Question about Eureka 4700A Maxima Bagless Upright Vacuum
Cut off while vacuuming
I was vacuuming and it cut off by itself
  • mcbride522 Feb 14, 2009
    i can vacum for about 10 or 15 mins. and its shut off until about 15 mins. what cause this and is it something i can fix?
  • 125 Answers
Likely the thermal fuse popped
its located in the motor housing
Posted on Dec 08, 2008
An Electrolux Z8266 won't stay on. It'll turns itself off in 2" after it's been switched on. Could you help? Thx! Gary.
Electrolux Twin Clean Washable Hepa Filter EF78 900196701 8
Check for clogs first Motor restricted air flow will cut it off, also change your filters if you havent done it your vacuum is quite old
Apr 01, 2017 | Electrolux Vacuums
The machine runs for brief periods, then shuts itself off. If it is allowed to sit for several minutes, it runs again, then shuts itself off.
the motor is heating up to much and the cut out switch is kicking in. You need to check the the motor filter, and worse case you may need to new motor..
Oct 04, 2010 | Dyson DC14 All floors Bagless Upright...
The powerhead cuts in and out on power as you vacuum with the brushes. Works ok with suction only. Have replaced both wands and still cuts out, Can it be the powerhead connections? Help? TJZ
had the same problem with mine check all the prongs on the 2 wands and on the power nozzle and on the handle itself you will probably see that one of them is discolored or burned looking you will need to replace that section, I had to replace one of my wands, and then a second time I had to replace the hose section with the handle attached.
Oct 04, 2009 | Eureka 6984A Bagged Canister Vacuum
Is there a reset button on the dyson
The short answer: No. The longer answer begins with a question: why do you need to know, what's happened to make you ask? Most Dysons have a built in cut-out system that stops the machine if it gets too hot. This usually happens because the filter needs washing or the machine is blocked. If your machine turns off on its own, unplug it and leave it for at least an hour. The cut-out should reset itself when it's cool enough.  Remember to check the filter and look for blockages before re-starting.  If the cut-out does not reset itself, you may need professional help.
Feb 28, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Just stopped running while vacuuming
When a vacuum cuts out while working, it usually indicates overheating. Most have a thermal cut-out, which will reset itself if given time to cool. The cause is usually a blockage of some sort.
Feb 15, 2009 | Kirby G6 Bagged Upright Vacuum
Nutone CV-750
You need to determine if this is a problem with the hose or the unit. I would recommend plugging my hose in the wall sideways. This should make your central vacuum run continuously. If the unit doesn't cut on and off it is the hose. If it still cuts on and off it is probably the relay.
Jan 06, 2009 | Broan-NuTone CV353 Central Vacuum
CUTTING OFF
Ok What is probably causing the problem is an internal error inside the vacuum. What I recomend you to do is take it back where you bought it and tell them what ever is wrong with it.
PLEASE RATE MY ANSWER AS SOON AS POSSIBLE!
Hope it works! Tell me if you have any questions later on!
Jun 17, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Thermal senser
If it is going bad, it will cause the motor to shut down, replace it then you will know if that is the problem or a problem with the motor itself.
Mar 24, 2008 | Vacuums
It just turned off
Could be the cord, overload protector for the motor, or the motor itself.
Mar 15, 2008 | Kenmore 34721 Upright Vacuum
Kenmore vacuum 116.36720600
Can be various reasons, the cord is bad, problem with the switch. Also there is a protector for the motor or the motor itself. The 1st thing I would check would be the cord.
Nov 20, 2007 | Vacuums
Eureka 4700A Maxima Bagless Upright Vacuum Logo
223 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
