Connecting Bose Acoustimass to receiver
I saw your response to the Denon posting, and want to connect a Bose Acoustimass to an A/V receiver without having the other channel speakers go through the Acooustimass.  My question is this, if I connect the Acoustimass to the receiver with the multi-pin connector (but only connecting the Acoustimass to the receiver), but then connect my other speakers directly to the receiver, will the receiver properly control the sound distribution, and will the Acoustimass work properly?
  • bdcjec May 06, 2009
    I have a Acoustimass 15 Subwoofer (5.1 channel sub w/5 dbl cubes and center channel) I have a Yamaha R665 7.1channel receiver.
    How can I connect 2 more dbl cubes for 7.1 channel sound? Any help is greatly appreciated!!!
5 Suggested Answers
  • 4 Answers
SOURCE: Bose Acoustimass 15 woofer, Replacement of RCA female connector
On the end opposite of the jacks (top of the sub opposite connectors) in the exact middle, there is a ratchet looking device (flashlight and magnifying glass reveal the little culprit) with a very small flat screw driver rotate the piece CCW until a small tab is protruding from the middle. Pu the palm of your hand on the plastic case and give it a small whack (in the direction of the jacks) it will move about a 1.2 inch. Lift straight up and the case will come off and reveal the connectors. Trust me, get a flashlight and magnifying glass and peer through the small crack between the cover and the box, you will see the little notch (encoder looking) rotating wheel
Posted on Dec 15, 2008
SOURCE: Need longer ribbon speaker wire for Acoustimass 16
I have the same question. I just called Bose at 1-877-210-3782 (prompt 6) and they have two solutions:
1. 20 foot Input extension - $25
2. Input adaptor - $12 (you can run your own speaker cable to the input adaptor)
Posted on May 08, 2009
  • 55 Answers
SOURCE: connecting Bose Acoustimas Wofer to a Sony receiver
you cannot hook a bose system up with any other system not even another bose
Posted on Sep 21, 2009
  • 10 Answers
SOURCE: Bose audio input receiver cable 15 pin
You can buy it on ebay but it's cheaper just to make one. If you can solder, all you need is a female 15-pin d-type connector and a bunch of speaker wire. Here is a diagram of the connections.
Posted on Mar 22, 2010
How do I hook up my bose 901s to this unit?
Well the basic connection of the speakers would be the same as another stereo speaker pair. Wire the left and right speakers to the L/R Front Surround speakers on the Denon.
With the 901's I am assuming that there is an external equalizer supplied by Bose. Typically this EQ is installed in a tape loop on the receiver/amp so that it is ahead of the power amplifier that drives the speakers. This EQ needs to be there to attempt to get reasonable frequency response from a speaker that has only 4" drivers. I'm not sure I see any reasonable way to make the EQ work with the Denon AV receiver. You'd likely be better off using the Bose speakers in a dedicated 2-channel stereo and getting a set of speakers for the AV usage.
Apr 16, 2016 | Denon Avr 3805 7.1 Channel Audio Video...
How to connect denon AVR 1513+Bose Acoustimass 5
Plug the speaker wire from the speakers themselves directy to the receiver or you can plug them into the acoutimass module and the module into the receiver using speaker wire.12_16_2013_3_46_09_pm.gif
Feb 19, 2013 | Denon Avr-1513 5.1 Channel 3d Pass Through...
Denon avr-1804/884, speakers Bose vcs center, Bose acoustimass 5 series 3 speaker system, Bose 201 series 4. All speakers play in test mode, with tuner, dvd, phono, cassette. The left side speakers will...
You don't say how "TV audio" is entering the system.
My guess is you're using analog audio Out from the TV into an analog input on the Denon. One channel failing would probably be the Left Channel cable failing or not seated.
I always recommend bypassing the TV audio entirely if the programming comes from somewhere other than its own antenna, as TV audio electronics add nothing good to the process.
