Question about Philips 30PW633R 32" TV
Phillips TV not really turning on
This is technically two problems (could be related, I'm no expert). 1) Occasionally the screen will go wavy on me and make a high pitched whine. Annoying, but not life threatening, so to speak. I can be perfectly happy with the wavy if my next problem can be fixed... 2) This is the serious problem... now the TV won't turn on. The little green light will flash, and I hear click from inside the TV. Also, I hear the screen static up for a second. This happened once before and a few days later the TV worked fine again. It just happened again (been about 3 weeks since the last time) and I'd like to get to the bottom of this problem if I can. *Disclaimer* I have no clue about the inner mysteries of a TV set, so if you can, keep it simple. I can solder if I need to, just expain how and where as if I was a slow-witted four year old :) Thanks in advance!
  • 45 Answers
You can try to check if these are a couple of bad solder joints on the board. You might have alot of dry joints. Take carethat the tv is unplugged and try it out. before starting, try shorting the pins of the largest capacitor in your tv set, to make sure you do not take an electric shock. Best Regards Patrick
Posted on Aug 27, 2007
Macbook air no power
Are you searching Macbook Air Technical Support Number? We provide world class technical support for Macbook Air and other Apple products with the help of well trained and qualified technicians who are always ready to assist you 24*7 support services. We fix most common issue related to installing and operating system, virus and security and etc.
MacBook Air Technical Support Number 1833 493 0111 MacBook Air Help
Mar 20, 2017 | Apple MacBook Laptop Computer Mac...
Phillips flat screen tv left half of screen is black right side is dim and flickering
Is your tv less than a year old? You need to call Phillips and see if it is covered under warranty. If that is not the case you need to get a few estimates. You want to know if it will be cheaper to repair or replace your tv set.
1 888-744-5477 Phillips customer service number
Aug 14, 2016 | Televison & Video
Can't turn off hibernate
Your system might be going into Standby. Check the settings in the Control Panel for Power.
Jun 22, 2017 | Fujitsu Siemens Computers & Internet
I have a Phillips Flat TV - HDTV model number 42PF94310/378 My problem is, now when I turn in on there is approximately 3-4 black vertical line going up the screen (near the center of the screen). Im...
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 26, 2017 | Philips Televison & Video
Turn on tv screen is blank hear clickling noise
If the noise is louder appears as if sparking inside the set than turn off set as there may be leakage in the EHT (extra high tension transformer) which can be replaced by some technical expert,if the noise is not louder than there is failure of internal power supply,get it repaired by technical expert.
Jan 21, 2011 | Sansui D 27" TV275 TV
The screen is wavy when I'm looking at an on screen menu or there are words on the screen. Just wondering on how to fix the problem. Not really bad but just really annoying
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 28, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Hello, I've got red wavy lines across screen
There are two common problems with these sets.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 22, 2009 | Samsung HCM5525W 55" Rear Projection...
Colored wavy lines on screen
This is a Logic board problem, not so easy to replace in Hitachi but well worth the repair if I had your zip code I could recommend a person or three. But the problem is a problem in the logic board and will beed replacement, Thanks for using Fixya.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 14, 2009 | Hitachi P42H401 42 in. Plasma HDTV
Green screen with red and blue wavy lines
This is "NOT" meant as "expert" advice...as this is not my area...HOWEVER...I see no one has answered this yet...AND I got some good help from here a year or so ago that worked for me!
When I had a similar "green screen" problem with my SONY projection tv...the guy helped me by having me make "MINOR" adjustments to the red/blue/green etc knobs behind the panel. These were three small black plastic pieces and needed less than a 1/16 of an inch adjustment...try adjusting one at a time and giving it few seconds after each adjustment. It worked for me..at least for a while (till my wife gave it away to a friend because it was "too big"...ah! women!!! LOL)...hope this helps. (NON-expert help!)
Jan 11, 2009 | Televison & Video
Turn on, red screen with wavy line, then it freezes
http://www.fixya.com/support/t1094202-ps3_freezes_startup
go here and scroll down the page, another fixya expert has resolved this problem, it has something to do with an updated patch....
I hope this helps
Nov 25, 2008 | Sony Playstation 3 (PS3) Console
Philips 30PW633R 32" TV Logo
112 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
