Question about Toshiba 57H82 57" Rear Projection Television
Picture all distorted cold warms up ok
I have a 57h82 toshiba tv when cold picture is distorted as it warms its ok can you help. hopefully its an easy adjustment
  • 1 more comment
  • bridgettekay Dec 09, 2008
    I had this problem it was the computer it cost $300 to fix..
  • Locnar Dec 14, 2008
    I am having the same problem and it is getting worse. I can get a nice Plasma for $1K, so I wonder if it is worth fixing...
  • azhunter7 Dec 16, 2008
    I have been having the same problem for about 4-5 months andit is getting progessively worse. It takes longer and longer to overcome. Any ideas?
  • Toshiba Master
  • 3,459 Answers
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
picture all distorted cold warms up ok - bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on May 30, 2010
I have a toshiba 57hdx82 got it in 04 replaced the scan converter in 07 and now almost 2011 the set is giving me a convergence error the red and blue crosshairs are fine cant get the green to go straight...
It sounds like it has cost you a fair bit of money over the years. It would be great to get it going again but if you stand back and look at what it may cost, would it not be wiser to put your money into some more modern technology?
Convergeance errors are unlikely to be easy fixes. I expect the power supply is getting noisy and producing distortion on your picture. Replacing the many aged capacitors will possibly repair it.
Hope that helps.
Dec 29, 2010 | Toshiba 57H82 57" Rear Projection...
TOSHIBA 57H82 TV Blurry for 15 minutes till warms up
This is a model first sold 2002.
They have a history of the Hyper board failing. Usually noise or lines in the picture and the warmup time gradually gets longer and longer.
This board processes all signal from all inputs inside the set and is no longer available from Toshiba.
The only way to get one is from a national company called PTS Electronics who rebuilds or repairs them--cost for rebuilt board is about 220 plus shipping and part number for this model is:
Part Number23148024
I have a service bulletin with photos of the board on my computer.
It is a financial decision, not a job for the average do it yourself person to attempt.
Let me know if you have questions or need help.
SD TECH
May 03, 2010 | Toshiba 57H82 57" Rear Projection...
This is jeff I just received an answer to my problem with my Toshiba 57H82 57 in. Rear Projection HDTV. The answer was " Try Wathing the Picture in Picture " But I don't know what Wathing Means
srry . watch the picture in picture . the sub video path takes a different route through video processing and may look ok. the pip control button should be at the bottom of the toshiba remote.
Oct 02, 2009 | Toshiba 57H82 57" Rear Projection...
My picture is distorted at the top of the screen .
What you need to do is seek prodessional assistance and it's actually going to be either your bulbs are going out and/or the cpu board in your television is going out and once fixed that will solve your distorted picture issue. It may even be cheaper to buy a new television.
Sep 28, 2009 | Toshiba 57H82 57" Rear Projection...
We have a Toshiba HDTV model number 57H82. It is
Sounds like a bad tuner/decoder on the Qam analog side of things. You can bypass this with a Clear qam converter box or a analog to digital tuner box or simply having this repaired upwards of $200 bucks.
Thanks for using Fixya.com
You're Toshiba Tv Expert.
Aug 31, 2009 | Toshiba 57H82 57" Rear Projection...
Distorted & Wavy Picture
yes you repaire an authorised service centre
Aug 28, 2009 | Toshiba 57H82 57" Rear Projection...
57H82 when I first turn on the tv it is all distorted looks kind of smeared and you can not make anything out. after about 15 to 20 min after it warms up you can see the picture but it has vertical wavey...
You can try setting the convergence for your tv which will be explained in the manual (if you don't have it anymore you could try the support page for Toshiba). I had a model like this, and when they get old you can get alot of dust inside which can affect the tv, and just years of use can sort of wear them out. I am a certified installer, and to get mine back to an old tv with a good picture was going to cost me $250 for the parts necessary. An electronic repair bill could be in the hundreds of dollars and you would still have an older tv. If you don't mind the slight inconvenience of waiting for it to warm up or the lines, that option doesn't cost any more money right now.
Aug 05, 2009 | Toshiba 57H82 57" Rear Projection...
Toshiba 57H82- Distortions on the picture screen
You have leky caps in your regulated power
supply they are typ 220 uf 200v and are large
and round next to flyback
Jun 23, 2009 | Toshiba 57H82 57" Rear Projection...
Toshiba 57H82 Blurry Pic on HD inputs except Xbox 360
Probably your G-Hyper board. You will need expert servicer and should cost about 3-400.00
Craig www.classtorations.com
Jun 08, 2008 | Toshiba 57H82 57" Rear Projection...
57h82 toshiba projection tv
Hyper board bad = No longer available part # 23148024 PTS
rebuild only...send core in........57H82..............................T.
Part # is specific to model !....
Mar 20, 2008 | Toshiba 50H82 50" Rear Projection...
Toshiba 57H82 57" Rear Projection Television Logo
157 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
