Whirlwind -Air Cooler with Heater and Humidifier, FH-778 Air Conditioner
How do i know if my cooling system can be repaired...
shared by 3 users
By Bray - usenet poster
How do i know if my cooling system can be repaired or if it is time to replace it?
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Posted by Guest on Jul 10, 2008
only fan is working no cool air
Posted by Guest on Jun 10, 2008
we have a unit given to us ,but when we turn it on it would be cold for a few minutes then we here the compressor turn off and no cold air??
Best Solution
posted on Aug 08, 2005
Helpful (85)
Kim1
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Consider replacing if:
Your heat pump or air conditioner is more than 10 years old Your furnace or boiler is more than 15 years old Your equipment needs frequent repairs and your energy bills are going up Some rooms in your home are too hot or too cold No one is home for long periods of the day and you do not have a programmable thermostat Your home has humidity problems Your home has excessive dust Your heating or cooling system is noisy
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on How do i know if my cooling system can be repaired or if it is time to replace it?:
I don't want to Accept this solution
Solution #2
posted on Aug 08, 2007
Not Rated (0)
CanDo
Rank:Wiz Wiz
Rating: 77%, 120 votes
If you need to replace it, it will be because it is not working well or not adaquately cooling your home. After 10 years motors dry out if you don't service them yearly or bi yearly the bushings will burn out because of being dry and not enough lubrication on the bearings and bushing. Some units are cheaper than others and they go out more quickly. others are more expensive and have been built alot better and will naturally last longer. When bearings and bushings dry out there is more pull of electricity to turn the motors. And eventually they will lockup or burn out.
Motors can be replaced with better grades that are more expensive but will last much longer.
Newer units these days are very efficient using less electricity and cooling better.
Thank You!
Can you Help with these Air Conditioners problems?
Air Conditioners
What is the procedure for adjusting a honeywell blower...
Air Conditioners
my central heating has a 4073A fitted when I select HW...
Whirlwind -Air Cooler with Heater and...
How do I recover the freon to the condensor and store it...
I have a 30 # cylinder of R22, I have the gages, how do I...
water fill light stays on all the time even when water...
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Repair Service
Find Air Conditioner Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Air Conditioning Contractors
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