If you're using cable box, sat box, game, whatever, ITS audio is best sent directly to your Denon's specialized audio hardware - digitally, if possible, to preserve multichannel possibilities.
You could also run standard analog audio from the cable box to the TV analog Audio IN if you just want to watch news and weather on TV speakers without the Denon involved.
Jan 11, 2011 | Denon AVR-1804 Receiver
AVR-1910 & Bose Lifestyle 35 setup
Bose Lifestyle (and all Bose-amplified speaker) products and their speakers are SYSTEMS and should not be split up or intermixed with other brands or models. Damage will probably result. Proprietary connectors provides a clue.
The digital audio out should work with the Bose. You could still use your Denon to drive a conventional sub in your scheme, but you would have to manually match volume with the Bose. Or go Full Monty and buy a full complement of speakers for the Denon, retask the Bose and slave its sources to the Denon.
Dec 05, 2009 | Audio Players & Recorders
Is there a current model receiver that I can puchase to drive my existing subwoofer and 5 speaker set? My Series 5 died.
How to connect Bose Acoustimass 25 series II subwoofer to Denon Receiver using factory provided 13pin cable
Oct 25, 2009 | Bose Lifestyle 25 System
I am planning on buying Denon AVR 1909 receiver. Can hook it up with Bose Acoustimass 6 speakers. DOes the Denon blow up the small bose speakers. If yes how do i hook them up.
on the am 6 by bose you have to use all the supplied cables or you will blow them. the way it works is that all the speaker signal/power from the denon goes directly to the sub, then the sub sends the signal to each speaker. if you do this correctly the sub takes what it needs and sends the rest to the smaller speakers. and you wont blow them unless you hook them directly to your reciever.
Jul 30, 2009 | Audio Players & Recorders
Left Channel Not Working.
Has it ever worked?
Try this - connect one pair of its speaker wires at a time and test it. Watch the polarity.
• Make sure all cube speaker arrays are connected to the proper terminals according to their
position in your room.
• Check to be sure all wires are connected to your surround receiver with the proper polarity
(+ to + and – to – wires). Incorrect wiring can result in a total loss of module output.
• Correct any wiring problems before you plug in your receiver and turn it on.
How do you know the receiver's Left channel isn't the fault? Sounds like a source issue.
Jan 04, 2009 | Bose Acoustimass 16 Speaker
Initial Bose Speakr Hook-Up Acoust 10-Denon RCVR
Hope this may help but you will disappointed. as heard from some pro, your amp will blow up the bose cube if direct connected to them, they are powering down your output to fit their tiny speaker. My understanding was you have to hook up everything to the bose module. They don't like to play with others.
http://www.allbose.com/Question.aspx?id=64108
(Page11)
http://www.riverparkinc.com/techpdf/Bose%20AM6%20&%20AM10%20Series%20III%20owners%20manual.pdf
Dec 14, 2008 | Bose Acoustimass 10 II System
Denon AVR 2807 with Bose Acoustimass 15
Well,i can tell you are not very focus,cause you posted Denon AVR-2807 with Bose AC 15 problem,but under your details,you put down AVR-5807!
First of all,it is so unfortunate that you are NOT able to gain and experience to true ability in sound for this wonderful receiver when you are using a dual tweeters speakers and expect to have good sound separation as a TWO WAY speakers(a tweeter and a midrange-for true high frequency and mid frequency sound separation.)
Secondly,you have defeated the audio configuration of the Denon AVR-2807,since all your speakers are control BY the Bose subwoofer.
Now,i could show you a way to hook this up,and it doesn't matter how you connect them, they are the "bicycle tires" installed with a "Porche"engine if you know what i mean.
If you want a good recommendation for your "beast",i will more than happy to show you the way!
Cheers,
solutiondoct
Sep 28, 2008 | Denon AVR-2807 Receiver
1,458 people viewed this question
 Grubhead
Grubhead
