I have an old janitrol thermostat with terminals marked R,Y,G,O,W2 and I want to replace it with a Hunter 44360 Programmable Thermostat with terminals marked G,RC,RH,Y/O,W/B,Y1 What wires do I hook up to the hunter and where do I hook them?
  • 85 Answers
Hook up like this:
R-RC (jumper rc with rh) unless you have more than one transformer
Y-Y/O
G-G
O-Y/O (depending if reversing is energized by O or B terminal, refer to your manual)
W2-WB
Posted on Dec 06, 2008
I have a Hunter Thermostat 44360 7 day Programable and I want to cancel all programs and just use it manually amy help?????
There should be a tiny unmarked hole in the front of the thermostat....if so, the thermostat 'reset' micro-switch should be under that hole. Gently stick a thin toothpick inside to depress the switch and get ready to operate it manually.
If there is no hole, separate the thermostat from its sub-base and look closely at the sub-base for a reset button.
Apr 13, 2015 | Hunter 44360 7-Day Programmable Digital...
Replacing a janitrol hpt 18-60 with a Filtrete 3m-22
What is the question that you have about this? What is the make and model of the hvac unit that it is running?
Apr 21, 2013 | Filtrete Thermostat. 7-Day Digital...
Rheem Heat Pump Thermostat Replacement (#41-20804-15)
you need a 2 stage heat and cool t-stat hunter t-stat is not 2 stage
Feb 19, 2013 | Heating & Cooling
I have an old Bryant heat pump. I got a Hunter 44860 2 stage heat/2 stage cool but I am having problems with the wires. These is the Bryant set up (the wire colors do not match)...
This should help you. You need to know if your thermostat is powered by the unit or independently and which way your reversing valve switches (I,m not sure on a Bryant, but probably Your old O wire goes to your new O terminal. They should pretty much match up, the new stat just has more options. Thermostat wiring
Jun 09, 2017 | Hunter Fan Company 5/1/1 Programmable...
I need a new manual for my 44360 Hunter programmable thermostat.
Try this URL. Should be able to download it for free.
http://homeappliance.manualsonline.com/manuals/mfg/hunter/44360.html
Click on the above link. If that doesn't work for you, copy and paste it into your browser's URL line.
Oct 13, 2009 | Hunter Fan Company 5/1/1 Programmable...
Switching old thermostat to Hunter thermostat model 44155c
By describing the wires from your new thermostat and your old one, it sounds like your new thermostat is not compatible with your system. If you have seven wires now, then you more than likely have a heat pump system and you have to get a thermostat that is compatible with this type of system. Then you will have the connections you need.
Jul 11, 2009 | Hunter Fan Company 5/1/1 Programmable...
Im swithcing from a Janitrol to a hunter ''stat'',
You have the wrong therm. This one will not work, you need one that works with all 7 wires. You probably have a heat pump or aux heat. The only hunter that will work is the one for a heat pump. The back of the packages will tell you more info.
Jun 17, 2009 | Hunter Fan Company 5/1/1 Programmable...
Wc wiring on thermostat
sounds like you have a heat pump the w2 on old thermostat is for a second stage heat. If you can give me a little more information on type of system you have (forced air furnace with heat/cool, Heat pump or boiler)? How many wires are on old thermostat? Is it a no programmable or programmable? How old is the furnace?
Jan 17, 2009 | Honeywell Programmable Thermostat Heater
Hunter 44360 thermostat wiring
If you don't have the wiring information, go here: http://www.hunterfanhq.com/tools/sales/hunter/preseason/images/owners/42710.pdf and see page 10.
If you're still having problems, go down to the furnace room and find the piece of equipment that you're wiring to.  See where the wires came from, transpose that to the information above.  Note: the wiring from the relay box should be 24 volts which is safe to handle.  Wiring inside the relay box may be 110 or more volts which is not!!!  Cut power before opening relay boxes.
As far as heater running continuously, be sure of your wiring.  You may have the gas relay lead and the fan lead reversed.  Determine if you've set the switch options for your type of heater correctly!!!  Do you hear the relay clicking in and out at or near the room temp when you change the setpoint?  If not, the unit may be defective.
Nov 14, 2008 | Hunter Fan Company 5/1/1 Programmable...
OMG! has anyone came up with a solution? I have the same problem as mlc3530b
Mar 08, 2008 | Hunter Fan Company 5/1/1 Programmable...
Heating & Cooling Logo
224 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
