Question about HP Officejet 7210 All-In-One InkJet Printer
Paper size error when copying - Office jet 7210
When I attempt to copy a document from the glass (8 1/2 X 11 to same), I receive the error "Paper Size Error, Paper Size Detected is Not Supported, Press OK to Cancel job".
I got the same error, and had it for months. open the ink door where it says office jet pro, it folds towards you, wait for the ink cartage to position to the left, then look inside and far to the right, and see if there is a wadded up peace of paper inside. Reach in and pull it out, it fixes the problem
Posted on Oct 22, 2012
    Guru:
  • 1,049 Answers
Open the scanner lid and make sure that the white backing is clean and not ripped. Try putting 8.5x11 paper behind what your copying, or you can hardcode/set the paper size to 8.5x11 instead of auto.
Posted on Dec 10, 2008
Not detecting paper on top of the glass
if you are trying to scan/copy a receipt of something else that is smaller, try to tape it to a regular sheet of paper before you copy it.
then the unit can detect the paper size.
Jan 02, 2014 | HP Office Jet 4500 G510n
HP Office jet plus 8600+ - supposed to print legal but does not!!?!
The printer set up procedure may reveal there is no provision for legal size printing.
May 26, 2017 | HP OfficeJet Pro K8600 Printer
Change legal size to letter size
scan it as a document, re-scale it in required size and save then print in required size.
these adjustments are in your word or office programs. if you need to make it to copy, insert your original in the scanner, in paper tray insert your letter paper, select copy and then re-size, this should do it "on the run".
Jul 26, 2010 | Dell 1815dn All-In-One Laser Printer
Scanner failure message
the main system is faulty same thing happened to me.
Aug 14, 2009 | HP 7210 OfficeJet All-In-One Printer
Paper Size Error: The specified custom paper size is not supported in the selected tray. I have a Hp Officejet pro L7780 All in one. I checked the default printer and paper handling and it all says letter...
1. Press the OK button to bring you back.
2. Press the menu button repeatedly until paper size comes up
3. Use arrows to change paper size from automatic to whatever size you are looking for.
4. Start Copy
This worked for the HP Officejet 7210 All in one
Jun 01, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
My HP 3210 won't make copies
HP has a pretty good online troubleshooting site, accessible at support at www.hp.com. I'm not familiar with that particular error, but you might try the steps outlined in this link for starters...
If changing the size settings doesn't work, try changing both size and type and rebooting, then changing back to your standards. That should force the driver to be reloaded. Sometimes all you can do is reset the printer. To do this,, turn off printer, unplug both power and data cables, wait a few minutes, then reconnect and turn on again.
But search the online database for more specific instructions for your model.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 15, 2009 | HP Photosmart 3310 All-In-One InkJet...
Can't get the copier to scan only 8.5*11 area on glass
Set your original settings to the actual size.
You are using the auto recognition feature which is over-ridden when you specify the size manually.
It will try to match it to the nearest size it "knows". That is why the stamp is detecting so large.
Apr 09, 2009 | Konica Minolta Di1610 Copier
HP Office jet 7210 All in One. When I feed paper
Lean the rollers in the automatic document feeder (ADF)
  1. Remove the document feeder tray from the product by gently pulling it.
  2. Lift the cover of the automatic document feeder by pulling it outward.
  3. Gently clean the rollers with a very damp cloth ansd a dab of dish detergent.
  4. Close the cover of the automatic document feeder, and then reattach the document feeder tray.
To clear the "scanner error" message do a
Perform a partial reset
  1. Disconnect the power cord from the product.
  2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
  3. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the partial reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next step to try a semi-full reset.
If a partial reset did not work do the following: Perform a semi-full reset CAUTION: Performing a semi-full reset deletes any saved phone numbers on the product.
  2. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
    • If the semi-full reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, unit may need service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 11, 2009 | HP 7210 OfficeJet All-In-One Printer
Making a copy
Open the document feeder and clean the scanner glass.
Feb 26, 2009 | Office Equipment & Supplies
Scanning on an mp500
First you should have installed the scanner in the computer using the cd comes with the scanner.
  1. Confirm that the printer is powered on and press the <Open> button. (The paper output tray will open.)
  2. Load paper in the auto sheet feeder or the cassette in the portrait orientation.
  3. Lift the document cover and set a document on the platen glass.
    MEMO:
    - Regardless of the document size, set it in the landscape orientation.
    - Place the copying face down on the platen glass.
    - Align the document with the alignment mark (shown as the arrow) on the lower right corner of the platen glass.
    Note: The machine cannot scan the area approximately 3 mm from the front and right edges of the platen glass.
    < 1 > Alignment Mark
  4. Close the document cover gently.
  5. Confirm that the printer is in Copy mode. If the printer is not in Copy mode, press the <COPY> button to switch into Copy mode.
  6. Check the copy settings, following the procedures below carefully.
    < 1 > Check the paper size and media type.
    < 2 > Use the up / down cursor button to specify the number of copies.
    < 3 > Use the right / left cursor button to adjust the intensity.
    Memo: Pressing the right cursor button increases the intensity. Pressing the left cursor button decreases the intensity.
  7. Press the <Color> button for color copying, or the <Black> button for black & white copying. (The printer starts copying.)
    Note: To cancel copying, press the <Stop/Reset> button.
Apr 02, 2008 | Canon Pixma MP500 All-In-One InkJet...
HP Officejet 7210 All-In-One InkJet Printer Logo
322 people viewed this question
Seeker5211
Seeker5211
