Question about Samsung HLR5067WX 50" Rear Projection HDTV
Auto focus problem SAMSUNG SP-48T5HP
Can any one tell me why the auto focus mode won't clock through to 100%on a Samsung SP-48T5HP?
  • fetuccinni Nov 15, 2007
    out of focus completely, don't know what to do... :(
  • gbabe12 Oct 27, 2008
    im seeing double on my screen, tring to fix the convergence thing, dont know wat im doing, auto focus is not helping either. if any1 knows or has a manual to help would b gr8ly appreciated.....
    President:
  • 1,284 Answers
It needs to most likely be re-initilized in a technician service menu. If the convergence looks fine otherwise this is most likely the cause.
Posted on Mar 02, 2007
SAMSUNG SCH MICF399 SOLUTION
Setting answer options - Samsung Convoy (SCH-u640)
  1. From the main screen, press OK to choose MENU.
  2. Select Settings & Tools then press OK.
  3. Select Call Settings then press OK.
  4. Select Answer Options then press OK.
  5. Select the desired option, press OK to choose MARK then press the left soft key to choose Done. Flip Open Answer calls when the phone is opened.
    linote.gif Speakerphone is automatically activated. Any Key Answer calls by pressing any key. Auto w / Handsfree Automatically answer calls with a handsfree device On the main screen type *#06#
    Information you get from the IMEI (International Mobile Equipment Identity)
    XXXXXX XX XXXXXX X
    TAC FAC SNR SP
    TAC = Type approval code of your samsung Mobile
    FAC = Final assembly code of your cellphone
    SNR = Serial number of your samsung Phone
    SP = Spare
*#06# IMEI code
*#9998*4357# Help Menu
*#9998*5282# Java menu (GRPS/CSD settings for JAVA server)
*#9999#0# Monitor Mode
*#9999# or *#9998*9999# Software Version
*#8888# or *#9998*8888# Hardware Version
*#9998*746# or *#9998*0746# or *#0746# Sim Infos
*#9998*523# or *#9998*0523# or *#0523# Display Contrast
*#9998*842# or *#9998*0842# or *#0842# Vibration On (until you push OK)
*#9998*289# or *#9998*0289# or *#0289# Buzzer On (until you push OK)
*#9998*288# or *#9998*0288# or *#0288# Battery & Field Infos
*#9998*377# or *#9998*0377# Error log
*#9998*778# or *#9998*0778# or *#0778# Sim Service table
*#9998*782# show date and alarm clock
*#8999*638# show network information
*#9998*5646# change operator logo at startup
*#9998*76# production number
*#9998*968# view melody for alarm
*#9998*585# Non-Volatile Memory (NVM)
*#3243948# Digital Audio Interference Off
*#32436837# Digital Audio Interference On
*#1111# S/W Version
*#1234# Firmware Version
*#2222# H/W Version
*#8999*8376263# All Versions Together
*#8999*8378# Test Menu
*#4777*8665# GPSR Tool
*#8999*523# LCD Brightness
*#8999*377# Error LOG Menu
*#8999*327# EEP Menu
*#8999*667# Debug Mode
*#92782# PhoneModel (Wap)
#*5737425# JAVA Mode
*#2255# Call List
*#232337# Bluetooth MAC Adress
*#5282837# Java Version
Type in *#0000# on a Samsung A300 to reset the language
Master reset(unlock) #*7337# (for the new samsungs E700 x600 but not E710)
Samsung E700 type *#2255# to show secret call log (not tested)
Samsung A300, A800 phone unlock enter this *2767*637#
Samsung V200, S100, S300 phone unlock : *2767*782257378#
#*22671# AMR REC START
#*22672# Stop AMR REC (File name: /a/multimedia/sounds/voice list/ENGMODE.amr)
#*22673# Pause REC
#*22674# Resume REC
#*22675# AMR Playback
#*22676# AMR Stop Play
#*22677# Pause Play
#*22678# Resume Play
#*77261# PCM Rec Req
#*77262# Stop PCM Rec
#*77263# PCM Playback
#*77264# PCM Stop Play
#*22679# AMR Get Time
*#8999*364# Watchdog ON/OFF
*#8999*427# WATCHDOG signal route setup
*2767*3855# = Full Reset (Caution every stored data will be deleted.)
