Question about Zenith D52WLCD 52" Rear Projection HDTV-Ready Television
Lamp reset timer
I have tried numerous combos regarding pressing Menu, Mute, Enter, etc...
cant get to the timer reset???
please help
  • mjpalm Dec 07, 2008
    i tried holding both those, but it did not bring up the reset menu???
  • 505 Answers
Hold mute on the remote and enter on the front panel for 5 seconds. this will bring up the lamp timer reset.
Posted on Dec 07, 2008
  • thielectronick
    thielectronick Dec 07, 2008
    i may be mistaken, it might be mute on the remote and menu on the front panel. either way you have to hold both simultaneously for 5 seconds to get the reset menu. if this does not work, you may need an LG service remote
  • thielectronick
    make sure that your remote is pointed at the tv (either into the screen or at the remote sensor on front panel)
Reset lamp timer lg projector model BX-401C
Try this, it works on older LG TV models:
Put the projector on. While holding down the Menu key on the projector, press and hold down the Menu button on the remote. Keep both buttons pressed for a count of at least 5 seconds.
When the Service Menu pops up, release the Menu button on the remote control first and then the one on the projector after.
Now you're in to the service menu, you need to find out which button on the remote brings up the Lamp Timer Reset function. This is where you're going to have to do a bit of trial and error. With the TVs, the remote button was the Mute key. There isn't a Mute key on the projector remote, so try the Lamp key first. If that doesn't work then try some other buttons. Here's the method.
While holding down the Enter/OK on the projector, press and hold the Lamp key for five second. If this works then the lamp timer reset box should appear. Release the remote button first, followed by the unit button.
Press Enter/OK on the remote to reset the lamp timer. If there's an On Screen Prompt to confirm, press Enter again.
Press Exit on the remote to come out of the menus.
Warning: Don't reset or change any other functions. The service menu isn't the place to be tinkering around with stuff you don't understand.
Aug 31, 2014 | Office Equipment & Supplies
Tip
Lamp Reset Procedure for Samsung Televisions.
You have replaced your lamp and the set is working fine but the 'replace lamp light' is still on or the lamp light is blinking. What do you do?
This is an important procedure because you need to know when it is time to replace the lamp again. If you do not reset the timer you may run the risk of having the lamp explode, because it was not replaced in time. This can be dangerous and could cause a fire.
Manufacturers have lamp timers built in to their TVs so that when it gets close to time to replaced the lamp you are made aware of this and if you heed the warning you may save money by not damaging other components such as the ballast. If you do not heed the warning, you are on your own and deserve whatever happens.
To reset first make sure the TV is powered off.
1) Point your remote towards your TV.
2) Press MUTE + 1 + 8 + 2 + Power.
3) Your TV should now say "Loading Factory".
4) Browse down to "Option" then press ENTER (or the right cursor button).
Note: The MUTE + 1 + 8 + 2 buttons need to be pressed down consecutively and fairly quickly. If your TV does not enter the service menu after using this combination, you can substitute MENU instead of MUTE. This seems to work for some sets. Also, the right cursor arrow acts as the ENTER button, so try it if you're having difficulty with the ENTER button.
5) To exit the service menu press the EXIT button or just turn the TV off. Do not turn on the TV immediately after. Let it off for several minutes.
This should reset your counter and you will be ready to enjoy your TV for about another 8000 hours.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
on Jan 29, 2011 | Televison & Video
Reset lamp timer
Aug 31, 2014 | LG Office Equipment & Supplies
HOW TO RESET LAMP HOUR OF LG PROJECTOR MODEL BX-401C
Hello, i would like to know if resetting the lamp timer on an LG MW60sz12 will allow you to get more time out of it?? also if it is possible, how do you reset it???
Quick answer = NO.
As projection TV lamps generally have a life somewhere between 3,000 - 6,000hrs (depending on lamp quality/type), the lamp timer is simply there to assist you in determining when the current lamp is due for replacement.
Resetting the lamp timer has no effect what so ever, on the longevity of the lamp.
The Lamp Timer Reset function is hidden within the Service menu and as such, technicians are usually the only ones who are authorised to reset the timer.
