Question about CTX PV 720 17" LCD Monitor
Ctx pv 720 lcd monitor backlight drops post plus 30 seconds!
I turn on the monitor and it is fine for 30 seconds or so then then the backlight drops but the images are still there can be seen with external light if i shut it off and turn it back on it will get another 30 seconds etc.
a transistor is obviously bad and I am poor enough to have to isolate it.
ctx pv 720 LCD monitor. how do I fix it ? I can solder and desolder with the best of them.
Comment posted on Dec 03, 2008 I know its gotta be capacitor or power transistor circuit but where exactly is the low power transistor controller
    Champion:
  • 293 Answers
Hi...there,
The problems on the backlight inverter power supply. Open it up and check all the capacitors, it look like a tiny battery cap on the side had writing on it. (Example 1000uf 16v ) if you are lucky you can spot it right away...with a bulged on top of each caps. If not, just replaced all of the caps... Good luck!
Posted on Dec 07, 2008
Faulty monitor ctx pv720a. The screen has the
Try another cable, or check the plug for bent pins. If they are all good, check that the monitor is set for VGA input (if it supports VGA and DVI) as it may be looking for a different input. Then replace the monitor. It's not common, but video processing circuitry can sometimes fail, and yours may have. New 17-inch LCD monitors are quite inexpensive now, so it would probably be more economical to replace this one than to try repairing it.
Jan 01, 2011 | CTX PV 720 17" LCD Monitor
Ctx pv720a monitor goes blank
This is what inverter board looks like:
http://www.shopjimmy.com/catalogsearch/result/?q=CTX%20PV720
Look for bad caps also, more likely to need new inverter board, warning, you can have bad lamp assembly also.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Jul 27, 2010 | CTX PV 720 17" LCD Monitor
Ctx ezbook 700e larger HD
Why move it at all. XP needs SP3 to read hi capacity drives. I use USB external drives without any problems to increase capacity without the hassles of moving files. There are software packages that will transfer data from one hard drive to another if you must.
May 12, 2017 | CTX PV 700B 17" LCD Monitor
Ctx lcd monitor turns off after 1 second
Your backlight fluorescent bulb is burned out.
Dec 24, 2008 | ViewSonic VE710b 17" Flat Panel LCD...
Ctx model PV720A
Hi...there,
You can saved even more repaired yourself. The problems on the backlight inverter power supply. Open it up and check all the capacitors, it look like a tiny battery cap on the side had writing on it. (Example 1000uf 16v ) if you are lucky you can spot it right away...with a bulged on top of each caps. If not, just replaced all of the caps... Good luck!
Sep 01, 2008 | CTX PV 720 17" LCD Monitor
Need bracket for ctx pv 720 monitor
i got my bracket for mine at office depot and circuit city also caries them
Aug 22, 2008 | CTX Computers & Internet
Monitor turns off
sir\maam i think there something wrong with the power supply of your laptop,,tv kindly check the power supply section,,,hope to help you thnkzz??
Jan 29, 2008 | CTX S762A 17" LCD Monitor
Need parts
Hi...there,
Oct 23, 2007 | CTX PV 720 17" LCD Monitor
LCD screen goes black repeatedly
Have you checked the light on your power supply? My monitor will go black and I noticed the light on my AC power supply was off. It was very hot so I unplugged it and let it cool down. When I plugged it back in my monitor worked fine until the power supply started to over heat again.
Oct 25, 2006 | Fuji FP-988D 19" Flat Panel LCD Monitor
CTX PV 720 17" LCD Monitor Logo
177 people viewed this question
Top CTX Computers & Internet Experts
Rommel Balcita
Jerry Greenberg
Jerry Greenberg
Are you a CTX Computer and Internet Expert? Answer questions, earn points and help others