*2767*2878# = Custom Reset
*2767*927# = Wap Reset
*2767*226372# = Camera Reset (deletes photos)
*2767*688# Reset Mobile TV
#7263867# = RAM Dump (On or Off)
#*4773# Incremental Redundancy
#*7785# Reset wakeup & RTK timer cariables/variables
#*7200# Tone Generator Mute
#*3888# BLUETOOTH Test mode
#*7828# Task screen
#*#8377466# S/W Version & H/W Version
#*2562# Restarts Phone
#*2565# No Blocking? General Defense.
#*3353# General Defense, Code Erased.
#*3837# Phone Hangs on White screen.
#*3849# Restarts Phone
#*7337# Restarts Phone (Resets Wap Settings)
#*2886# AutoAnswer ON/OFF
#*7288# GPRS Detached/Attached
#*7287# GPRS Attached
#*7666# White Screen
#*7693# Sleep Deactivate/Activate
#*2286# Databattery
#*2527# GPRS switching set to (Class 4, 8, 9, 10)
#*2679# Copycat feature Activa/Deactivate
#*3940# External looptest 9600 bps
#*4263# Handsfree mode Activate/Deactivate
#*2558# Time ON
#*3941# External looptest 115200 bps
#*5176# L1 Sleep
#*7462# SIM Phase
#*7983# Voltage/Freq
#*7986# Voltage
#*8466# Old Time
#*2255# Call Failed
#*5376# DELETE ALL SMS!!!!
#*6837# Official Software Version: (0003000016000702)
#*2337# Permanent Registration Beep
#*2474# Charging Duration
#*2834# Audio Path (Handsfree)
#*3270# DCS Support Activate/Deactivate
#*3282# Data Activate/Deactivate
#*3476# EGSM Activate/Deactivate
#*3676# FORMAT FLASH VOLUME!!!
#*4760# GSM Activate/Deactivate
#*4864# White Screen
#*7326# Accessory
#*7683# Sleep variable
#*3797# Blinks 3D030300 in RED
#*7372# Resetting the time to DPB variables
#*3273# EGPRS multislot (Class 4, 8, 9, 10)
#*7722# RLC bitmap compression Activate/Deactivate
#*2351# Blinks 1347E201 in RED
#*2775# Switch to 2 inner speaker
#*7878# FirstStartup (0=NO, 1=YES)
#*3838# Blinks 3D030300 in RED
#*2077# GPRS Switch
#*2027# GPRS Switch
#*0227# GPRS Switch
#*0277# GPRS Switch
*#7465625# = Check the phone lock status
*7465625*638*Code# = Enables Network lock
#7465625*638*Code# = Disables Network lock
*7465625*782*Code# = Enables Subset lock
#7465625*782*Code# = Disables Subset lock
*7465625*77*Code# = Enables SP lock
#7465625*77*Code# = Disables SP lock
*7465625*27*Code# = Enables CP lock
#7465625*27*Code# = Disables CP lock
*7465625*746*Code# = Enables SIM lock
#7465625*746*Code# = Disables SIM lock
*7465625*228# = Activa lock ON
#7465625*228# = Activa lock OFF
*7465625*28638# = Auto Network lock ON
#7465625*28638# = Auto Network lock OFF
*7465625*28782# = Auto subset lock ON
#7465625*28782# = Auto subset lock OFF
*7465625*2877# = Auto SP lock ON
#7465625*2877# = Auto SP lock OFF
*7465625*2827# = Auto CP lock ON
#7465625*2827# = Auto CP lock OFF
*7465625*28746# = Auto SIM lock ON
#7465625*28746# = Auto SIM lock OFF
*2767*49927# = Germany WAP Settings
*2767*44927# = UK WAP Settings
*2767*31927# = Netherlands WAP Settings
*2767*420927# = Czech WAP Settings
*2767*43927# = Austria WAP Settings
