Question about Sony KV-32S35 32" TV
Sony KV-32S35 32" TV died
Just lost power as other components that were on same circut kept going, now tv will not power up at all cannot see an external fuse link on tv and operating instructions offer no help. thanks for looking at this.
    Genius:
  • 1,199 Answers
Try replacing the flyback///a commen problem
Posted on Dec 06, 2008
Need to know which optocoupler ic is used in str 6267 based power supply in sony trintron crt tv
Sony FD Trinitron WEGA... Repair Questions - Fixya
www.fixya.com/.../p228979-sony_fd_trinitron_wega_kv_36fv310_36_t...
Hello, i have a sony FD Trinitron WEGA #KV-36FV310 ... Need to know whichoptocoupler ic is used in str 6267 based power supply in sony trintron crt tv.
Sony KV-TG21M61 21" TV Repair Questions,... - Fixya
www.fixya.com > Forum > Standard (CRT) Televisions > Sony
Need to know which optocoupler ic is used in str 6267 based power supply in ... My sony crt Tv totally dead when touch any components and the IC strs6307 ...
Tv code hi i'm looking for a 3 diget programming code for my ...
Dec 21, 2015 | Sony Televison & Video
Sony sony kv-25v25 no power
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 14, 2014 | Sony KV-27V55 27" TV
My sony will go greenish and then shut off ...it happens mostly when there seems to be a dark scene or change of brightness on show...any info would be great
Hello
Your TVs ABL [automatic brightness Limiter} section has some trouble. It is in the main circut board. It can be located only by and experieced technician. You can't locate it by yourself. It needs the schematic diagram of the circuit of your TV. it consists of one or two resistors and capacitors and a zener diode.
Find someone who could repair it, or send it to the nearest Sony service center. Never try to repair by yourself. Some of Sony components are critical and very difficult to get loacally.
Oct 18, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony FD TRinitron WEGA, KV-32FS320... NO PICTURE/NO SOUND ...The red light flashes on the front of the TV. I have unplugged the power cord, and have allowed time to pass before re-plugging. Once I...
Just went thru the same problem with my sony kv-34. There are two IC's on the D circut board located on the left side looking from the rear. If you can solder 18 pin IC's without making a mess it is possible.If you have a friend thats real good with a pencil tip solder device. I recomend putting sockets in where the IC's were as you won't have to worry about overheating stuff next to the IC's.Do a google search: Sony led flashes ad select the second hit in the list.
Good luck
Rich
Jun 06, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
I have a 36" TV that won't work - Red LED light blinks 5 times
The 5 blinks indicates a White Balance Failure. This involves checking voltages and components tied directly to the CRT. I would not suggest any attempt for self repair. The cost for this repair should not be significant. Figure a parts cost in the $30-$50 range at worst.
Dan
Mar 06, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Power Supply Demage Of Sony TV KV-XR29M61
You can get required service manual from Manual Zone for little fee.
Feb 23, 2009 | Sony KV-XR29M61 TV
Tv cuts on and off
This sounds like the flyback on the main circut board needs replaced (part is in 70.00 range!
Dec 12, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
KV-34HS510
Isnt it interesting that I see these 6 and 7 code problems all happening within a timeframe. Seems to me Sony has a problem if not rigged it to die after a certain amount of time.
Mar 15, 2008 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Sony tv model kv-27HFR
hi can you send me a tv diagram for sony tv model kv-27HFR cause there are components missing and...
Feb 26, 2008 | Sony Televison & Video
TV died
Death can occur from a simple power supply fuse to the anything inside. Now if you are confident that you can try to fix it on your own, start from the fuses, and check for possible shorted components if the fuse is blown.
Jan 30, 2008 | Sony KV-32XBR48 32" TV
Sony KV-32S35 32" TV Logo
59 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
