Question about Eureka 4700A Maxima Bagless Upright Vacuum
Cut off while vacuuming - Eureka 4700A Maxima Bagless Upright Vacuum
  • Shelleybean Jan 02, 2009
    I have had this vacuum for three years now and experienced the cutting off only when curtains or throw rugs got sucked up. I would give it a day and it would reset itself. Recently I went to vacuum and it would not even turn on. Took off belt and there's no wear on it. Paid $60 for it so, would it be worth the cost to get if fixed or just buy another vac?
    President:
  • 1,673 Answers
If it went dead, and restarted after it cooled off, then check for a clog in the hose or the dirt inlet by the brush roll. If it won't turn on, you could have a bad switch, cord, motor or a bad electrical connection.
Posted on Dec 06, 2008
Why does my vacuum keep cutting out
There is a break in the inner cable somewhere. have the flex replaced or if the break is near the connection to the vac get it refitted removing the faulty section. Get a competent person to do this !
Oct 18, 2014 | Vacuums
My kirby heritage II vacuum hose has a cut near the end of the metal nozzle. Is there a way to replace just the hose or even just cut off the damaged section and reattach to the metal nozzle?
We do carry a brand new Heritage II hose here. I do not know how you would cut and reattach the hose without losing hose integrity. You can try submerging the end in warm almost hot water and pulling off the end, cut the hose, and squeeze the end back in. But your hose will be shorter and I am not sure if it will work depending on how it is torn.
GoodVac.com Technician
www.goodvac.com
1-800-775-6586
Sep 13, 2014 | Kirby Heritage II Vacuum
Vacuum powers off and when I check the NEW belt, it looks frayed.
There is misalignment of the belt path. This can be a result of uneven wear of the brush roller.
Jan 15, 2014 | Eureka Smartvac 4870 Bagged Upright Vacuum
DC15 Brushbar Problem. Intermittant operation of brushbar. Cuts out depending on angle of vacuum. Also cuts out on lifting from floor. Normal suction at all points and no blockage. Brushbar not...
DC15 Brushbar Problem. Intermittant operation of brushbar. Cuts out depending on angle of vacuum. Also cuts out on lifting from floor. Normal suction at all points and no blockage. Brushbar not jammed. Seems like a loose connection somewhere but where ? and what
Jun 29, 2011 | Dyson DC15 All Floors - The Ball Bagless...
Power mate cuts off after a few secs.
You have a short somewhere. They can be tricky to find. You might need to take it to a repairman.
Dec 14, 2009 | Vacuums
Machine cuts out due to getting hot
most vacuums have a heat resister in when they overheat they cut out, this is normally because they are full up, got a blockage or the filters need cleaning, suggestions are, clean filters, empty and check for blockage.
Jul 13, 2009 | Dyson DC07 Allergy Blue/Turquoise Bagless...
I have an Electrolux Aerus 2100 canister vacuum. When I
it might be that the hose connections are bad.or it might be a sensor in the vacuum. call a electrolux vac shop and get it looked at.
Jun 24, 2009 | Vacuums
Sebo vacuum cleaner cuts out ?why
it might be the bag.just check with your local vacuum store
Jun 04, 2009 | Sebo X4 Bagged Upright Vacuum
likely the thermal fuse popped
its located in the motor housing
Dec 06, 2008 | Eureka 4700A Maxima Bagless Upright Vacuum
MY CLEANER CUTS OFF
My Hoover S3639 on/off switch stopped working. I don't hear the 'click' any more. I removed the top of the vacuum but can't determine how to replace the switch.
Aug 18, 2007 | Hoover S3639 WindTunnel Bagged Canister...
Eureka 4700A Maxima Bagless Upright Vacuum Logo
150 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
