls of the freezer are warmed up as well to facilitate melting the ice.
The air blown from the condenser fan should be blowing across the collection tray, and will evaporate the water in a short time. If you think that there is too much water, or it has started to over flow the tray, you can try scooping the water out using a small cup, or place the corner of a large towel into the water to soak it up. In either case, turn off power to the fridge first.
Jun 11, 2010 | KitchenAid Superba Architect KSCS25INSS...
Hoover Contour HE423UFL fridge freezer continually frosts over?
I am on my fourth timer for this problem. Seems to fix the problem each time. You must remove the big chunk of ice covering the drain hole before you operate the fridge with the new timer. The contacts in the timer get burnt due to arcing inside the switch. The heating element seems to always work ok, but if the element is no good the fridge will not defrost.
Jan 31, 2010 | Refrigerators
My refrigerator leaks water on one side & the water collects in one of the vegetable coolers. I am now unable to use that vegetable cooler & am having to constantly wipe up. The seals appear to be...
I have Model ET8CHMXKQO-3 whirlpool fridge with the same problem. The problem I believe is due to the drain line to the tray that collects defrost water freezing up. Temporary solution is defrosting the fridge; permanent solution is running a thin wire thru the drain line that aparently prevents the condensing water from freezing. I am trying to find out how to install this wire and where to buy it.
Jan 28, 2010 | Whirlpool Refrigerators
Hoover contour fridge leaking
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Aug 30, 2009 | Refrigerators
Whirlpook ET21NK--Water collecting in crispers
Self-defrosting refrigerators turn themselves off to defrost once in each 24-hour cycle. There is a 'drip pan' under the refrigerator that catches water from this automatic defrost cycle. The pan is not very deep, so if the unit is leaning very much, water will run over the top of the pan. For this and other reasons, you should try to keep the unit as level as possible.
Aug 21, 2009 | Refrigerators
Water leaking into fridge
Unless you have a lot of confidence in your ability as a handy person and plumber, it may be better to leave this to a pro. Here's the story.
When the freezer automatically defrosts, water from the melted ice collects into a tray behind the back panel of the freezer. There is a drain in this tray, and the drain empties into a pvc tube that carries the water down into an evaporation tray that extends from front to back on the bottom right side of the refrigerator. A fan blows air over the evaporation tray to dry the water in the tray before the next defrost cycle.
Over time, the drain tube gets partly clogged with gunk, the water in the upper collection tray doesn't drain completely into the lower tray, and when the defrost cycle ends, the water still in that upper tray freezes. After a few defrost cycles, enough ice forms in the collection tray so it blocks the drain completely, and this plug won't melt during the defrost cycle. Now every time there is a defrost cycle, water collects, overflows, and drips down through the air channel at the back of the fridge into the refrigerator section.
The fix is to clear the drain tube leading from the upper collection tray to the lower evaporation tray. Here's how (if you have the know-how to tackle the job):
First, move the fridge away from the wall, unplug it, and remove the fiberboard panel that runs across the the bottom back. From the front of the fridge pull out the trim grill that runs across the bottom. Locate the evaporator tray on the right, but don't remove it yet.
Empty the freezer, and be sure to safely store the removed items in another freezer, or an insulated cooler, if you can complete the job in an hour or two. Be careful with ice cream and such, which cannolt be allowd to defrost, even partially.
Remove the ice maker if you have one, remove the screws holding down the bottom panel of the freezer, remove it, and remove the screws holding the back panel, and remove it.
Leave the refrigerator door closed, to keep the food in it from spoiling. If this job is going to take you more than an hour or two, move the food in the fridge to another fridge.
Now you need to let the freezer defrost (a hair dryer will make it go faster, but don't let it get wet), and sponge out all the water, There will remain an ice plug in the drain at the bottom of the collection tray at the back. Use hot water to dissolve the ice plug, use a drinking straw inserted into the drain (don't let it drop!) to be sure the ice plug is melted.
You still have to clear the plastic drain tube of collected gunk. This is like snaking out a drain pipe. I found that 8 feet of 1/8 pvc tubing works well. Before you clear the drain tube, remove the lower evporation tray. There is a finger hole at the front. Use it to lift the tray up and forward (be carelful, it may contain water).
Put the pvc "snake" down into the drain in the upper collection tray, and gently work it down through the drain tube. You are done when the snake emerges from the bottom of the drain tube, at the back bottom of the fridge, above where the evaporator tray sits. . Snake up from the bottom, and then back down again from the top, to be sure the drain tube really is clear. Replace the evaporator tray, and slowly pour 2 cups of water into the collection tray at the top, and confirm that it drains quickly and completely into the lower tray.
Empty the lower tray, replace it, and reverse all the disassembly steps.
This is not a permanent fix, because the drain tube could clog again, but should be good for a few years before you have to repeat this operation. At least now you know the cause and the fix, and can deal more effectively with a repair tech, even if you don't tackle the job yourself.
Jun 20, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Water is leaking out of the bottom of the interior of our Contour Refrigerator.(HE430TF) It does not appear to be flowing into the defrost overflow tray. I have poked a piece of fexible plastic up the pipe...
Hi Richard,
I don't have any knowledge of your particular model but on mine the water condenses on the cold plate in the fridge compartment and then drips down into a little channel. From there it goes down through a fairly small tube which opens onto a little dish formed on the top of the compressor unit. This unit is warm when running, and the water is supposed to evaporate away into the room.
If water is collecting on the floor of the fridge compartment it is almost certainly due to a blocked drain pipe. If the drainage channel has become cracked this might be another cause of your problem.
One way to check that the drainage pipe is clear is to blow up it (not blow it up !) but that is a pretty yucky job. Alternatively you could pour a little hot water with dishwashing detergent dissolved in it into the drainage channel and check that it comes out onto the compressor top.
I hope this helps, but if not please defer a rating until we have had another think about it. Cheers, D.
Jul 09, 2008 | Hoover Refrigerators
Refrigerators Logo
110 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