*2767*39927# = Italy WAP Settings
*2767*33927# = France WAP Settings
*2767*351927# = Portugal WAP Settings
*2767*34927# = Spain WAP Settings
*2767*46927# = Sweden WAP Settings
*2767*380927# = Ukraine WAP Settings
*2767*7927# = Russia WAP Settings
*2767*30927# = GREECE WAP Settings
*2767*73738927# = WAP Settings Reset
*2767*49667# = Germany MMS Settings
*2767*44667# = UK MMS Settings
*2767*31667# = Netherlands MMS Settings
*2767*420667# = Czech MMS Settings
*2767*43667# = Austria MMS Settings
*2767*39667# = Italy MMS Settings
*2767*33667# = France MMS Settings
*2767*351667# = Portugal MMS Settings
*2767*34667# = Spain MMS Settings
*2767*46667# = Sweden MMS Settings
*2767*380667# = Ukraine MMS Settings
*2767*7667#. = Russia MMS Settings
*2767*30667# = GREECE MMS Settings
Type *#9998*627837793# Go to the 'my parameters' and there you will find new menu where you can unlock phone.(not tested-for samsung C100)
To unlock a Samsung turn the phone off take the sim card and type the following code *#pw+15853649247w# .
Java status code: #*53696# (Samsung X600)
Feb 14, 2012 | Samsung Cell Phones
Samsung Projection TV - Yellow White Level and Auto Focus Failure
perfect focus is based on service mode convergence. FActory setting as it were. the set needs to converged in service mode then these values stored then it should work
Jan 03, 2008 | Samsung PCL541R 54" Rear Projection...
Tip
Unlock your samsung phone in just a simple trick
hi there everyone i would like to share this trick for some of samsung mobile phones
having problem with your phone it always says wrong card????
then try this one...
Note...this code is not working with some of samsung phones...
so just try it...100% it will not damage your phone
just follow this step
1st Make Full Eprom Reset *2767*3855#
After Rebooting Mobile
then enter....
*7465625*638*00000000*00000000# (to change NCK code to 00000000)
then enter...
#7465625*638*00000000# (to permanently unlock the phone)
check the lock status...
*#7465625#
Input *#7465625# to check the locks....all locks should now be inactive as shown below:
network lock - inactive
subset lock - inactive
sp lock - inactive
cp lock - inactive
sim lock - inactive
activa lock - inactive
phone lock - inactive
auto network - inactive
auto subset lock - inactive
auto sp lock - inactive
auto cp lock - inactive
auto sim lock - inactive
hope it will help you
on Dec 30, 2009 | Cell Phones
Tip
All Codes for SAMSUNG SYNC SGH A707
Normal 0 MicrosoftInternetExplorer4 Following are the list of all codes for Samsung Sync SGH A707 with their functions.Use them at normal dial screen and at your own risk:
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Get IMEI: *#06#
Reset phone to factory settings: *2767*3855#
Disable auto sp: #7465625*2877#
*#1111# S/W Version
*#2222# H/W Version
*#4777*8665# Power on attach (GPRS tool?)
