Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
Philips 60pw9363 double image
I tried fixing this problem by aligning the multipoint (red/blue), But the first top crosses are way off. What do you think is the problem?
  • blufuel104 Apr 19, 2009
    Are these "resistors" ez to fix myself, or do I need a "tech" to come in and fix them?
  • 505 Answers
You have bad convergence ICs. Replacing them with any possible bad resistors will fix the problem. They are hooked to the largest heatsinks inside the tv, like stk392-120 or simmilar ICs.
Posted on Dec 07, 2008
Is there a code number that needs to be entered to bring the convergence pattern or menu on screen.
From a user standpoint you would follow these steps to bring up your Convergence menu:
1) Press your MENU button.
2) Press the Right Cursor Button to enter the Picture menu.
3) Press the Down Cursor Button until you highlight the MANUAL CONVERGENCE choice on the menu.
4) You will then see the following choices on the right hand side of the menu: Convergence Red, Convergence Blue, Multipoint Red, Multi Blue, Save Multipoint.
5) Once you choose either the Red or Blue choices you will get a crosshair in the middle of your screen. You will then use either your Up, Down, Left, or Right Cursor buttons to get the two images to line up correctly. If you still have multi images on your screen in either Red or Blue you would then have to adjust the Multipoint choice for that color.
May 14, 2011 | Philips 51PP9100D 51 in. Television
Multipoint blue convergence cannot be adjusted
Sound like you need to replace the STK's and any blown pico's on convergence board.
Jan 20, 2008 | Philips 60PP9202 60" Rear Projection...
My phillips 60 in projection tv has color distortion and the multipoint converge wont let me adjust the cross hairs
Hi..... well if is a LCD Rear projection Tv is a issue with one of the color filters, and you will need to change at least the optical block or the light engine system, I always buy them from www.discount-merchant.com
If TV is DLP it might be a issue with the color wheel, you might be able to hear a buzzing sound.
Jun 27, 2009 | Philips 60PW9363 60" Rear Projection...
Convergence problem with Philips 51PW936317F TV
bad news probably not economic to repair
Dec 15, 2008 | Televison & Video
60PP9352 philip hdtv
Classic symptom - Your convergence chips are toast.You can
get a repair kit with photo instructions from www.TvRepairKits.com.
Sep 30, 2008 | Philips 60PP9352 60" Rear Projection...
Screen appears curved on top and bottom
One or more colors can't be adjusted when when using the convergence menu. Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jul 22, 2008 | Philips 55PW9363 55" Rear Projection...
Blue Multipoint converge failure Philips 55PP9753
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 12, 2008 | Philips 55PP9753 55" Rear Projection...
Menue and multipoint
I fixed this tonight -- it was the convergence amps, which I purchased for $20. Thought it was the convergence board at first but it turned out to be the amps, which commonly fail after 3 years or so.
Dec 17, 2007 | Philips 60PP9202 60" Rear Projection...
Red bow at top left and botton left of screen
Lost of high voltage on the vertical amp was caused the bowing. That was a simple tweak. I'm sorry to tell you that the high voltage adjustments are rather precise and have major interaction with each other. The HV circuit is also used to power low voltage circuits to gain efficiency. If one or more are not within spec, the process to recovery will require bench alignment of the various stages. Seek professional help or consider replacing. Good luck
May 21, 2007 | Philips 60PW9363 60" Rear Projection...
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
