Question about SanDisk Sansa e250 MP3 Player
WHERE IS MY MEMORY?!?
I deleted everything on my Sansa using the menu in "my computer." The info screen reads zero songs, zero voice recordings and zero fm recordings. So why does my player show that I have only 798MB of free memory instead of the original 1893MB?
  • 8,596 Answers
Reformat
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
I have sansa 4gb. i recorded some songs and its stored in voice module. when i transferred it to my computer using cut paste option, the files are not getting deleted in sansa.i can neither do the same in...
probably the memory it has some kinda option for the files...like read only ..or delete protection ...try to rest it to factory settings ..using the rest button ..or by removing the battery ..This should fix the issue ..or ..get into the memory settings and see what is the issue ..under options ..
If this is happening only with the internal memory ..or with voice module ...area..than only there you should look under options ..and see
usually the cut will not function ...but they should be able to be deleted when you delete them using the device's own menu ..
Jan 13, 2011 | SanDisk Sansa e260 MP3 Player
How Can I Retrieve Voice Recordings that I have deleted
no because once you delete it it deletes the whole voice and everything out of the memory Sorry
Sep 29, 2009 | Audio Players & Recorders
Delete songs
If you have a Sansa Fuze you can play the song you want to delete and then click on the bottom of the disk and a menu will come up to delete songs If you have a 1 gig Sansa you must connect the player to the computer with an USB cable and the right click on the mouse when the Windows Media Player comes up. It will then show you everything on you MP3 player and you can delete the song on the menu on the computer screen
Sep 14, 2009 | Audio Players & Recorders
My mp3 player says that the memory is full but I have no songs
if you are deleted the song using computer interface before, it is still on hidden file. plugin your device to computer and go to your sansa directory,
unhide all hidden file and delete it if you are using windows, but for mac pc, just go to the finder then ampty the trash.
Mar 02, 2009 | SanDisk Sansa e260 MP3 Player
How do you delete voice recordings?
Connect your sansa to the computer via usb. (assuming you have windows) Now go to "My Computer". If your sansa is in automatic mode, it should show up as "sansa c205". Double Click on that. Now double click on "internal memory". (If you don't have that, just skip it) Now double click on "recordings". Double click "Voice". Now a list of your recordings show up. Simply delete the ones you don't want, such as "001" and "002".
Hope this helps!
Jan 06, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Want to organize/delete songs but don't see them on my computer..
Change your USB Mode in the settings menu from MTP to MSC and see if it helps.
Jan 04, 2009 | SanDisk Sansa E280 MP3 Player
My sansa 1gb won't let me delete songs
To delete files directly from the Sansa player, follow these steps:
1. In playback mode, press the Submenu button.
2. Select Delete.
To delete music files using the computer, follow these steps:
1. Connect your Sansa to the computer.
2. Select Open device to view files using Windows Explorer on initial
connection.
3. Locate the folder where your files are stored.
NOTE: Music files are stored in the MUSIC folder. Voice recording files
are stored in RECORDING folders. Photos and Videos are stored at PHOTO
and VIDEOS folders, respectively.
4. Highlight and delete the desired files.
Dec 07, 2008 | SanDisk Sansa m240 MP3 Player
"Memory Full" message flashes, even though all files are deleted
Use the reformat option in the menu to completely erase the memory.
Oct 15, 2008 | Olympus DS-2300 Digital Voice Recorder
Erase everything from my Sandisk M230
Hello!
Im affraid to answer this question. because i only gain' thanks for trying" but its ok.
In your case , If you want to delete all files in your sansa, maybe you can delete it by formatting your sansa disk. You can find maybe the format on the menu and select format the disk(something like that.) Or you can connect the sansa to the computer and delete all files in there. You can browse your files in the my computer and select the drive created by computer when the sansa is connected.
may this help, melnavz
Mar 06, 2008 | SanDisk Sansa e200 MP3 Player
Deleting all recordings and some songs
first you go to songs and then go down to recordings, when selecting it you can delete them. also to delete some songs you should hook it up 2 da computer and take it out the music folder.
Jan 28, 2008 | Audio Players & Recorders
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