However, the following procedure has been known to reset LG lamp timers:
1. With the TV on, press and hold the MENU button on the TV front panel.
2. While holding that button, press and hold the MENU button on your remote.
3. Hold both buttons for ~5 seconds until the service menu comes up on the TV.
4. Release the remote MENU button first, then the TV MENU button.
5. While holding that button, press and hold the MUTE button on the remote.
6. Press and hold the ENTER (or OK) button on the TV front panel.
7. Hold both buttons until the Lamp Life Hours show up on your TV screen.
8. Release the MUTE button first, then the ENTER button on the TV front panel.
9. Make a note of the lamp hours if you want.
10. To reset the lamp hours, press the SELECT button (the one between the four arrow keys with two concentric circles on it) on your remote.
11. It will ask you to confirm the reset--press SELECT again to confirm
"If this has resloved your problem, please be kind enough to rate this solution and/or leave a testimonial"
Sep 19, 2011 | Televison & Video
I have a sony kds-r50xbr1 when turn-ed on the stand by light flashes for about a min the goes solid and picture comes on but very dark. replaced lamp . there is no sound from any input and the controls...
Sir try to reset the lamp timer. you should press the "display" button on the remote then "5" then the "volume up key" and power "on" you should do this while the tv is in standby mode. Then press "Jump" 3 times to enter the DE service menu. Your tv will display the total lamp hours. Reset the lamp time by pressing channel 3, then mute, then enter. this will make your lamp hour timer to zero. Good day and best regards.
Aug 21, 2011 | Mitsubishi VS-50609 50" Rear Projection...
I have a Sony model KDF-e55a20. I just changed the buld but I still don't get any picture all I get is the power on light blinks 3 times. Does anyone know what the problem is?
Sir reset the lamp timer of your unit.
1 Press "Display" on the remote, followed by the 5 button, then the sound up key, and "power on". Do this while the tv is in stand by mode.
2 Then press "jump" 3 times to enter DE service menu.The tv screen will display the total lamp time hours.
3 Reset the the lamp time by pressing channel 3, then mute, then enter.This will return lamp timer back to 0. Hope this may help good day and best regards.
Aug 18, 2011 | Sony KV-36FV26 TV
Installed new lamp/how to reset the lamp hour meter on samsung (HL-S4666W)
Here is the procedure for resetting the lamp timer.
This is a quick reference guide to show you how to reset your Samsung DLP TV’s lamp hour meter or hour counter. Resetting the counter is a very simple procedure.
Begin with the TV powered off.
Press:
Mute + 1 + 8 + 2 + Power.
Your TV set should now say “Loading Factory”.
Browse down to “Option” then press Enter (or the right cursor button).
NOTE: The Mute+1+8+2 buttons needs to be pressed down consecutively and fairly quickly. If your TV does not enter the service menu after using this combination, you can substitute MENU instead of MUTE. This seems to work for some sets. Also, the right cursor arrow also acts as the ENTER button, so try it if you’re having difficulty with the ENTER button.
To exit the service menu, hit press the EXIT button or just turn off your TV (remember not to turn on your TV immediately afterwards!).
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jun 01, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
E44W46LCD Lamp Timer Reset
To reset the lamp timer, hold the "enter" button on the tv and the "mute" button on the remote at the same time. Once the menu pops up, hit the right arrow on the remote and confirm the reset.
I would guess that's it's a little too late for this answer now, but for future reference... ;-)
Jan 09, 2009 | Zenith E44W46LCD 44" Rear Projection...
Replacing lamp in rear projection tv
To do this, press the ENTER button on the TV and the MUTE button on the remote at the same time. After 5 seconds the screen should come up and it will read "Lamp use time...Total lamp use time ....lamp reset" Press the center button on your remote (the circle button right in the middle of the four directional buttons) and you will be reset to -0- again. Your orange light should now be off.
May 09, 2008 | LG RU-52SZ30 52" Rear Projection...
Zenith D52WLCD 52" Rear Projection HDTV-Ready Television Logo
116 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
