We have an EWT 2kw downflow bathroom heater which cuts out
It has a pull switch which does switch the heater on and off but the heater stops working after a minute or so although the red light stays on. We clean it regularly but to no avail. Can you help please?
4 Suggested Answers
Loringh
  • 185 Answers
SOURCE: Bathroom Heater
Check out this web page
www.glendimplex.com/brandstour1.php?id=23 - 20k
Perhaps they might be able to help
Hope this helps Loringh
Posted on Oct 19, 2008
  • 1015 Answers
SOURCE: Hello, i have a Glen (hot
I'm not 100 percent for sure on those its been awile since I worked on one but I think that there is a fuseible link inside that may be your problem Hope this helps you. Thanks
Posted on Dec 30, 2010
walterkunesk
  • 683 Answers
SOURCE: Does a bathroom new installation Dimplex FX20V
It would be safe if you did it that way.
Posted on Sep 15, 2011
How do I wire FOR STORAGE HEATING
230volt is gonna require a double pole breaker, not single phase. Makes sense with 2kw.
If that's the case, then you'll have 2 hot wires & a ground.
Feb 16, 2015 | Heating & Cooling
Dimplex bathroom fan heater cord problem
take the cover off and clean the inside and were the cord is and use some wd 40 turn of the supply first and that should loosen it for you
Jan 06, 2014 | Dimplex Fx20ve 2kw Timer Wall Mounted...
Switching on
The switch is failing.
Dec 19, 2013 | Heating & Cooling
Dimplex Fx20ve 2kw Timer Wall Mounted Bathroom Downflow Fan Heater Pull Cord is stuck
turn of the powere and take the cover off and clean the pull cord and the use a bit of lubricant to keep it free that should loosen it
Sep 24, 2013 | Dimplex Fx20ve 2kw Timer Wall Mounted...
Hello, i have a Glen (hot air) downflow bathroom heater which worked for years and it was also cleaned regularly, but the other day it stopped, does it have some kind of trip switch inside or a fuse? that...
Dec 30, 2010 | Heating & Cooling
We used to have hot extremely hot water in both bathrooms. One day, the water became warm and ultimately cold in one of the bathrooms. Now, the water is also freezing in the bathroom where the water used...
Your check-valve has most likely failed at the switch.
The flow check valve works by opening when you turn the water tap. When it opens it closes a switch which turns on your heating elements. When this switch fails you will still have water flow, but no heat. Titan has parts for this but you will need to call their service Dept.
or call
Toll free support pesonnel hours (EST): Monday-Friday: 9:00am - 5:00pm
They also have an online support operator during normal business hours here
http://www.titanheater.com/livehelp/livehelp.php?department=2
Mar 24, 2010 | TitanNet TITANTANKLESS. COM PRESENTS THE...
Bathroom ceiling fan has stopped working
remove the switch and test it with a meter on ohms or remove the switch and disconnect the fan wires and connect the fan wires to an extention cord to test.
Phil
Jun 09, 2009 | Honeywell L4064B2236 Fan/Limit Control...
Actual output on settings
MODEL DELONGHI TRD0820ER 2KW OIL FILLED RADIATOR
YOU HAVE THREE SETTINGS
1. 900 WATTS
2. 1.1 KW 1,000 WATTS WHICH IS ABOUT 1.096 WATT
3. 2.0 KW 2,000 WATTS
Nov 25, 2008 | DeLonghi Dragon 3 1025 / 1025T Oil Filled...
Bathroom Heater
Oct 19, 2008 | Heating & Cooling
Heating & Cooling Logo
310 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