*#7465625# = Check the locks (network, subset,etc)
*#1111# S/W Version
*#2222# H/W Version
*#232337# Bluetooth MAC Address
*#7465625# = Check the locks (network, subset, etc)
*#0*# LCD Test
*#0228#
Battery info
*#0289# Melody test
*#0782# Show the real time clock
*#0842# Vibration test
*#5002*8376263# Some info
*#0002*28346# <---test mode (another menu)
*#0523# Test Menu
NOTE:ALL ABOVE INFORMATION IS FOR EDUCATIONAL PERPOSE.USE THEM AT YOUR OWN RISK.
on Dec 08, 2009 | Samsung SYNC SGH-A707 Cellular Phone
Forgot my password for samsung e 390
Hello Dear,
Type the code * 2767 * 3855 # and the phonewill reset to the factory settings. Other interestingcodes for Samsung phones: * # 0228 # BatteryInformation
* # 0673 # Test MP3
* # 0782 # Date and Time
* # 0842 # VibrationTest
* # 1111 # SoftwareVersion FTA
* # 1234 # Softwareversion (short)
* # 1235789 # StateControl of Integrity
Hardware Version * #2222 # FTA
* # 232337 # BluetoothBroadcast Address View
* # 32489 # State ofCiphering
* # 742695 # Softwareversion, Hardware Version, Date of Last Calibration Radiofrequency
(Equivalent to * # 8999* 8376263 #)
* # 8999 * 8376263 #Software version, Hardware Version, Date of Last Calibration Radiofrequency
(Equivalent to 742 695* # #) * # 1546792 * #Admin settings (WARNING: not to experiment!)
(* # * 73561 # OperatorCode, where applicable)
(* # 2456987 * # MasterKey) # * # 123580 TestMode main menu (not to experiment!, Equivalent to * # 9998 * 324 #)
* # 9998 * 324 # TestMode main menu (not to experiment!, Equivalent to * # 123580 #)
* # 0002 * 28346 # ItemMenu Handset Volume (sub-menu of the Test Mode Menu)
* # 0011 # NetworkConnection Status
(Same as in Test Mode,which not only returns to the main menu of the Test Mode)
* # 7412359 # Test MenuRadiofrequency
* # 9999 * 0 # NetworkMonitor
(Same as in Test Mode,which not only returns to the main menu of the Test Mode) * # 7465625 # setthe Phone List of Blocks # 7465625 * 27 *code # Remove the "PC Lock"
# 7465625 * 638 * Code# Remove the "Network Lock"
# 7465625 * 685 * Code# Remove the "Multi Lock"
# 7465625 * 746 * Code# Remove the "SIM Lock"
# 7465625 * 77 * code #Removes the "SP Lock"
# 7465625 * 782 * Code# Remove the "Subset Lock"
# 7465625 * 228 #Disable "Activa Lock"
# 7465625 * 2827 #Disable "Auto CP Lock"
# 7465625 * 28638 #Disable "Auto Network Lock"
# 7465625 * 28685 #Disable "Auto Multi Lock"
# 7465625 * 28746 #Disable "Auto SIM Lock"
# 7465625 * 2877 #Disable "Auto SP Lock"
# 7465625 * 28782 #Disable "Auto Subset Lock" Malicious code:
* 2767 * 3855 #Reset Full Phone (back as "just bought") * 7465625 * 27 *code # Set the "PC Lock"
* 7465625 * 638 * Code# Set the "Network Lock"
* 7465625 * 685 * Code# Set the "Multi Lock"
* 7465625 * 746 * Code# Set the "SIM Lock"
* 7465625 * 77 * code #Set the "SP Lock"
* 7465625 * 782 * Code# Set the "Subset Lock"
* 7465625 * 228 #Enable "Activa Lock" to restart the phone
* 7465625 * 2827 #Activate "Auto CP Lock" to restart the phone
* 7465625 * 28638 #Turn on "Auto Network Lock" to restart the phone
* 7465625 * 28685 #Turn on "Auto Multi Lock" to restart the phone
* 7465625 * 28746 #Turn on "Auto SIM Lock" to restart the phone
* 7465625 * 2877 #Activate "Auto SP Lock" to restart the phone
