Question about Dishwashers
GE dishwasher detergent cup broke.
The detergent cup won't close. How can I fix it.
WONT CLOSE
Posted on Mar 07, 2009
My office's GE QuietPower 3 dishwasher detergent
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Jul 29, 2011 | Maytag Dishwasher
The detergent cup lid stopped closing on my old GE Model # GSD600G-0l dishwasher. Tried turning the dial clockwise to the Off position, but it won't work.
heatman101
May 10, 2011 | GE Dishwashers
Hello. I have a GE Potscrubber 600 dishwasher. The soap dispenser will not close. This seems to be a common problem. Any help would be great, thank you.
Main detergent cup won't close on GE Potscrubber 700 GSD700.A workaround is to add the additional detergent with rinse aid 18 minutes intothe wash cycle. To repair, switch off power through circuit breaker. Set timerknob to 12 o'clock. If the detergent cup lever spring opens the cup after it isclosed, remove screws on panel that holds detergent cup and remove the panel upand out of door. Remove timer cover by moving it right and pulling up to exposetimer, see photo 1. _1909.jpg If a spring is loose, it can be reattached as follows.Remove two screws that hold timer, then remove timer. Do not remove timer knobfrom front of GSD700 because knob is designed for removal from rear of panel,after the timer is out. If spring attachment point broke off, reinforce it withepoxy (JBKwik), see gray cone upper right of center in photo 2. _1910.jpg After epoxy cures, drill and tap a hole for a metric 3 - 0.5mm-8mm screw (4-40 may also work). Install spring between new screw anddispenser linkage and tighten screw, see photo 3. _1911.jpg Install timer, jiggle knob so it engages timer and securetimer with two screws. Pull dispenser lever down to make sure it moves andsprings back. Replace round switch and cover. Install white cover with leverextended through it. Install cover screws, close soap door, and rotate timer,soap door should open after about 90 degrees of rotation followed by rinse aidactuation.
Oct 24, 2010 | GE Dishwashers
Detergent left in dispenser cup
You either do not have enough water getting itno the machine or it is not hot enough. 5 years old so I would suspect a plugged screen on the fill valve.
Eric
Dec 11, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
The detergent cup will not close on GE GSD5120 dishwasher
they get warped and the latch gets waren out . replace the cup assy . this is a common repair . mm
Dec 08, 2009 | GE 24 in. GSD5120 Built-in Dishwasher
Soap dispenser cover won't close
It sounds like it may be stuck between cycle steps.(this sometimes happens if the washer is open during a cycle)Try and run it through one full wash cycle as it is.Then check to see if the soap door will close.If not,the lack may be broken
Jan 09, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Need a diagram for the kenmore dishwasher model 665.16645890
I have GE Dishwasher (model no:GSD1100G02),and for the last few month I was not able close the main detergent cup cap(it is coming back to full open position,even after keeping the CAP turned all the way to a closing postion)
I have called the GE spare parts division,and obtained the New detergent cup cap,and when I tried to remove the old one,inorder to replace with the new one,I was not able remove old one.
Please help me how to remove the old main detergent cup cap,and replace with a new one.
Hope I will hear from you soon in this regard.
Murthy Pillutla
Home Ph:630-428-3277
Cell:484-919-3653
Jun 14, 2008 | GE 24 in. Profile PDW9880JSS Built-in...
Dishwasher detergent left in dispenser cup on GE Profile dishwasher
there is no solution for it because of its design. i have same GE and same problem. It is happening because top rack is right front of the detergent cup and it is not opening 180 degree while it is washing. it opens only 15 or 20 degree and water just doesnt get in there as much as suppose to be because only water can get in there from the bottom sprayer arm because detergent cup lid is not allowing water to get in the cup from middle and top sprayer like any other dishwasher! i called them so many times and they are just jerks! they blame anyting about my house but their dishwasher. their tec. showed up 4 times and they just keep blaming hot water temrature etc. water temprature doesnt matter if water cant get in the detergent cup, right? but they dont want to admit that because they are like programed robots to give you same answers and just blame you but GE dishwasher. please fill out complain form with Consumer Complaint Department. you should be able to find their address and web site on the internet. Please do so, maybe we can get refund or replacement or something. Never ever buy GE again. Just get a Bosch.
Apr 14, 2008 | GE Dishwashers
Detergent cup door partially opens
heatman101
y
Mar 21, 2008 | GE Tritonr XL GSD6260JCC Dishwasher
Dishwashers Logo
139 people viewed this question
Top Dishwashers Experts