* 7465625 * 28782 #Turn on "Auto Subset Lock" to restart the phone These codes areworth a bit more for all Samsung phones, in particular: Samsung E390,Samsung Ultra Video F500, Samsung F510, Samsung F520, Samsung F700, Samsung SGHi520, Samsung i600, Samsung i620, Samsung L760, Samsung P910, Samsung P920,Samsung P940, Samsung SCHB100, Samsung SGH F600, Samsung SGH i550, Samsung SGHJ750, Samsung SGH I600, SGH i607 Samsung Blackjack, Samsung SGH P930, SamsungSGH Z630, Samsung Ultra Edition 12.1 (U700), Samsung Z100, Samsung Z105u,Samsung Z107V, Samsung Z110, Samsung Z130, Samsung Z140, Samsung Z140V, SamsungZ150, Samsung Z170, Samsung Z220, Samsung Z230, Samsung Z300, Samsung Z310, SamsungZ320, Samsung Z330, Samsung Z350, Samsung Z360, Samsung Z370, Samsung Z400,Samsung Z500, Samsung Z510, Samsung Z520, Samsung Z540, Samsung Z550 , SamsungZ560, Samsung Z600, Samsung Z610, Samsung Z620, Samsung Z650i, Samsung Z700,Samsung Z710, Samsung Z720, Samsung ZV10, Samsung ZV30, Samsung ZV40, SamsungZV50, Samsung ZV60, Samsung ZX10, Samsung ZX20. WARNING: Someof these codes may cause blockage or malfunction of the cell, therefore, it isunderstood that you use them at your own risk.
Dec 04, 2011 | Samsung SGH-E390 Cellular Phone
My Samsung S8000 has come up with no sim mode. Wont work with simm in have tried all ways
Sir,, very sorry for it but there is only a last way please go to samsung mobile service centre. you can find your nearest centre from this url http://www.samsung.com/in/support/location/serviceLocation.do?page=SERVICE.LOCATION ,,have you reseted your phone or not try this *2767*3855# if problem continues then type this code and check *#7465625# ,and see which option is locked in your phone then inform me or you can use these codes to deactivate the specific type of lock... *#7465625# = Check the phone lock status
Bye and please rate me,,./.
Aug 24, 2011 | Samsung Cell Phones
I have a samsung SL502 and it started showing grid like lines on my screen- how can I get those off?
You are seeing grid like lines because the camera is in the multi auto-focus mode.You can select it to Center auto-focus mode by selecting the Focus Area option from the left of the screen and changing it to Center AF.If you need further clarification please have this detailed user manual from the following link. {Refer page number 44}. Good luck. ( http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man )
Jun 02, 2011 | Samsung SL502 Digital Camera
I i forgot my phone lock code for my samsung sgh-f480
hard reset *2767*3855#
All Samsung Hard Reset Codes
In those steps:
1.)*2767*3855#
2.)*7465625*638*00000000*00000000#
3.)#7465625*638*00000000#
Now your phone is unlock forever Permanent
Here is Samsung F480 Secret Codes
Admin Settings: *#6984125*#
Admin Settings
Internals (sub menu): *#9072641*#
Developer Settings: *#0523#
Camera test mode:
Press *#36287# key string in the dial screen to enter camera test mode -
[1] Auto focus [On]
[2] ISP firmware write
[3] ISP firmware version check
[1] Press the "1" key to disable auto focus. In order to enable auto focus, press the "1" key again.
[2] Press the "2" key to write the ISP (Camera Module) firmware. “ISP firmware write [Please wait]” will be displayed during 2 minutes. Then "ISP firmware write [SUCCESS]” will be displayed when the firmware upload finished.
Jun 08, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Green Out Of Focus
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
May 30, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Codes
Samsung Secret Codes
*2767*688# = Unlocking Code
*#8999*8378# = All in one Code
*2767*3855# = E2P Full Reset
*2767*2878# = E2P Custom Reset
Mar 08, 2008 | Samsung Blackjack SGH-I607 Smartphone
Samsung HLR5067WX 50" Rear Projection HDTV Logo
336 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
